"Unsupported Audio Device" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2007, 07:11 AM - Thread Starter
rpoulos's Avatar
Quoted: 16 Post(s)
Just got a PS3 for my bluray player and whenever I play a disc I get this message on my TV: "Unsupported Audio Device Detected". It's a message generated by the TV, which is a Sony 60a2000.
I'm running HDMI direct to the TV, but running optical to my receiver. Everything runs fine, but it's just a litte annoying to keep seeing this message every time I run a movie.
I assume it's the HDMI audio stream that the TV doesn't like, but why is it unsupported? Could it be that the PS3 is HDMI 1.3 and the TV is only 1.2? If so, I haven't been able to disable the HDMI audio in the PS3 settings...
any thoughts...advice?
thanks,
Rob
rpoulos is offline
post #2 of 4 Old 02-23-2007, 09:54 AM
WaldorfSalad's Avatar
thanks,
Rob
The A2000, like many other TVs, supports only PCM 2.0 and not bitsream so you'll switch your player to output PCM you won't get the message. I'm not familiar with the PS3 but the Samsung BD player does the same thing whereas the Sony BDP-S1 doesn't because it has a seperate setting for HDMI audio and has an Auto setting.
WaldorfSalad is offline
post #3 of 4 Old 02-23-2007, 11:32 AM - Thread Starter
rpoulos's Avatar
Quoted: 16 Post(s)
Hey thanks Waldorf, I'll try that out...I think I have it set to PCM now though, I will check
rpoulos is offline
post #4 of 4 Old 02-23-2007, 11:47 AM
Maxx_75's Avatar
The problem is that the PS3 doesnt output audio via HDMI and toslink at the same time. I wish it did but it doesnt. Perhaps they can fix this via firmware update.
"My ignorance amuses me." .......Manfred Powell
Blu-Ray = 381 HD DVD = 1
My Collection
Maxx_75 is offline
Reply Blu-ray Players
