OFFICIAL Sony UBP-X800M2 Owners Thread (No Price Talk) - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 167Likes
post #751 of 834 Old 02-08-2020, 04:54 PM
mrvideo's Avatar
Quoted: 1349 Post(s)
Liked: 1007
Originally Posted by hodgjy View Post
Did anyone else experience this? Was I just unlucky?
Not me, said I.
"VCR was in the closet. Still works. Can't get the clock to stop blinking, though."
Angela - Animal Kingdom - 7/16/19
My 2017 Total Solar Eclipse Photos
mrvideo is offline
post #752 of 834 Old 02-08-2020, 04:57 PM
mrvideo's Avatar
Liked: 1007
Originally Posted by psm01 View Post
Does anyone else get a periodic burst of displayed static when playing a SACD? The static is only the video display, the audio isn't impacted.
Not me, said I. We seem to be repeating ourselves.
mrvideo is offline
post #753 of 834 Old 02-08-2020, 05:19 PM
Quoted: 450 Post(s)
Liked: 51
It was on top of a shelf directly under the tv (with a few inches of clearance above it) without anything blocking airflow, and it wasn't hot to the touch at all. It was just weird. I thought about trying another unit, especially since it was on sale (and is no longer on sale), but I have an LG player that I know works and doesn't make cracking noises. The main reason I tried the Sony was the supposedly silent drive. While it was slightly quieter than the LG, it wasn't $XX (no price talk) quieter and certainly wasn't silent.
If it means anything, the manufacturing date of the 800m2 was November 2019.
I have both the X800 and the X800M2 and I've never heard any noises such as you describe. However, my first X800 unit on my main tv had to be exchanged due to random freezing and the unit would sometimes turn on by itself with nothing on the screen. My second X800 used with another tv has always worked fine with no freezing. So it seems to depend on the specific unit just like any other product you buy today. My X800M2 is around four months old and no problems so far. I do leave QuickStart ON, HDMI Control ON and no issues. It is used every day for at least two hours but I do not stream so I can't comment on that.
jkeldo is offline
post #754 of 834 Old 02-08-2020, 05:20 PM
Quoted: 450 Post(s)
Liked: 51
Originally Posted by MDeB View Post
Mine has Netflix, Amazon Prime Video, and YouTube. I don't use them either. I couldn't get the sound to work on YouTube. I chatted with Sony tech support and they tried to get me to tinker with Bluetooth on my phone, not sure why.
You're right, it's YouTube. But I'll have to try it just to see about the sound issue one day.
jkeldo is offline
post #755 of 834 Old 02-08-2020, 05:26 PM
Quoted: 450 Post(s)
Liked: 51
Originally Posted by mystickid View Post
Looking to get the X800 m2 by Sony.
Does anyone's X800 M2 still work after 2 years?
I heard that these go bad fast and are no good in the longevity department. Is this true?
Please see my post above (753) but I think you mean the X800 as the M2 version was available around May, 2019 which is not even a year. The original X800 had some issues depending on the specific unit as the one I still have with the older build date works fine where the newer one had to be returned/exchanged for an M2 under an extended warranty.
jkeldo is offline
post #756 of 834 Old 02-13-2020, 01:36 AM
Liked: 0
BD-R won’t play
My x800m2 won’t play any of my own recorded BD-R discs. Yes they are clean. Yes they are finalised. They play fine on my Panasonic Blu-ray burner/player and also on my PC. Why not on the Sony?
David Snow is offline
post #757 of 834 Old 02-13-2020, 08:40 AM
LNEWoLF's Avatar
Quoted: 539 Post(s)
Liked: 336
NEW FIRMWARE for 800M2 available
https://www.sony.com/electronics/sup...loads/00016618
Applicable Models
This information is for the following models:
UBP-X800M2
IMPORTANT: This file is only for use with the models identified. Not all models are sold in all countries.
About this download
Benefits and improvements from the latest update
Fixes issues that may occur when using network services
Previous Benefits and Improvements
Improves image quality in specific scenes
File Info
File Name
Firmware update version M45.R.0052
File Version
M45.R.0052
File Size
187 MB (196,107,038 byte)
Release Date
02-13-2020
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW, Sony XBR 85X 850G, Sony UBP-X800M2, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #758 of 834 Old 02-13-2020, 08:44 AM
LNEWoLF's Avatar
Quoted: 539 Post(s)
Liked: 336
Per owners manual. May be a concern for you.
*2 BD-RE: Ver.2.1, BD-R: Ver.1.1, 1.2, 1.3 including organic pigment type BD-R (LTH type). The BD-Rs recorded on a PC cannot be played if postscripts are recordable.
