OFFICIAL Sony UBP-X800M2 Owners Thread (No Price Talk) - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 129Likes
post #271 of 477 Old 07-04-2019, 10:38 AM
iraweiss's Avatar
Quoted: 106 Post(s)
Liked: 54
Originally Posted by bwillcox View Post
Do you have CEC enabled on any of your devices? The X800M2 ships with its CEC enabled (I forget the Sony name for it). I always have to disable it on my devices. My X800M2 kept turning on my TV when I was watching the projector until I disabled the CEC on it.
I just checked Monoprice as I only use Monoprice Certified Premium High Speed HDMI Cable, [email protected], HDR, 18Gbps cables. Monoprice only sells certified 4K cables up to 30' so I think 40' is definitely pushing it. Here's a link to their cables: https://www.monoprice.com/product?p_id=15427
I would look at an extender.
iraweiss is offline
post #272 of 477 Old 07-04-2019, 04:17 PM
Liked: 0
I am not sure if the hdmi cables are 4k compatible. I have had those for over 7 years. I will have to check that function on the Sony to see if it is shut off. I will have to connect the Sony Player directly to my TV with the small 4k hdmi cable to even get to the menu to check this. Thank you all for the advice! I have ordered the 4k Extender just to be on the safe side and to have the latest upgrade. I really appreciated the advice! If you think of any other possible solutions let me know.
Rod5 is offline
post #273 of 477 Old 07-04-2019, 10:03 PM
sb01gt's Avatar
Quoted: 189 Post(s)
Liked: 57
If your cables are 7 years old, they won't be 4K compatible. I have the exact same wiring setup as you, and when I made the upgrade to 4K, I also had to switch out my 50 ft. HDMI cable with a new one. Like said above, they won't be "certified" at that length, but should still work as long as you're getting one with speeds meant for 4K, the one I got is rated at 27 Gbps.
Panasonic EZ1000 65" OLED / Panasonic DMP UB400 / NAD T758v3 / Nvidia Shield TV
5.1.2 speaker setup - KEF R300 / R600c / Q50a / Focal Chorus SR800V / HSU ULS-15 mk2
sb01gt is offline
post #274 of 477 Old 07-05-2019, 07:57 AM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
I finally got around to testing if my x800m2 can stream multichannel DSD files from my DLNA server (minidlna with DSD support patch) and happy delight it does! I've had no success with my Oppo 203 players working with my DLNA server even though others are able to get them to work with theirs (likely due to the difference in servers).
Suffice it to say, another reason I am glad that I added this player to my collection.
Edit: Player just switched to a multichannel flac track and that is playing as well!
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #275 of 477 Old 07-05-2019, 08:39 AM
Ray Cendroski's Avatar
I bought one of these newer 40ft HDMI cables on the Monoprice website for $62.51 and have been using it for about a month with no problems on 4K material.
It's really hard to find on their website, but a search for product #14470 should bring it up.
Good luck,
Ray
Monoprice HOSS Active High Speed HDMI Cable - 4K @ 60Hz, HDR, 18Gbps, 24AWG, YUV 4:4:4, CL3, 40ft, Black
32 Reviews | 26 Questions, 32 Answers Product # 14470
$62.51
Length: 20ft 25ft 30ft 35ft 40ft 50ft 60ft
Ray Cendroski is offline
post #276 of 477 Old 07-05-2019, 11:11 AM
iraweiss's Avatar
Quoted: 106 Post(s)
Liked: 54
Good luck,
Ray
$62.51
Thanks for pointing out Monoprice's newer active HDMI cable line. I don't need cables that long so never looked for them.
iraweiss is offline
post #277 of 477 Old 07-05-2019, 12:09 PM
UHD Addict
aaronwt's Avatar
Quoted: 9203 Post(s)
Liked: 5918
Originally Posted by Transistorious View Post
I have the UBP-X800M2 with the following audio settings:
Digital audio Output Auto Note: Set whether to output bitstream signals or output PCM signals.
DSD output Mode Auto
BD Secondary Audio OFF
DTS Neo:6 OFF
48kHz/96kHz/192kHz PCM 192kHz
DSEE HX OFF
Audio DRC Auto
Downmix Surround
DTS CDs play DTS at 44.1kHz/16bit 1.4Mbps, without any issues. My AVR is the Onkyo TX-RZ820. The HDMI 1 to the TV. HDMI 2 to the Onkyo. I hope this helps. BTW I had the UBP-X700 set-up the same way W/O any issues, either.
Good luck!
DSSE HX I think is the option that will make it upsample 44.1khz content to 88.2khz?
Sent from my Galaxy S10
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #278 of 477 Old 07-05-2019, 05:39 PM
Transistorious's Avatar
Quoted: 83 Post(s)
Liked: 48
I am playing American Landscape DTS CD by David Benoit. It's playing at 44.1 kHz/16bit 1.4Mbps with DSSE HS on.
