Sony UBP-X1100ES Anticipation Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #61 of 119 Old 05-27-2019, 12:18 AM
Keenan's Avatar
Quoted: 4311 Post(s)
Liked: 3999
Originally Posted by priitv8 View Post
What kind of Hi-Res audio do you mean?
Previous X800 and X700 both play them all over LAN (PCM 192/24, Dolby TrueHD, DTS-HD MA, DSD) so why wouldn't this one?
This is playing on my UBP-X700. My previous X800 was no different in this respect:
Sorry, I should have been clearer, I mean lossless such as DTS-Master HD and Dolby TrueHD in video files such as Blu-ray/UHD rips.
Keenan is online now
post #62 of 119 Old 05-31-2019, 03:07 PM
DVnt's Avatar
Quoted: 29 Post(s)
Exclamation
Originally Posted by Panson View Post
No word yet if Sony's DV toggle stubbornness will continue for the X1100ES.
The Manual is finally on line under Sony Support. Sadly you still need to manually toggle DV on and off. I read nothing that stated Auto DV. What gives? Is this a flavor of DV just for Sony? Is there some type of advantage internally in these players to not support auto DV?
https://www.sony.com/electronics/sup.../47408251M.pdf
Sony OLED XBR-65A1E / Sony UHD Player UBP-X800Mark 2, & 1
Sony Playstation 4 Pro / Sony A/V Receiver STR ZA2100ES
Apple 4KTV / DirectTV Genie Gen 2 H44-500
DVnt is offline
post #63 of 119 Old 05-31-2019, 03:37 PM
Keenan's Avatar
Liked: 3999
I read that manual entry as saying the "On" position is the Auto position, meaning that when the player encounters a DV-encoded disc it will play in the format automatically. When in the "Off" position it will block any DV-encoded content from going to a display that is not DV-capable, and there are people who prefer HDR10 over DV and I'm guessing this switch will allow for that.
Botton line, leaving the switch in the "On" position equates to Auto, in my opinion, hard to say until actually playing with the unit itself.
post #64 of 119 Old 05-31-2019, 04:31 PM
UHD Addict
aaronwt's Avatar
Quoted: 9741 Post(s)
Liked: 6417
That has to do with the container used. With MKV, DTS-HD MA is not an issue with the X800. While Dolby True HD yields silence. While the same content in an m2ts file will play fine with Dolby True HD.
And then if you have the Sony player decode to PCM, it will decode the Dolby True HD audio to PCm from the MKV file and you will get audio output instead of silence.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #65 of 119 Old 05-31-2019, 04:34 PM
DVnt's Avatar
Quoted: 29 Post(s)
I read that manual entry as saying the "On" position is the Auto (DV) position, meaning that when the player encounters a DV-encoded disc it will play in the format automatically. When in the "Off" position it will block any DV-encoded content from going to a display that is not DV-capable, and there are people who prefer HDR10 over DV and I'm guessing this switch will allow for that.
We'll have to agree to disagree. Under screen settings page 21-22 you have BRAVIA Mode, HDR Output, and Dolby Vision Output. HDR Output choices are Auto or Off, DV Output choices are On or Off. I bolded your statement and stopped at content as isn't this the same operation as the X700 and current X800M2 for DV choices? And if so then the 1100ES will falsely try to output erroneous DV signal to the display from disc that aren't encoded in DV if left On. I am assuming as much. But I do agree with you on this point, to wait and see the unit on hand and in operation. Myself, I'm fine upgrading from the X800 Mark 1 to the Mark 2.
DVnt is offline
post #66 of 119 Old 05-31-2019, 04:49 PM
Keenan's Avatar
Liked: 3999
So how does it compare to an OPPO, which can play just about anything via the LAN? I'm looking for a possible backup/replacement for my OPPO 203 and it needs to be able to play ripped content such as UHD discs with full audio capabilities, does this Sony do that? I looked through the format playback charts and it doesn't appear that TrueHD or Atmos are playable via the LAN.
