OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE - Page 669 - AVS Forum | Home Theater Discussions And Reviews
 12518Likes
post #20041 of 20079 Old 01-20-2020, 05:45 PM
Quoted: 21 Post(s)
Liked: 1
Originally Posted by ipca204 View Post
No, because your bdp-140 is running a modified firmware which is why it can read ISO. There are a couple of players that can do that as well with modified or "jailbroken" firmware but we get bitch slapped if we talk about it in detail on the forum.
thank you very much friend, the information I have is that oppo 203 does but only with BDMV files, tell me something I have been researching a lot about media players, KDLINKS, CHINOPPO, DUNE HD, ZAPPITI, EGREAT, HIMEDIA, POPCORN HOUR, some exhibit original blu ray menus, others only bdlite, do you know other brands to pass me and so I do more research? in your opinion which are the best in this matter?
Cbizotto is offline
post #20042 of 20079 Old 01-20-2020, 06:14 PM
Quoted: 342 Post(s)
Liked: 181
chinoppo aka m9702 is by far the best of ALL of them. I have had nearly every single media player in the last 10-14 years for playback of local media....
ipca204 is offline
post #20043 of 20079 Old 01-20-2020, 06:23 PM
Quoted: 21 Post(s)
Liked: 1
thanks again, does chinoppo play with both iso and bdmv menus? the problem is that here in Brazil m9702 is not found and imports are very expensive here, taxes etc ... apart from m9702 in your ranking, which would be 2nd, 3rd best?
Cbizotto is offline
post #20044 of 20079 Old 01-20-2020, 06:30 PM
Quoted: 342 Post(s)
Liked: 181
If your only concern is blu ray ISO and menus, you can easily get by with a Dune Smart series. They are discontinued right now but that would be my second choice for blu ray ISO files with menus.
yes, the chinoppo does iso with full menus as well as 4kuhd iso with menus an dolby vision
ipca204 is offline
post #20045 of 20079 Old 01-20-2020, 06:34 PM
Quoted: 21 Post(s)
Liked: 1
yes you mean the dunes hd smart d1 and b1 correct? even the b1 has a blu ray player together, so even though they are old and discontinued they still run iso and bdmv with original menus?
Cbizotto is offline
post #20046 of 20079 Old 01-20-2020, 06:36 PM
Quoted: 21 Post(s)
Liked: 1
chinoppo is linux? this dune hd smart is linux? not android?
Cbizotto is offline
post #20047 of 20079 Old 01-20-2020, 06:36 PM
Quoted: 342 Post(s)
Liked: 181
yes, or even the h1..
ipca204 is offline
post #20048 of 20079 Old 01-20-2020, 06:39 PM
Quoted: 21 Post(s)
Liked: 1
dune hd i can with good price used, the smart b1 or d1 version, can you name me sites where chinoppo are sold? I'm going to try to see if I can find a way to bring him with more taxes, if I can't get there for the dunes, I also have an option here in Brazil of the dune base 3d, can I buy too? is it reliable like the smart model? I was even surprised that you put the dunes in front of zappiti, egreat, himedia and kdlinks that have 4k versions, although they are all android and I sincerely prefer linux or similar
Cbizotto is offline
post #20049 of 20079 Old 01-20-2020, 06:43 PM
Super Moderator
teachsac's Avatar
Quoted: 1352 Post(s)
Liked: 2202
Please continue in the networking section:
https://www.avsforum.com/forum/39-ne...ent-streaming/
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #20050 of 20079 Old 01-27-2020, 01:39 AM
burnfout's Avatar
Quoted: 33 Post(s)
Hi everyone, I just bought a Sony KD-65AG9, looking for a 4K player now.
If I want 4K streaming (netflix and amazon prime) including Dolby Vision, and DV Vision on Disc playback, what are the best options?
burnfout is offline
post #20051 of 20079 Old 01-27-2020, 01:48 AM
ten8yp's Avatar
Sony UBP-X700 for sure. I love mine. I have owned Sony blu ray players for years and never had an issue and the x700 is considered by many to be the best bang for the buck for 4k players anywhere. Hard to go wrong with it.
