Thread Tools |
I'm about to do a complete overhaul my 10+ year old home theater system, which is based around a Knox S-Video 8x8 matrix switch (the "hub").
The new system will have an LED HDTV (probably a 60"+ Samsung smart TV) and an AV receiver (likely a Sony STR-DN1040).
I'll continue to need to allow my non-HDMI-capable legacy devices to act as sources: a CD changer, a Hi8 VCR and even a S-VHS VCR. As an experiment, I bought an S-Video to HDMI converter, and the conversion quality is not bad, considering the relatively low resolution of the legacy device itself. So it appears with a converter for each legacy source, I'll be able to standardize on an HDMI hub.
So here's my question: should the HDTV act as the hub, or should the AV receiver?
I'm leaning towards using the AV receiver as the hub, as it has more HDMI inputs than the HDTV (the Sony receiver has 8).
But what are the pros and cons of using the HDTV as the hub?
DadCat
Sponsored Links | |||
Advertisement |
Too bad you didn't upgrade your receiver a couple of years ago (unless you are worried about 3D) Upconversion of legacy video formats to HDMI used to be a common feature on many receivers, simply to consolidate cabling to your display.
Advertisement |
Tags |
Sony Str Dn1040 7 2 Channel 1050 Watt A V Receiver |
Thread Tools | |
Posting Rules | |
