OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE - Page 671 - AVS Forum | Home Theater Discussions And Reviews
 12523Likes
post #20101 of 20107 Old 06-26-2020, 07:36 PM
Liked: 0
Originally Posted by mdavej View Post
Panasonic is usually pretty compatible. My guess is your disc is not US region or the player is failing (worn drive belt, dusty/failing laser). A good cleaning may extend its life a little more.
Pickings are pretty slim these days. A Sony 3700 would work fine or even a 1700 if you don't intent to stream. I've had Sony players since before the dawn of blu-ray and they've always had excellent compatibility. Then again, so have all my Panasonics.
The discs are North American region & as I burned the BD-REs myself, they'd have to be region-free. I also double-checked the box set and it's Region 1.
The irony is that both players have had very low usage. How do I clean the players?
Paul_W is offline
post #20102 of 20107 Old 06-28-2020, 02:51 PM
PaulGo's Avatar
Quoted: 286 Post(s)
Liked: 196
Originally Posted by rdgrimes View Post
The Sony S1700 and S3700 are still available at BB, and yes they are 2016 models. They both have pretty much the same Android based UI and smart features, with WiFi being the main difference. The S6700 is also under $100 and adds 4K up-scaling.
I don't believe any of the Sony Blu-ray players have an Android based UI. It is a propriety UI.
Dom Di Stroia likes this.
PaulGo is online now
post #20103 of 20107 Old 07-05-2020, 06:21 AM
SubaruB4's Avatar
Quoted: 47 Post(s)
Liked: 30
I'm looking for a UHD blu-ray player I really just need it to have Dolby Vision I don't care about any streaming apps on it.. I would put my budget max about $350.
SubaruB4 is offline
post #20104 of 20107 Old 07-05-2020, 09:54 AM
Super Moderator
teachsac's Avatar
Quoted: 1446 Post(s)
Liked: 2538
Display will make a difference. If you have a Sony, you'll need either the Panasonic 820 or the Sony 700/800 series.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #20105 of 20107 Old 07-09-2020, 12:29 PM
MrChad's Avatar
S~
I'm in the same boat. Just got an LG 65" CX OLED TV. I'd like a player with separate Audio HDMI out so I can continue to use my older Denon AVR-1610 receiver (which supports hi def audio but not 4K passthrough). And I'd like HDR10+ and DV capabilities. The Sony UBP-X700 seems like a nice player for the money, but manually turning on and off DV seems like a pain.
MrChad is offline
post #20106 of 20107 Old 07-09-2020, 05:56 PM
Super Moderator
teachsac's Avatar
Liked: 2538
Only player I would personally consider for playing discs is the Panasonic.
teachsac is offline
post #20107 of 20107 Old 07-11-2020, 08:28 AM
pirspilane's Avatar
Quoted: 18 Post(s)
Why is the Panasonic better than others? I was considering the UB820, but don't need the analog audio output. I wonder if a cheaper model would give the same video quality?
pirspilane is offline
Reply Blu-ray Players
1080p , bd-30 , Blu Ray Players , blu-ray , blu-ray 3d , blu-ray dvd hardware player mp4 usb playback , blu-ray players , blueray , bluray player , colour , control , counter , Dts , dvd , dvd player , dvd-a , flac , hdmi input , Lg Bd 390 Network Blu Ray Disc Player , lg blu ray , mkv , multichannel analog , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Panasonic , philips blu ray , Pioneer Elite Bdp 62fd , Pioneer Pdp 5080 Hd , Plasma Hdtv , player , quality , S390 , sacd , samsung bd f7500 , samsung blu ray , samsung uhd , size , slow , smart , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , sony bdp-s6200 , Sony Blu Ray Disc Player Bdp S790 , subtitle sizes , subtitles , Toshiba , usb , video quality , wifi , zoom