LNEWoLF is offline
post #759 of 834 Old 02-13-2020, 09:16 AM
Liked: 0
Mine were made on my Panasonic Blu-ray recorder. My local AV shop has tested one of my disks and it works fine in everything except Sony 700, 800 or 800m2. A Sony problem then! Any chance of a Sony firmware update to address this?
post #760 of 834 Old 02-13-2020, 12:19 PM
Quoted: 450 Post(s)
Liked: 51
What brand are you using? I have recorded many BD-R's using my Mac computer with an LG burner with no issues playing on both my Sony 800 and 800M2 models. But I've only used Verbatim 25gb discs so far.
EDIT: One other thing that comes to mind: what country are you in? I thought Panasonic recorders are not available in the U.S. if it's a consumer grade machine. You might have a region code issue then although I thought blurays don't have the same problem as regular dvd's.
jkeldo is offline
post #761 of 834 Old 02-13-2020, 12:29 PM
Quoted: 450 Post(s)
Liked: 51
Here is a link I found regarding DR mode and compatibility. Not sure if it applies to your situation:
https://www.avforums.com/threads/hel.../post-24070901
jkeldo is offline
post #762 of 834 Old 02-13-2020, 12:42 PM
Liked: 0
I’m in the UK.
post #763 of 834 Old 02-13-2020, 12:45 PM
Quoted: 450 Post(s)
Liked: 51
I’m in the UK.
I would check your manual about any compatibility issues compared to other players. It reminds me of the support for DVD-RAM which many players couldn't recognize but Panasonic's could as they had developed the format as I recall.
Also, I'm in the U.S.
jkeldo is offline
post #764 of 834 Old 02-13-2020, 03:09 PM
mrvideo's Avatar
Liked: 1007
Blu-ray region coding requires Java programming. I would find it strange if a recorder would be able to do that.
mrvideo is offline
post #765 of 834 Old 02-13-2020, 11:58 PM
Quoted: 381 Post(s)
Liked: 117
M45.R.0052
Wow! This version really addresses TrueHD playback from MKV files!
Just halfway theough.
Now it won’t complain about audio format not supported, but recognises it as MLP 7.1 audio.
Unfortunately, this will be output as PCM 7.1 and drops Atmos, naturally.
PS also the X1100ES got this update - M46.R.0052
priitv8 is offline
post #766 of 834 Old 02-14-2020, 11:03 AM
Derek87's Avatar
Quoted: 127 Post(s)
Liked: 48
Applicable Models
UBP-X800M2
About this download
File Info
File Name
File Version
M45.R.0052
File Size
Release Date
02-13-2020
thanks for the heads up. my 800m2 has been stable in my usage over the 2 months of ownership so i think i'll wait to hear a little more feedback here before proceeding. (in fact, i will need to plug mine back into the network as i have all network services turned off and i unplugged the ethernet cable and don't have it hooked up via wifi)
Derek87 is offline
post #767 of 834 Old 02-14-2020, 06:21 PM
Anderegg's Avatar
Quoted: 557 Post(s)
Liked: 326
Angry
Just installed the new firmware
Results...rebooted with FAILED wired status, previously only used wired, needed to connect via wireless.
NetFlix still goes to black every time you hover over a different selction.
So basically, the firmware broke my LAN and didn't fix the main issue with the apps, which is the only improvement promissed in the firmware details. Thanks Sony.
Paul
Sony X900F SDR and HDR Calibrations https://www.avsforum.com/forum/166-l...l#post57551552
Anderegg is offline
post #768 of 834 Old 02-14-2020, 07:39 PM
Morac's Avatar
Quoted: 372 Post(s)
Liked: 103
Paul
LAN still works for me after the update.
Morac is offline
post #769 of 834 Old 02-14-2020, 07:47 PM
Anderegg's Avatar
Quoted: 557 Post(s)
Liked: 326
I hate you :-P
Does your Netflix still blink?
Paul
Anderegg is offline
post #770 of 834 Old 02-14-2020, 07:53 PM
Morac's Avatar
Quoted: 372 Post(s)
Liked: 103
I hate you :-P
Paul
I can’t say as I’ve never used Netflix on it and I’ve currently temporarily canceled my Netflix service. Have you tried doing a factory reset on it?
