Panasonic DP-UB420 4K HDR10+ (non-Dolby Vision) Blu-ray Player now available.. - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 129Likes
post #511 of 537 Old 02-13-2020, 08:57 PM
john hunter's Avatar
Quoted: 96 Post(s)
Liked: 34
Well guys I have tried about half a dozen recommended methods to convert my locked 420 B Blu ray zone to A and.....no luck!!
Am sure they work for some so you loose nothing by trying.
It may be my 420 is especially adapted for Australia or a brand new batch off the assembly line with tightened specification but still looking for an answer.
Still very happy with the 420 and knew it was zoned locked when bought so can't and won't grumble.
john hunter is offline
post #512 of 537 Old 02-13-2020, 10:02 PM
MidnightWatcher's Avatar
Quoted: 233 Post(s)
Liked: 230
Originally Posted by Pip View Post
Does it remain region B after you power off? Does it revert to region A after your power off?
Pip
Reverts back to Region A.
MidnightWatcher is offline
post #513 of 537 Old 02-14-2020, 10:31 AM
inspector's Avatar
Quoted: 269 Post(s)
Liked: 178
Can someone post setting for AUDIO? I have a fairly new AVR=Denon 4300.
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 (r-free); Panny ub420; 7.2.4. Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; 5 Bello chairs; Coaire Mini-split.
inspector is offline
post #514 of 537 Old 02-14-2020, 07:14 PM
xrtdr's Avatar
Quoted: 32 Post(s)
Are people still happy with this unit? Ned 4K but don't need dolbyvision. Don't want too much noise.
Brian Hampton likes this.
xrtdr is offline
post #515 of 537 Old 02-14-2020, 08:06 PM
Quoted: 233 Post(s)
Liked: 230
I'm very happy with it.
LVKeith, xrtdr and skylarlove1999 like this.
post #516 of 537 Old 02-15-2020, 05:00 AM
Brian Hampton's Avatar
Quoted: 1568 Post(s)
Liked: 1001
I'm thrilled with mine!
This is the second UHD BD player and my first was Sony X700 which I actually purchased twice. The first time I bought it it wouldn't play anything without locking up repeatedly so I returned it. A FW update came to "improve HDMI connectivity issues" so I gave it another chance. It was much better but still occasionally locked up which I believe was due to overheating even though it's in a very open and cool area. This happened 4 times but 3 of the 4 were when I had visitors and I was showing off the HT.... this wasn't ok.
The Panasonic hasn't locked up ever. I'm a big fan of the fact this player has a fan. For some that means it's noisy but for me I've never heard it. I keep my source devices and AVR outside of the theater. The Projector, speakers and screen are inside the theater naturally.
Moving from the X700 to the UB420 I discovered the HDR Optimizer and being a native 4K projector early adopter this HDR optimizer function is something I consider to be a must have.
=Brian
Ted99, xrtdr and skylarlove1999 like this.
Brian Hampton is offline
post #517 of 537 Old 02-15-2020, 09:52 AM
I just picked one up from Best Buy after having an LG UBMK9 (Wally World version). I made sure to dig through the ones that they had to find the newest one (I think) by looking at the ship date on the tag. Plugged it into my cheapie Benq HT2550 and with the HDR Optimizer it's like a whole new projector. I didn't notice a whole lot more noise compared to my LG and I've got my fingers crossed that it holds up well but I'm not too concerned as I don't use it for streaming, just strictly disc playback. As I continue to figure out and tweak the settings with the optimizer I'm sure it'll even be better.
Svttom01 is online now
post #518 of 537 Old 02-15-2020, 04:13 PM
inspector's Avatar
Quoted: 269 Post(s)
Liked: 178
Any settings for AUDIO and also the HDR SETTING button on the remote?
post #519 of 537 Old 02-16-2020, 07:51 AM
Mark4Mich's Avatar
Quoted: 33 Post(s)
What type of improvement would the HDR optimizer make with my Sony VW350 projector which does 4k but not HDR?Currently use a UB900.
Mark4Mich is online now
post #520 of 537 Old 02-16-2020, 11:04 AM
Liked: 1001
You can have it do 4K SDR/BT2020. It re works HDR into SDR space and it's very very very useful for projectors and low spec (early) direct view 4K sets.
Even though my VW285 supports HDR that just means there is a gamma curve for it but one size doesn't really fit all in todays HDR content. Having the player re map to SDR seems to help a lot.
I'm still learning about mine... I did a calibration but my BT2020 readings seemed off... I have to learn more about it.
-Brian
post #521 of 537 Old 02-17-2020, 08:22 AM
xrtdr's Avatar
Quoted: 32 Post(s)
=Brian
Brian, I also have a theater where the component rack is a distance from the projector. The company that did my install in 2012 is out of business. (I did score their Cinecurve Stewart screen though.) How are you handling the 4K signal to the projector? Do you run HDMI2 to the AVR, and then use HDMI extenders (or balans) across CAT6 wiring to the projector?