I guess I should be asking if the Sony will play content in a BDMV file/folder structure and I'm guessing not.
post #67 of 119 Old 05-31-2019, 04:56 PM
Keenan's Avatar
Liked: 3999
I guess we'll have to wait and see, it seems pretty clear to me but I could certainly be wrong. I'm not reading that it forces DV anywhere, only that it allows for DV if the sink device is capable of using that signal.
post #68 of 119 Old 05-31-2019, 05:25 PM
UHD Addict
aaronwt's Avatar
Liked: 6417
OPPO was nowhere near the norm. They played just about everything. Which is not typical for a disc player. I use Shield TVs to play back my UHD BD MKV rips. I have zero issues bitstreaming the lossless audio from the rips. Plus I can get a graphical interface that shows me cover art, poster art, actors, etc. Which you didn't have on the Oppo or on the Sony.
aaronwt is offline
post #69 of 119 Old 05-31-2019, 05:26 PM
UHD Addict
aaronwt's Avatar
Liked: 6417
I would expect it to behave just like the X800M2 for DV. Which behaves just like the X700 does with DV.
Which forces DV on everything when you have it set to on.
And it just boggles the mind why Sony doesn't have it set to automatically switch between DV, HDR10, and SDR. Like all the other DV players do.
aaronwt is offline
post #70 of 119 Old 05-31-2019, 05:31 PM
Keenan's Avatar
Liked: 3999
That is crazy and I agree, it should be automatic instead of forced. The next time the Sony rep comes to my local Mag/HiFi it's something I'm going to ask him about.
post #71 of 119 Old 05-31-2019, 05:32 PM
Keenan's Avatar
Liked: 3999
Yes, the OPPOs were very rare birds, which explains why they're going for insane amounts of money on the used market!
post #72 of 119 Old 06-11-2019, 12:39 PM
lebellium's Avatar
Quoted: 36 Post(s)
Liked: 30
lebellium is offline
post #73 of 119 Old 06-11-2019, 04:41 PM
aracGuate's Avatar
Quoted: 57 Post(s)
Liked: 45
Originally Posted by lebellium View Post
Región B for Bluray play only!
Región 2 for DVD play only!
Hope Sony changes those settings for USA market
Does someone knows something about this player yet?
Is it going to be in the stores this year?
Nice review, very complete.
Sonys UBP-X1100es seems like a very good option.
aracGuate is offline
post #74 of 119 Old 06-11-2019, 05:26 PM
Keenan's Avatar
Liked: 3999
That's a UK review site, Region B is Europe (EU), Africa, Middle East, Australia, and New Zealand.
post #75 of 119 Old 06-11-2019, 05:28 PM
sloanthebone's Avatar
From that review:
One annoying aspect of the player's setup is that for Dolby Vision playback you have to turn that feature on in the menu. However in doing so the player will output HDR10 and Dolby Vision content as Dolby Vision. That is far from ideal, because HDR10 content should be displayed as it was created, and not converted into Dolby Vision. The only way around this problem is to leave the Dolby Vision setting off so that HDR10 is output as HDR10, and then manually turn on Dolby Vision when playing a Dolby Vision disc.
Panson likes this.
sloanthebone is offline
post #76 of 119 Old 06-15-2019, 08:35 AM
crazepharmacist's Avatar
Quoted: 97 Post(s)
Liked: 24
What's the differnence between this and say the Sony UBP X800?
crazepharmacist is offline
post #77 of 119 Old 06-15-2019, 07:36 PM
Quoted: 1021 Post(s)
Liked: 2538
Originally Posted by sloanthebone View Post
From that review:
And it reiterates that in the Cons with, "Dolby Vision implementation not ideal".
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
"I watch a lot of movies, I know what I'm doing." - Daniel Lugo
Panson is offline
post #78 of 119 Old 06-15-2019, 07:41 PM
Liked: 2538
Originally Posted by crazepharmacist View Post
What's the difference between this and say the Sony UBP X800?
Dolby Vision, analog section, maybe other.
Panson is offline
post #79 of 119 Old 06-16-2019, 04:39 AM
Quoted: 379 Post(s)
Liked: 116
Front panel display.
