Need guidance for Klipsch home theater setup - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Is Klipsch home theater in a box better than customized Klipsch setup
Yes 0 0%
No 2 66.67%
Highly Recommended 0 0%
Customization is much better 1 33.33%
Depends on budget 0 0%
Customization gives better options 2 66.67%
Home theater in a box is a better deal 0 0%
Home theater is steal-a-deal 0 0%
Better options available thank Klipsch in the same budget 0 0%
Klipsh is bang for buck whether customized or in box 0 0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
post #1 of 3 Old 04-13-2015, 01:51 PM - Thread Starter
Quoted: 265 Post(s)
Liked: 155
Hi,
Reaching out to all the enthusiasts and experts of home theater setups. Need your guidance regarding the Klipsch setup I'm planning to buy with the following configurations...
Sub Woofer- R-112SW
Center Speaker- RP-450C
Surround- RS-52 II
Bookshelf- RB-51 II
Receiver- Yamaha RX-V677 7.2-channel Wi-Fi Network AV Receiver with AirPlay
Please suggest if this is a good setup to go with or should I make changes to any of the above. My end goal is to have maximum clarity with all the details and at the same time have deep bass which is crisp (not loud and distorted).
Any ideas, comments, suggestion & feedback is welcome.
P.S.- It's going to be my first home theater setup. So want to get the best considering I can't go over $3,00 including installation.
Matrixman18 is offline
post #2 of 3 Old 04-14-2015, 06:18 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 43
Seems just a bit unbalanced to me. Everything is pretty well matched, but the bookshelves for the L+R seem to be weak in comparison with the center.
jayn_j is offline
post #3 of 3 Old 04-14-2015, 11:06 AM - Thread Starter
Quoted: 265 Post(s)
Liked: 155
Thanks for the feedback. What do you recommend? Please share your thoughts.
I can pick any of the following...RP-150M Monitor Speaker or RB-61 II Bookshelf Speakers or RB-81 II Bookshelf Speaker.
Home Theater , Klipsch , Klipsch Audio , klipsch sub , klipsch surround