I've also heard that the Panasonic UB420 is decent but I haven't owned it.
ten8yp is offline
post #20052 of 20079 Old 01-27-2020, 05:03 AM
BillP's Avatar
Quoted: 669 Post(s)
Liked: 566
^^ I don't believe the Panny 420 plays DV.
Sony A9G, Oppo 205, Parasound JC2, Parasound A21, Sonus Faber Olympica IIIs
BillP is offline
post #20053 of 20079 Old 01-27-2020, 04:44 PM
Liked: 5
Hey guys I'm looking for a 4K blu ray player that supports blu rays in dolby vision and dolby atmos and that can also play .mkv rips (remux) in HDR (dolby vision preferably) with Atmos. My set up is LG B9 and Samsung K950 soundbar. My Xbox One X won't play Dolby Vision blu rays and the integrated LG media player doesn't support Atmos or Dolby Vision for the blu ray rips. I'd rather get a blu ray player that can do it all and end the headaches.
SliChillax is offline
post #20054 of 20079 Old 02-08-2020, 07:43 AM
allene222's Avatar
Quoted: 13 Post(s)
Looking for a 1080p blu-ray player to play rented Netflix discs. I like the specs of the Sony 3700 but the Amazon reviews make me think that it is junk. 28% 1 star reviews! Discs getting stuck in the unit and sending it in for repair with the disk inside. Is this real?
The other unit is a Best Buy offering that is not on Amazon and it is the LG-BP175. Since it is not on Amazon there are no reviews there and I am unable to find any reviews elsewhere so guidance is lacking.
I have a high end DVI cable from my processor to my projector. Other 1080p equipment works over the cabling but I doubt that 4K would work so I do not want anything that outputs just 4k. If I ever update to 4k it will be streaming with a Chromecast right at the projector and coax audio back to the processor. But I have other reasons that say 4K is not in my future so it is just not desirable.
There may be other options I should consider that I am unaware of so I am not limiting myself other than by my ignorance. I have checked all the posts on this thread back to the beginning of 2019 and searched Google without getting guidance.
To be more specific I have two questions other than what should I get:
1) Does the S3700 really eat discs like the reviews say?
2) Is the LG-175 any good?
I am leaning toward the LG-175 but concerned that there are no reviews of it anywhere that I can find.
Thanks for your help.
Allen
Sony 1080p TV
MythTV 1080p
Espon 3800 projector
105 inch screen
Chromecast (one at the Tv and one at the projector)
Outlaw 990 processor
Classe 200 power amp
Thiel cs3.6 speakers
Sunfire sub
Rear speakers (4.1 system)
PS. I am running 4.1 surround because the fronts are so good that even adding a Thiel center degraded the sound.
allene222 is offline
post #20055 of 20079 Old 02-11-2020, 05:17 AM
BillP's Avatar
Quoted: 669 Post(s)
Liked: 566
Panasonic and Sony seem to be the most popular. And there is no such thing as a player that outputs just 4k. All 4k players can also output 1080p; you simply designate the desired output in the settings menu.
BillP is offline
post #20056 of 20079 Old 02-11-2020, 09:26 AM
purduesd's Avatar
Quoted: 84 Post(s)
I'm setting up my first theater w/ projector and in need of a quality UHD Bluray player. My theater is open concept and setup for Dolby atmos. Should i rely on my bluray player for the upscaling? Leave that to the projector?
TIA!
Epson 6050
Denon x3500H
5.1.2
considering an apple tv for streaming
purduesd is offline
post #20057 of 20079 Old 02-11-2020, 10:54 AM
Quoted: 1077 Post(s)
Liked: 520
TIA!