Optical digital out.
RS-232 for system integration.
Panson likes this.
priitv8 is offline
post #80 of 119 Old 06-16-2019, 03:00 PM
Lozin's Avatar
Quoted: 346 Post(s)
Liked: 166
Front panel display is a must. I won’t buy a player without one.
Lozin is online now
post #81 of 119 Old 06-16-2019, 04:52 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Track listing is nice does it have this?
My UHP-H1 only shows number when a cd track starts, NET, time, stop,play and Home...
If I remember correctly
IIDexII is offline
post #82 of 119 Old 07-01-2019, 07:28 AM
Franin's Avatar
Quoted: 3430 Post(s)
Liked: 2329
This player is on my radar. Might be the one to replace my beloved Oppo. The Bravia mode really has my interest piqued.
Let us know when you pick one up Wabo
_________________________
God Bless!
Equipment: Bose Soundbar; 1951 Philco Model 50-T701 Black and White tabletop TV;Projection :HANIMEX ZOOM 8 MM PROJECTOR
Franin is online now
post #83 of 119 Old 07-01-2019, 11:12 AM
Waboman's Avatar
Quoted: 7434 Post(s)
Liked: 16868
I decided to go a different route. I am looking forward to your review when yours arrives. Don’t make us wait too long, Franin. We’re an impatient bunch.
Waboman is online now
post #84 of 119 Old 07-01-2019, 05:18 PM
Franin's Avatar
Liked: 2329
Soon hopefully that will be no 22
Sent from my iPhone using Tapatalk Pro
God Bless!
post #85 of 119 Old 07-02-2019, 06:20 PM
allisonok's Avatar
Quoted: 26 Post(s)
Just placed my order!
Denon AVR-X6300H, LG OLED55B7A, Sony UPB-X1100ES, Oppo BDP-103, Tivo Roamio OTA, Panasonic DMR-ES46V, Proscan PSLD-43, Audio-Technica AT-LP120-USB
Klipsch R-820f fronts, C-2 center, R-620f surrounds, Quintet V for Atmos, Monoprice Monolith 10", Velodyne VRP-10
allisonok is offline
post #86 of 119 Old 07-03-2019, 06:10 AM
Quoted: 38 Post(s)
Liked: 5
I can't believe a new Blu Ray player this expensive still can't automatically swtich from dolby vision to non dolby vision automatically. Panasonic and LG have been doing it for a long time.
aaronwt, allisonok, yobbo and 1 others like this.
Braggtrooper is online now
post #87 of 119 Old 07-03-2019, 04:14 PM
Liked: 2538
I can't believe the prices on any of them, for what they do and don't offer.
Panson is offline
post #88 of 119 Old 07-03-2019, 07:46 PM
Rgb
Rgb's Avatar
Quoted: 752 Post(s)
Liked: 1000
Haven't read the whole thread and a Search didn't turn up HDR10+ as a feature of the X1100es. If true, seems like a big ommision for a 2019+ player, esp against UB820
Rgb is offline
post #89 of 119 Old 07-04-2019, 04:05 AM
danielb6752's Avatar
Quoted: 50 Post(s)
Liked: 40
Originally Posted by audiomanz View Post
I too hope Auto DV is on this player. Fingers crossed it is, cause I like Sony 4K blu ray players. I have the X800 and it looks great and I only had one disk that froze but other than that they all played fine. If not, then maybe I would go for the X800M2 cause it would most likely be the same thing in terms of manually switching on DV.
audiomanz
Yes, this. The manual switch to/from DV is so disappointing in my X700 player.
danielb6752 is offline
post #90 of 119 Old 07-04-2019, 04:31 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
I really don't see the big deal about the manual on off DV.
I remember a Denon player I manually had to toggle resolution button on the players panel.
Didn't bother me.
So I don't see the big deal, if it can be adjusted by the remote/settings.
Sent fra min AGS-W09 via Tapatalk
IIDexII is offline
Reply Blu-ray Players