Transistorious is offline
post #279 of 477 Old 07-06-2019, 01:13 AM
Quoted: 306 Post(s)
Liked: 93
When I was attempting the same with my original X800, I found the DLNA server called Serviio, which could stream DSD right out of the box without any additional setup.
Tried many of them to no avail. MiniDLNA was not among them.
I’ve come to like Serviio so much that its my main DLNA server now.
priitv8 is offline
post #280 of 477 Old 07-06-2019, 05:49 AM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
Hmm, well I did try Serviio but didn't have any success with it on my FreeBSD server (have to admit that I didn't try too hard). I might try it again at some point, but for now, I'm good with minidlna.
bwillcox is offline
post #281 of 477 Old 07-06-2019, 05:59 PM
UHD Addict
aaronwt's Avatar
Liked: 5918
Is that stereo PCM or DTS? The upsampling only works on stereo pcm content.
But I looked on the SOny site and DSEE HX is the function that enables upsampling. The same thing is on my SOny x800. And my Onkyo and Denon receivers have something equivalent to it. Whether it actually makes a difference is debatable. But personally, I leave the feature on with all my devices that have it.
post #282 of 477 Old 07-07-2019, 06:10 PM
Liked: 1
Hey guys, quick question. As someone who is in the market for a new 4k Blu Ray player, is the X800M2 in any way a step up over the x700 when it comes to picture quality? From what I understand the X800M2 has a superior build quality and will add HDR 10+ support. But since my TV only does Dolby Vision, HDR 10 and HLG that's not really a consideration for me, neither is the build quality or rack mountability. DVD Audio or SACD is also not something that I see myself using.
I'm curious if the X800M2 has better image processing in any way especially when it comes to upscaling 1080p BluRays, 720p content or DVDs. This would literally be the only reason I'd spend the extra $120 on the X800M2. So I was curious if this is the case. Also, X800M2 apparently comes with an HDMI 2.0b out compared to the 2.0a on the X700, any differences there?
Siladitya Ray is offline
post #283 of 477 Old 07-07-2019, 07:39 PM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
If improved picture quality (subjective, at best) is all you care about, save your money. I own and use both a X800M2 and a couple of X700s (in different systems) and haven't noticed any apparent picture differences (of course, I haven't done a careful side by side comparison either).
bwillcox is offline
post #284 of 477 Old 07-07-2019, 08:10 PM
Liked: 1
Thanks a lot. If any possible improvements need a detailed side-by-side comparison to spot, then I'll be good with the X700 then. As long as the X700 upscales 1080p Blurays well, then I'm good with it.
post #285 of 477 Old 07-07-2019, 08:37 PM
Quoted: 30 Post(s)
Liked: 9
It does - but I don't use it that way. I let my 4k TV (Sony A9F) do the upscaling as it's got significantly more capability than the X700 IMHO.
Sony XBR-65A9F, Sony UBP-X700, Denon AVR-890 (cooled by AC Infinity AIRCOM T10), Apple TV (non 4K), B&W 600 series & LM1s in 7.1 config, Harmony Elite
avsngaiouser is online now
post #286 of 477 Old 07-09-2019, 08:10 AM
zeonstar's Avatar
Quoted: 497 Post(s)
Liked: 117
Hey all
I have a weird problem going on with my player. When I use my Harmony 950 remote activity to watch a Blu-Ray, lately when it powers everything on, the X800m2 opens the disc tray. I don't know why it's doing this, and it didn't always do it. I don't have any command on my activity to open the tray so I really don't know what is causing this to happen.
Anyone else have this happening when you power on your m2? It happens both when a disc is left in the tray and when one isn't.
zeonstar is offline
post #287 of 477 Old 07-09-2019, 10:52 AM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
Originally Posted by zeonstar View Post
Hey all
This really sounds like your Harmony remote is sending an eject code to the player. Does it behave this way when you power it on with its own remote?
bwillcox is offline
post #288 of 477 Old 07-09-2019, 02:48 PM
zeonstar's Avatar
Quoted: 497 Post(s)
Liked: 117
Hey all
It does not seem to do it with the original remote. How could the harmony send a command it wasn’t doing previously? I checked my harmony activity and it doesn’t show as having any eject command in the start up sequence.
zeonstar is offline
post #289 of 477 Old 07-09-2019, 02:53 PM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
Wish I could help with your Harmony remote, but although I do own and use two of them it's on systems that I really don't need a universal remote (simple configuration, computer monitors that turn themselves on when they receive a signal). With most of my systems I use Pronto remotes (TSU9400s).
bwillcox is offline
post #290 of 477 Old 07-09-2019, 03:06 PM
Quoted: 357 Post(s)
Liked: 287
I would try rebuilding your Bluray activity from scratch to see if maybe something got corrupted in the current activity.