Morac is offline
post #771 of 834 Old 02-14-2020, 07:57 PM
Anderegg's Avatar
Quoted: 557 Post(s)
Liked: 326
Will probably do that at some point in the future, seems to be working fine on WiFi...my router sits on top of the X800M2 :-)
Paul
Anderegg is offline
post #772 of 834 Old 02-15-2020, 12:46 AM
Transistorious's Avatar
Quoted: 104 Post(s)
Liked: 50
Applicable Models
UBP-X800M2
About this download
File Info
File Name
File Version
M45.R.0052
File Size
Release Date
02-13-2020
Transistorious is online now
post #773 of 834 Old 02-15-2020, 03:14 AM
LNEWoLF's Avatar
Quoted: 539 Post(s)
Liked: 336
Fyi, you can also update via USB. You’ll need to decide what is BEST for YOU. Follow the Sony USB firmware update instructions on the product page. For ME thats how I recently did both my TV and UHD player. I plan to do all future firmware updates this way. I made the decision to not connect the new for ME Sony 85X850G TV and 800M2 to the internet at all.
Just to add to Sonys USB firmware update instructions. make sure you delete ALL files on the USB drive. Then run a FULL format Fat32 on the USB drive. (uncheck quick format on Windows os.) once you download and extract the zip files from Sony. Copy the UPDATE folder with ALL the files contained within the update folder to your newly FULL formatted USB drive.
I also recommend powering the player from a complete fresh startup initially before performing any firmware updates. Turn off player. Pull plug, wait 5 minutes. Plug player back in. Power on your TV, set input to player, turn player on, once the gui displays. Plug USB drive in and it will automatically recognize the UPDATE folder and display on TV asking if you want to update. Click OK. Once update completes and does its final reboot. I like to perform an additional fresh startup as I described above.
Good luck.
LNEWoLF is offline
post #774 of 834 Old 02-15-2020, 11:55 AM
mrvideo's Avatar
Liked: 1007
Strange, the player does not see that it exists.
mrvideo is offline
post #775 of 834 Old 02-16-2020, 12:47 PM
mrmagloo's Avatar
Liked: 26
Quick question... Just picked a x800M2 up last night. So far all's going well. However, I noticed when trying to stream Spotify to my AVR mounted Chromecast, when selecting device on the phone, the x800M2 showed up in the listing for "Spotify Connect". I was surprised as I know the only built-in apps are Netflix, Amazon, and YouTube. However, every time I tried to connect, it just timed out. Anyone else noticed this and have any suggestions on how to get a successful connection. Sure would be nice to get rid of the Chromecast which is really flaky. TIA!
mrmagloo is online now
post #776 of 834 Old 02-16-2020, 11:27 PM
mrvideo's Avatar
Liked: 1007
I was asked to try and update the player via USB. Does a lead balloon mean anything? Yep, it did not work. The player said that the file was corrupted. I even tried formatting the Kingston 32GB drive. It was already Fat32. I unzipped the files directly to the device. I can see the files on the computer, but the player refuses them. So much for updating via that method.
mrvideo is offline
post #777 of 834 Old 02-17-2020, 02:50 PM
Liked: 0
Hello everyone!
New owner of the player and I already have 2 major issues:
1. The player freezes for 5-6 seconds on almost all my UHD discs and always on a specific scene. For example, while watching 2001 Space Odyssey, it always freezes on chapter 14 (57 min). My discs are brand new with no scratches.
2. I get severe audio drops on Dolby Atmos in UHD discs. The player is connected directly to my TV with a 18 gbps HDMI cable. Am I doing sth wrong or is it sth in the settings?
Thank you!
Danny80 is offline
post #778 of 834 Old 02-17-2020, 06:29 PM
LNEWoLF's Avatar
Quoted: 539 Post(s)
Liked: 336
Originally Posted by Danny80 View Post
Hello everyone!
Thank you!
Is the HDMI cable a “PREMIUM CERTIFIED HDMI cable?”.
Did you try to turn off the player, then unplug from wall outlet power, wait 5 minutes. Plug back in and power player on. Does the movie now play without concerns?.
LNEWoLF is offline
post #779 of 834 Old 02-17-2020, 07:37 PM
barryecohen's Avatar
Quoted: 80 Post(s)
Liked: 39
Just updated via Wi-Fi, took less than 5 minutes and went flawlessly.
So much media, so little time...
My Media Room...
barryecohen is offline
post #780 of 834 Old 02-17-2020, 09:15 PM
Liked: 0
Well, the unplugging would make sense in case of a total freeze, right? I'm dealing with 5-6 secs freezing issues and then the player skips some scenes and keeps on playing. Only the freezing doesn't happen randomly but on specific scenes instead, usually once on every movie.
Honestly I would ask for another disc, but it's happening on 3-4 brand new discs so I'm thinking it's the player.
As for my HDMI cable, yes it's supposed to be a Premium one, it says on the box and everything. Is there an official list somewhere?
Danny80 is offline
Reply Blu-ray Players
