Looking for 80-90 inch wide and nice-looking TV stand for Family Room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-20-2016, 05:32 PM - Thread Starter
Upgrader's Avatar
Quoted: 38 Post(s)
Hello guys,
I am looking everywhere for a nice-looking stand for our 75" LaserVue TV in our family room (it weighs 154 pounds). I found this one made by Salamander which lists for $2000
http://www.salamanderdesigns.com/pro...1-5125e21e32e7
This one is 87 inches long with a large opening under the top for a center channel which is great. However, reviews have been all over the place for it with complaints that include assembly issues and missing parts.
What other choices for nice-looking TV stands are there in the 80-90 inch width range? I am looking to spend up to $2500 for the right stand ... and that's not because I got money coming out of my rear but because of the WAF. BTW, doing a straight-up google search for this brings up many choices but they are either undersized, do not have a large-enough opening for the center speaker, or they were rated down-right ugly as rated by the wife.
I am sure those of you who have setup AV systems in your family rooms or living rooms have been challenged with this problem. Please let me know what you went with. Thank you.
Upgrader is offline
post #2 of 7 Old 02-21-2016, 08:29 AM
JoeAngelicchio's Avatar
Originally Posted by Upgrader View Post
Hello guys,
Might be a little out of the price range.
http://www.standoutdesigns.com/colle...x-82-inch-wide
Joe
Joe
JoeAngelicchio is offline
post #3 of 7 Old 02-22-2016, 10:28 AM
I spent a LONG time looking for something that would work as well (in the same situation).
I ended up landing on this, for about 2 grand.
So far I'm loving it, and even fit my center channel Elusive 1099 in the middle after removing the shelf!
I'll try to post pics soon.
It comes in two colors.
http://www.modernessentials.com/BDI-...FZSEaQod97wAAQ
Oldcabin is offline
post #4 of 7 Old 02-22-2016, 10:11 PM - Thread Starter
Upgrader's Avatar
Quoted: 38 Post(s)
Unhappy
Joe
Thank you Joe, this one looks very nice. We are going with the Espresso finish and after adding some of their options we are at just about 3 grand. It's a shame you can't find a furniture-class TV stand for less.
Upgrader is offline
post #5 of 7 Old 02-24-2016, 01:13 PM
Liked: 2
It sounds like you may have already made your decision, but if you're still looking for options I would recommend BDI's products.
I've had the Avion 8929 for about 5 years. It has a clean, modern design that should help the WAF. In my experience it as been durable both under normal everyday use and one long distance move. It has a cabinet with built in mesh to accommodate a center speaker (depending on your speaker size). At 77", it's a little under your specified requirements but still close.
https://www.bdiusa.com/media-furnitu...l#.Vs4LdfIrKCg
The Signal series is 79.25"
https://www.bdiusa.com/media-furnitu...l#.Vs4N6fIrKCh
https://www.bdiusa.com/media-furnitu...l#.Vs4NqfIrKCg
The Vertica 8559 is 79"
https://www.bdiusa.com/media-furnitu...l#.Vs4OFvIrKCg
All of these can be found for under $2000 at everyday prices and even lower during store sales.
Mansfieldstake is offline
post #6 of 7 Old 02-24-2016, 01:22 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5757 Post(s)
Liked: 11568
Another option would be to have something made locally by a good cabinet maker. I found one through a local audio store who made me a very nice cabinet, to my specifications, with the shelves I wanted, in a piano black finish, for a few hundred dollars. This was for a 200lb, 92" Mitsubishi DLP. Just another option to consider.
Spending a couple of thousand dollars on a cabinet can be a great move furniture-wise, but not so great from an AV standpoint. I have found myself adding and changing equipment over the years, and even with flexible shelving, it can be a challenge. But, if necessary, I can always have another cabinet/stand made.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #7 of 7 Old 02-24-2016, 06:00 PM
bluer101's Avatar
Quoted: 651 Post(s)
Liked: 800
I could not find anything reasonable priced or for my equipment either. I ended up building my own instead. I have now changed out some equipment with no issues too.
https://www.avsforum.com/forum/15-gen...ole-build.html
bluer101 is offline