Current system:
Sony 75X900e/Sony STR-DN-1080, CS-3/CS-8/CS5
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/Sony PS-4
Cheddarhead is online now
post #291 of 477 Old 07-10-2019, 05:22 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5809 Post(s)
Liked: 8279
The Harmony may be sending a Play command. Try with the regular remote to see if Play opens the tray when there’s no disc currently in the tray.
If so, check for a Harmony setting to Play when the activity is selected and the device is powered up.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #292 of 477 Old 07-10-2019, 08:20 AM
0hwell's Avatar
Quoted: 26 Post(s)
Hey all
I use an older harmony remote a 620 and it doesn't happen to me. What did you use for a player when you set up your remote, Logitech didn't list the m2 when I set up my remote so I just used the UBP-X800 settings.
0hwell is offline
post #293 of 477 Old 07-10-2019, 11:44 AM
zeonstar's Avatar
Quoted: 497 Post(s)
Liked: 117
I ended up sycning my remote to the Harmony software and it stopped doing it. Still have no idea what caused it!
—Bob
Play closes the tray if it's open but didn't do anything when the tray was closed. Turning the player on with it's own remote didn't do anything other than power it on.
I actually set it up using the X700 because it has commands saved in the database that the x800 does not have, but the commands work fine with the X800m2. Most notably, it has a "skip back" and "skip forward" command in the database that skips back or forwards instantly 10 seconds. It's a button I use frequently and no recent BD players seem to have it on the remote, yet the command works fine even though it's for an older model. (which actually I don't even think the x700 even has a remote button for that command... yet it's in the database.) I've noticed that a lot with the Harmony database. A lot of times, older models are better to choose as they have more remote command options.
dsaskew14 likes this.
zeonstar is offline
post #294 of 477 Old 07-10-2019, 08:28 PM
Liked: 0
Glad to hear about the skip functions still working on the x800m2 as l am coming from an S790 that had the skip functions along with older Sony disc players (ex. S550). That one even had a lighted remote. I use a Pronto Pro 7000 so I will be able to continue using that feature. I have not used the x800m2 yet as I am waiting for my Vizio PX65 to be delivered on Friday. My previous display was a Pioneer Kuro Pro151 (RIP). I changed out my receiver also. I went from a Yamaha RX-Z7 to a Yamaha A2070. Glad your issue was resolved.
Sent from my SM-T830 using Tapatalk
dsaskew14 is offline
post #295 of 477 Old 07-14-2019, 06:35 AM
Liked: 1
I am seriously considering a x800M2.
I searched this thread (and the owners manual) and did not find a direct reference to this question.
Does the x800M2 provide a 'source direct' output option for the HDMI output resolutoin?
(This would force upscaling to the TV rather than within the player).
Of the players I have, only the oppo's have this option.
Thanks in advance for the info!
KenUHD is offline
post #296 of 477 Old 07-14-2019, 08:04 AM
zeonstar's Avatar
Quoted: 497 Post(s)
Liked: 117
It does indeed. It's called "4K upscale setting" on this model and the options are Auto1, Auto 2, and off. Off sends video as is to your TV.
zeonstar is offline
post #297 of 477 Old 07-17-2019, 10:32 AM
Liked: 0
Mkv / dts
Hey.
I will probably buy M2 next week but I need help with one thing
Can someone tell me if it supports MKV with DTS-HD/5.1/7.1 ? Not not asking about Atmos like someone before . Just DTS
According to manual it should not but ...
Thanks in advance for reply
Legancy is offline
post #298 of 477 Old 07-18-2019, 06:51 AM
Quoted: 306 Post(s)
Liked: 93
Originally Posted by Legancy View Post
Hey.
Both the X700 and X800 did/do it. Up to dts:X. Would be surprising if the M2 didn’t.
priitv8 is offline
post #299 of 477 Old 07-18-2019, 08:14 AM
Liked: 0
According to your words it should but if you check the manual there are few lines for MKV files and no information about DTS .
Screen below
This is very confusing :/
Legancy is offline
post #300 of 477 Old 07-18-2019, 03:39 PM
Quoted: 30 Post(s)
Liked: 9
Hey.
Screen below
That screenshot shows clearly that the Sony implementation for the MKV container doesn't support DTS. DTS is only supported in m2ts and mpg.
There's a good post in the X700 Owners thread (from memory) that explains why, it's Sony adhering strictly to the specification and many MKV tools don't (i.e. they don't require the DTS core to be included in their DTS-HD encoding), so how can the player decode something that isn't there?. Off topic, but people "creating" the content need to get it right, and the best way to do that if you want DTS or DTS-HD is to put it in a M2TS container.
EDIT: This turned out to be incorrect, and despite the manual not showing DTS is supported in an MKV container, I subsequently tested DTS 5.1, MA 5.1 and MA 7.1 with no problems. I was thinking of Dolby TrueHD which doesn't play from mkvs on the X700
Reply Blu-ray Players
