2.1 Speaker for gaming/small room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-03-2015, 08:08 AM - Thread Starter
Quoted: 49 Post(s)
Liked: 1
I'm looking for a 2.1 speakers that have RCA inputs (red&white). Must have a good quality subwoofer.
ANy recommendations?
darrenchristoper is offline
post #2 of 6 Old 04-03-2015, 09:03 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 43
Budget? What does "good sub" mean to you?
The red and white (rca) inputs can be adapted to the 3.5mm plug that most of these systems have. Be careful though. I have seen the RCA plugs with both line level and speaker level outputs. You need to check whether the jacks are for amplified or unamplified signals. The suggestions below assume the signals are unamplified.
In the $150 range, try these:
http://www.amazon.com/gp/product/B00...f_rd_i=desktop
http://www.amazon.com/Klipsch-ProMed...s=2.1+speakers
jayn_j is offline
post #3 of 6 Old 04-03-2015, 10:34 AM - Thread Starter
Quoted: 49 Post(s)
Liked: 1
OK thanks... budget is $100. I'm not sure about the jacks.... I have a Sony Bluray player with HDMI and RCA ports.... Are the signal amplified or unamplified?
Hmmm good sub.... If I can hear a deep explosion from my PS3, that would be a good sub.
post #4 of 6 Old 04-03-2015, 10:45 AM
steve1106's Avatar
Quoted: 819 Post(s)
Liked: 539
I have the Logitech z623 and the sub will wake up the dead. I got mine a couple of years ago for $106 so they do go on sale.
steve1106 is offline
post #5 of 6 Old 04-03-2015, 12:05 PM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 43
Those will be unamplified. Your original post made me think you were hooking to a computer. No specific recommendations at $100. I would suggest you go to amazon and search "2.1 speaker system"
jayn_j is offline
post #6 of 6 Old 04-04-2015, 01:00 AM - Thread Starter
Quoted: 49 Post(s)
Liked: 1
not too cheap though like $50 speakers.... maybe around $80 to $100.... thanks for your help.
