Panasonic DP-UB420 4K HDR10+ (non-Dolby Vision) Blu-ray Player now available.. - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #721 of 734 Old 05-14-2020, 01:04 AM
Liked: 0
Anyone use this player as CDs player without turning on the TV?
Should I use an optical cable ? Or how....?
HAIMIRICH is offline
post #722 of 734 Old 05-14-2020, 01:43 PM
Quoted: 1326 Post(s)
Liked: 701
Originally Posted by biglen View Post
When the 420 is set to SDR/BT2020, the HDR Settings button is disabled. If you hit the Option button, it takes you to the HDR Optimizer settings. Is that the same menu it would take you to if the HDR Settings button wasn't disabled?
Sent from my SM-N975U using Tapatalk
IIRC, yes.
DunMunro is offline
post #723 of 734 Old 05-15-2020, 01:14 AM
solobaric's Avatar
So, is there any reason other than Dolby Vision to step up to the 820? I have an older 1080 projector and don't need DV so wondering if the 420 would be just fine for me.
solobaric is offline
post #724 of 734 Old 05-15-2020, 05:52 AM
inspector's Avatar
Quoted: 299 Post(s)
Liked: 195
Yes
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" .09 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 (r-free); Panny ub420; 7.2.4. Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; .
inspector is online now
post #725 of 734 Old 05-15-2020, 06:24 AM
Quoted: 43 Post(s)
Originally Posted by Mike Butny View Post
I picked up the 420 and I noticed almost every ultra Bluray will pixelate/ glitches right around the halfway mark in a movie. I have to skip 1-2 chapters forward to get a stable picture again. The only way to get it to playback glitch-free is to take the disk out and clean it ( even though it didn't have a mark on it), stop the movie completely, and go back to the same scene. I watched Alien last night and I made sure I cleaned the disk before I started it and boom, the same problem right around the halfway mark. I'm thinking it may be at the point where perhaps it's a layer change and the player is getting hung up. I also watched a few regular Blu-rays and have had zero problems. Should I return the 420 for another unit or perhaps upgrade to the 820? Has anyone else experienced this issue?
Ive had the same issue with my ub400. ive watched endgame flawlessly, and then had it hang up in the same spot on the fight scene near the end. wondered if it was a buffering issue.
pgscubadiver is offline
post #726 of 734 Old 05-15-2020, 08:12 AM
Mike Butny's Avatar
Quoted: 1219 Post(s)
Liked: 2904
I returned the unit for another ub420 and have watched 2 ultra blurays without any issues.
Equipment List: JVC RS500, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Panasonic UB420, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, 2 Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA S3600I'S.
Mike Butny is offline
post #727 of 734 Old 05-15-2020, 09:41 AM
edfowler's Avatar
Quoted: 349 Post(s)
Liked: 188
I returned my 820 and got a 420. Exact same picture quality
johng, Pip, inspector and 2 others like this.
Chad B calibrated JVC RS600, 112" wide 2.35 DaLite 2.8 High Power Screen (395 calibrated nits baby!!), 7.5.4 Yamaha RX-A3050, Yamaha RX-Z9, Aerial Acoustics Model 6, Model 5, CC3, Def Tech UIWBP/A, 4-15" Infinite Baffle Sub + 15" Velodyne Sub Near-field, OPPO 203, Panasonic UC420, Geek Pulse DAC, Nvidia Shield. Lots of iFi and Furman power filters which made my computer audio listenable.
edfowler is offline
post #728 of 734 Old 05-15-2020, 07:22 PM
Dan Daigle's Avatar
Quoted: 49 Post(s)
Hey guys... I was wondering...whats with the downmix setting. Out of the box it's on stereo but there is an option for surround encoded. I have the player going through a sony dn1080 AV receiver and I'm doing 5.1. Should I leave it on stereo? Or change it to surround encoded. Also I have a new Samsung Q90T tv... Should the hdr tv type on the player be set to middle or high luminance lcd or the super high luminance lcd?
Dan Daigle is offline
post #729 of 734 Old 05-16-2020, 04:17 PM
ajstan99's Avatar
I have mine set to “Surround Encoded” and “Super High Luminance”. I have a 2020 Frame which is likely not as bright as your 90T. I couldn’t tell the difference between the two settings and figure I’d start with the setting for the highest spec TV and retest after I got familiar with the 4K discs I have.
ajstan99 is offline
post #730 of 734 Old 05-25-2020, 12:32 PM
mkiv808's Avatar
Quoted: 142 Post(s)
Liked: 36
I am loving the picture on this connected to my JVC X570R.
However, I've had issues with some Blu-Rays. Notably Skyfall and Guardians of the Galaxy. Both 1080p. Skyfall just stops midway through the movie (layer change?), almost like there's a scratch on the disc. But the disc is PERFECT.
Guardians had some moments where it seemed like a scratch, but it wouldn't stop completely like Skyfall. It would skip ahead a bit and keep working. This happened twice, once halfway through, once about 3/4 through. That disc worked perfectly on my Xbox.
Do I have a bad unit?
One thing I will say is I haven't initiated a firmware update yet, not sure if that would help.
mkiv808 is online now
post #731 of 734 Old 05-25-2020, 03:56 PM
MidnightWatcher's Avatar
Quoted: 265 Post(s)
Liked: 263
Sounds like a bad disc. My Blu-ray of World Trade Center looks perfect but won't play at all (in any player).
MidnightWatcher is online now
post #732 of 734 Old Yesterday, 12:23 AM
JP32's Avatar
Quoted: 69 Post(s)
Liked: 36
I've had the exact same problem last week, on the same movie, but on the XBOX ONE X.
As I type this, I'm 2nd guessing myself on whether it could have been Aliens (I went on an Alien movie run and watched 1-3 within a week of each other. I have ALIEN on 4k, but the rest I played from my 1080p BD boxset). Another movie glitched HARD and didn't revert without rebooting the xbox.
I've definitely noticed an uptick in apparent layer change glitches, and random frame stutters... I wonder if there's been some almost-universal firmware update that's messed a bunch of machines up... or if it's just a coincidence, and both our machines are dying.
JP32 is online now
post #733 of 734 Old Yesterday, 01:21 PM
Mike Butny's Avatar
Liked: 2904
Since I returned the UB420 and purchased another I have had zero issues. The issue in my case was the player and not the physical disk.
JP32 likes this.
post #734 of 734 Old Yesterday, 06:36 PM
JP32's Avatar
Quoted: 69 Post(s)
Liked: 36
Good to know... thanks for the heads up.
Mike Butny likes this.
JP32 is online now
Reply Blu-ray Players