Epson 6050
Denon x3500H
5.1.2
The Panasonic UB420 is probably your best value, and it works very well for projectors, with the UB820 as a potential upgrade. Both have excellent upscaling as well and it's probably best to let the BD player do the upscaling, but that's easy to test. The UB420 also does well for streaming from Netflix and Primevideo, as it probably has more options to enhance streaming content via SDR to HDR conversion and via it's HDR Optimizer, than other streaming devices.
DunMunro is offline
post #20058 of 20079 Old 02-15-2020, 06:36 AM
Bill Mac's Avatar
Quoted: 2277 Post(s)
Liked: 3535
Currently available Blu-ray player to play DSD/PCM files off of a USB hard drive
I'm looking for a currently available (new) Blu-ray player to play DSD/PCM files off of a USB hard drive. The player would also need to have apps for Netflix and Prime Video. I'm setting this up for a friend so she can play music files off of a hard drive. Any suggestions would be appreciated !
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #20059 of 20079 Old 03-02-2020, 01:45 PM
Quoted: 12 Post(s)
Liked: 2
Hey folks... I've been perusing the Thread here for an hour or so... I'm curious if you experienced folks have any recommendations - I have a few criteria I'd like to see in a BR Player.
Blu-Ray and DVD. Region Free, of course.
PAL & NTSC
A USB port to play Data.
And the ability to play most Data like, .mkv, .mp4, .TS, .avi, DVD ROM, .wmv (not required)... the Usual, most popular Data.
Wi-Fi would be nice but not critical. My Receiver is wi-fi and I assume I can update firmware to the 4k Player thru the HDMI cable, can't I?
A lot of these at 220 say: "Blu-ray Region switching - 1 Button." Is that a problem?
I was thinking of the: LG BP550
Any recommendations?
Thanx!!!
albabe is offline
post #20060 of 20079 Old 03-04-2020, 12:28 AM
Liked: 0
Hi,
Am looking for recommendations on players that have 'source direct' as an option (rather than switching for each disc manually). I believe the Sony x800mk1 has this ability. Also the oppo's but these are now discontined.
Thanks in advance!
togs is offline
post #20061 of 20079 Old 03-06-2020, 08:45 AM
Liked: 0
Looking for DVD-A player with lossless HDMI output
I have some legacy DVD-A (5.1 channel audio, not video) discs that I would like to play. I am looking for perhaps a out-of-production DVD player which will decode DVD-A discs and output the 5.1 channel signal through an HDMI port. I would like a player that outputs the audio signal without degredation, i.e. lossless. Does such a player exist?
Boomerut is offline
post #20062 of 20079 Old 03-06-2020, 09:06 AM
Dom Di Stroia's Avatar
Quoted: 225 Post(s)
Liked: 126
I believe so:
http://wiki.oppodigital.com/index.php?title=DV-980H
https://www.oppodigital.com/support/dv980h/
A/VR: Sony STR-DE598; front: Polk Audio (1x RTi6 + 1x TSx220B)
subs: 1x JBL PSW-1200 + 1x BIC RtR RtR-12S
rear: 2x Klipsch Reference R-15M
monitor: LG 24EA53V-P (panel: LG Display AH-IPS)
display: Sony BRAVIA KDL-48W600B (panel: S-LCD S-PVA)
Dom Di Stroia is offline
post #20063 of 20079 Old 03-10-2020, 02:58 PM
Quoted: 31 Post(s)
Liked: 2
Question
Hi,
I’m looking for a blu ray player that will play disks from both US and Europe.
A mid or high end player would be fine, but it should at least be able to play 4K videos and Atmos soundtracks.
Any suggestions?
Thank you
Hoggorm is offline
post #20064 of 20079 Old 03-10-2020, 05:23 PM
Quoted: 1111 Post(s)
Liked: 2945
Originally Posted by Hoggorm View Post
Hi,
Any suggestions?
Thank you
Try Amazon or other for LG UBKM9.
