4K UHD Carousel - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #31 of 33 Old 08-10-2019, 04:59 PM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 548 Post(s)
Liked: 689
Originally Posted by Low Profile View Post
I love your idea of a high capacity changer, but without the actual UHD Blu-ray player built-in. Well, it would need a UHD Blu-ray drive, the conventional UHD Blu-ray player then acting as the controller having the ability to select a given disc and play it. I'd also want to see RS-232 and IP support so that one could could send a command to the UHD Blu-ray player telling it what disc they'd like to play.
Yes, and interchangeable between player-controllers, easier with basically only Sony and Panasonic left (not counting Philips, but they can join the fun if they want to ).
The carousel mechanism shouldn't be more than $400-$500 in retail cost, plus the optical disc reader inside it at no more than $100 retail
https://www.amazon.com/Archgon-Premi...gateway&sr=8-3
treytexag likes this.
Rgb is offline
post #32 of 33 Old 08-10-2019, 05:21 PM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 548 Post(s)
Liked: 689
Could use a VPN protocol over Gigbit ethernet for the carousel<>player/controller secure link, with 512 or 1024 bit keys (whatever strength they think they need to make it work)
Rgb is offline
post #33 of 33 Old 08-12-2019, 12:50 PM - Thread Starter
Rgb
Rgb's Avatar
Quoted: 548 Post(s)
Liked: 689
ATA over Ethernet (AoE) could make the carousel "look" like a SATA optical drive to the controller/player over stock Cat6-
https://en.wikipedia.org/wiki/ATA_over_Ethernet
Rgb is offline
Reply Blu-ray Players