I'll need to figure this out if I can on my own.
xrtdr is offline
post #522 of 537 Old 02-17-2020, 08:45 AM
Liked: 1001
I only use HDMI out 1 to my AVR with a 4 foot premium certified cable then a 25 foot fiber optic cable to the projector.
This way I can also switch to ATV4K which run through the projector.
I have use the 2 HDMI outputs of my old Sony X700 before, .. when I setup my gear at a remote location for a church movie.
-Brian
post #523 of 537 Old 02-17-2020, 08:54 AM
xrtdr's Avatar
Quoted: 32 Post(s)
-Brian
So you have both the ATV and the UHD Bluray going into HDMI2.0 inputs on your AVR, then fiberoptic from HDMI out on the AVR to the projector?
I guess I need to find out if my CAT6 run can handle the signal or if i need to get fiber.
xrtdr is offline
post #524 of 537 Old 02-18-2020, 08:49 PM
blfuller's Avatar
Will this unit output 720P resolution?
blfuller is offline
post #525 of 537 Old 02-19-2020, 08:08 AM
jeep05's Avatar
Quoted: 231 Post(s)
Liked: 253
A couple of quick questions...………………..
1...My display is a Sammy KS9800, capable of close to 1,500 nits. Should I use Middle/High Luminance or Super High for the optimizer or neither and just leave the optimizer off?
2...What should "High Clarity Sound" be set to? I'm running 2 hdmi outs> 1 to video on KS9800 and 1 to Audio on Sammy K950 Dolby Atmos Soundbar.
Attachment 2687228
Name:	Audio Options (2).jpg
jeep05 is offline
post #526 of 537 Old 02-19-2020, 08:14 AM
Quoted: 1023 Post(s)
Liked: 496
I'm away from my UB420, but , IIRC, it can be set to output in 720P.
DunMunro is offline
post #527 of 537 Old 02-20-2020, 05:51 PM
Quoted: 38 Post(s)
Liked: 5
What would Netflix look better with, this Blu Ray Player because of the tone mapping option or my Nvidia Shield TV? also do you think I should avoid it because my LG C8 Oled has DV or do you think the tone mapping more than makes up for that?
Braggtrooper is offline
post #528 of 537 Old 02-20-2020, 08:08 PM
blfuller's Avatar
I contacted Panasonic and they said, No 720p: Selectable video resolution up to 3840 x 2160 pixels: 4K, 1080p, 1080i, 480p.
If you would not mind verifying that I would appreciate it.
blfuller is offline
post #529 of 537 Old 02-20-2020, 08:14 PM
Quoted: 233 Post(s)
Liked: 230
I'm sure that most 720p TVs will accept a 1080i signal. My old Pioneer 5080 even accepts 1080p.
post #530 of 537 Old 02-21-2020, 08:36 AM
Liked: 496
It will be another week before I can do that.
DunMunro is offline
post #531 of 537 Old 02-21-2020, 08:41 AM
Super Moderator
teachsac's Avatar
Quoted: 1328 Post(s)
Liked: 2164
Panasonic is correct.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #532 of 537 Old 02-21-2020, 04:51 PM
Quoted: 38 Post(s)
Liked: 5
Does this player play 4k mkv files? Like I see some say it doesn't play this or that audio format. But I don't care about Atmos. Does that mean if it's an Atmos track in the file you get no audio or it will just convert it to something else but you still hear audio?
post #533 of 537 Old 02-21-2020, 04:55 PM
Quoted: 233 Post(s)
Liked: 230
No audio.
post #534 of 537 Old 02-24-2020, 04:30 PM
Liked: 1
HDR Optimiser vs Dolby Vision
Hi all looking to get this player for use on a TV that has Dolby Vision support and I was wondering on how it compares to the HDR Optimiser on this unit. Thanks
D'Anthony Norman is offline
post #535 of 537 Old 02-24-2020, 06:22 PM
Super Moderator
teachsac's Avatar
Liked: 2164
The 420 does not support Dolby Vision. The 820 does.
teachsac is offline
post #536 of 537 Old Yesterday, 11:18 AM
Pip
Pip's Avatar
Quoted: 380 Post(s)
Liked: 187
Originally Posted by inspector View Post
This is what I read. Insert disc, wait for ERROR message to appear. Then hit STOP on remote followed by hitting TOP MENU twice. Now region code is defeated. You need to repeat this every time you play a disc. This works for "B" discs, not sure about "C" discs.
I hope you try it and get back to us.
Originally Posted by MidnightWatcher View Post
Just worked with a Region B bluray I have. Fantastic!
Jest a heads up: This does work for Blu-rays (at least Region B) but it does not work for DVDs (Region 2). I tried guessing at some button presses, but absolutely nothing worked.
Pip
Pip is offline
post #537 of 537 Old Today, 11:46 AM
gireesh's Avatar
How does this compare to Sony BDPS6700? Does this support 3D Bluray?
gireesh is online now
Reply Blu-ray Players