This AVS linked item may be long gone. Note: Owner says it's not compatible with Sony Dolby Vision.
https://www.avsforum.com/forum/210-v...-4k-ubkm9.html
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
"I watch a lot of movies, I know what I'm doing." - Daniel Lugo
Panson is offline
post #20065 of 20079 Old 03-10-2020, 07:28 PM
Quoted: 31 Post(s)
Liked: 2
Thank you for the suggestion. I am a bit confused though. There appears to be two different versions of this player. I understand AVS do not allow links to sites such as Amazon, but searching for the mentioned player gives two very different prices for this device. One costs over 300 USD and claim to be both region free and accepts a range of voltage an Hz. The other costs around 150 USD and appears to be neither region free nor accepting 240 volts... Looking the player up on LG mention nothing about this beeing region free.
What is correct? Will Amazon claim it to be region free when it is actually not?
Hoggorm is offline
post #20066 of 20079 Old 03-10-2020, 08:12 PM
Super Moderator
teachsac's Avatar
Liked: 2202
Manufacturers are not allowed to produce region free players. Any manufacturer player will be limited to its designated region for Blu-ray and DVD. UHD is region free. Region-free players sold on sites are modified by third parties, may not be firmware upgradable, and are not covered under manufacturer warranties.
teachsac is offline
post #20067 of 20079 Old 03-11-2020, 02:20 AM
Quoted: 31 Post(s)
Liked: 2
I see... Is there a risk that performance may be downgraded as well then so that the player do not deliver its full potential in regards to audio and video quality?
I'm just surprised to see that the mentioned device, with a third party modification as far as I understand, is labeled with "Amazon's Choice". It seems a bit misleading if this is not a completely legit product...
Hoggorm is offline
post #20068 of 20079 Old 03-11-2020, 10:16 AM
mdavej's Avatar
Quoted: 3233 Post(s)
Liked: 1478
Nope
Amazon is chock full of questionable items from many 3rd party sellers. "Choice" means that product gives Amazon the biggest kickback.
Legit brands don't make region free players. They're region free either by a remote hack or firmware or hardware mod. If you're not comfortable with that, you'll have to but a different player for each region. Also realize that DVD regions and Bluray regions are very different. So you may need even more players to cover the more numerous DVD regions.
Personally, my $30 used Sony has been working great for all regions. But it's only 1080p, not UHD.
mdavej is online now
post #20069 of 20079 Old 03-11-2020, 01:58 PM
Quoted: 31 Post(s)
Liked: 2
Originally Posted by mdavej View Post
Nope
I understand! Thank you!
Hoggorm is offline
post #20070 of 20079 Old 03-17-2020, 04:49 PM
Ian_Slater's Avatar
Hi all,
Looking for a recommendation for the cheapest Blu-ray player that outputs 6 channels LPCM from True HD.
Something used on Ebay would be fine.
I mostly watch dvds with the occasional blu-ray. I have a 4k tv the but the audio setup is an older Meridian setup that is HDMI 1.4 spec.
So I don't watch anything in 4k.
Thanks to all...
Ian_Slater is offline
Reply Blu-ray Players
1080p , bd-30 , Blu Ray Players , blu-ray , blu-ray 3d , blu-ray dvd hardware player mp4 usb playback , blu-ray players , blueray , bluray player , colour , control , counter , Dts , dvd , dvd player , dvd-a , flac , hdmi input , Lg Bd 390 Network Blu Ray Disc Player , lg blu ray , mkv , multichannel analog , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Panasonic , philips blu ray , Pioneer Elite Bdp 62fd , Pioneer Pdp 5080 Hd , Plasma Hdtv , player , quality , S390 , sacd , samsung bd f7500 , samsung blu ray , samsung uhd , size , slow , smart , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , sony bdp-s6200 , Sony Blu Ray Disc Player Bdp S790 , subtitle sizes , subtitles , Toshiba , usb , video quality , wifi , zoom
