How many HDMI cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-20-2017, 10:39 AM - Thread Starter
Liked: 0
Unfortunately I was only able to use a fish tape to get one HDMI cable behind a rock fireplace where I have a tv mounted along with a cat 6 and cable. I'm afraid if I try to attempt another ill damage what I have, how many hdmi cables is enough? The run to my media room is about 40' and the only thing I'm gonna have on the Rock fireplace is the tv, all components,network switch, roku, nas, plex, etc, will be in media room, I saw they have hdmi splitters etc,
Can I use a device in media room to send media down a single hdmi cable to the tv
Alaska_av8r is offline
post #2 of 15 Old 02-20-2017, 11:40 AM
mbarland's Avatar
Quoted: 93 Post(s)
Liked: 54
Yes. Any HDMI audio video receiver or HDMI switch can do this for you. In fact, it's my preference to switch the signal at the AVR or otherwise before the TV. TV should just be a monitor.
mbarland is offline
post #3 of 15 Old 02-20-2017, 12:04 PM - Thread Starter
Liked: 0
Ty very much that keeps my life much simpler
post #4 of 15 Old 02-21-2017, 05:59 PM
FrankTR's Avatar
Quoted: 46 Post(s)
Interesting subject. Just starting the process to have a house built and in discussion with the construction supervisor we discussed my request to have HDMI cables in the walls. They stated they never do that but use CAT 6 to the location and use a short HDMI cable to the unit? Is this the norm?
FrankTR is offline
post #5 of 15 Old 02-17-2019, 04:18 PM - Thread Starter
Liked: 0
Frank I don't know the answer to that but i did find out that using a splitter on my HDMI cable to switch inputs to the TV does not work with direct tv, the splitter does not pass on some part of the signal so the tv doesn't show direct tv. I am sure it is used in some way to prevent people from splitting direct tv signal to two tv's or something along those line.....
post #6 of 15 Old 02-28-2019, 11:48 AM
GoZags13's Avatar
Quoted: 174 Post(s)
Liked: 90
Couple quick things to consider.
1 - hdmi cables can fail (and also will become obsolete), while CAT6 is going to last and will always have someone making a converter/adaptor.
2 - on a long run like 40', you want to get a high quality HDMI cord. There are some really good articles and tests that'll show you brands that will pass 4K. You probably want to go with a copper/fiber cable.
3 - there are HDMI transmitters that will do 4K. These are coming down in cost and it might be easier/better to do this than buy an expensive HDMI cable.
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
post #7 of 15 Old 02-28-2019, 03:50 PM
bofa89's Avatar
Quoted: 65 Post(s)
Liked: 42
My AV guy used HDMI's. The key really is to have the flexible conduit so you can easily replace wires, then all you need is a metal fish tape to run whatever you want.
bofa89 is offline
post #8 of 15 Old 02-28-2019, 04:20 PM
FrankTR's Avatar
Quoted: 46 Post(s)
Thanks that is what happened except in one wall they did a S turn had to cut a hole in the wall to get the fish tape through
FrankTR is offline
post #9 of 15 Old 03-01-2019, 08:31 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 324 Post(s)
Liked: 114
It's pretty common to run a "pull" string with the cable making it easier to install additional cables. To replace a bad cable you can either use the pull string or tie the new one to the old pulling out the old as you're pulling in the new.
kjfalls is offline
post #10 of 15 Old 03-01-2019, 02:47 PM
bofa89's Avatar
Quoted: 65 Post(s)
Liked: 42
Wow, thats unreal, I would have made the guys that installed the tubing come back and run a pull string once I found out I couldn't.
They forgot to do pull strings on mine even though I requested it but it only took me 2 minutes to do with a tape.
bofa89 is offline
post #11 of 15 Old 03-01-2019, 04:00 PM
FrankTR's Avatar
Quoted: 46 Post(s)
I had the electric company here when I cut the hole. The tech could not believe the S turn. I saw the S turn but did not think it would be a problem. I patched the hole and it is the wall behind the screen so it got covered in insulation. The tube going from the living room closet to the patio had the string stuck in the tube it could not be reached but the fish worked fine. I wish I had realized there was no string in the tubes before I had the sheet rock installed.
FrankTR is offline
post #12 of 15 Old 03-01-2019, 04:10 PM
Neurorad's Avatar
Quoted: 279 Post(s)
Liked: 155
A vacuum usually does the trick for pulling a new string (attached to a balled up plastic garbage bag) through conduit, but that would be a cool tool.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #13 of 15 Old 03-02-2019, 05:28 AM
bofa89's Avatar
Quoted: 65 Post(s)
Liked: 42
Originally Posted by Neurorad View Post
https://www.youtube.com/watch?v=Gk65uV_gRlc
Thats always a great idea, I was going to use that, it will always work on an unfinished room but once you have drywall up and the tube is behind a plate, its pretty much impossible to get a hose on it to get suction.
bofa89 is offline
post #14 of 15 Old 03-07-2019, 01:29 PM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
Did you use a splitter or an actual HDMI switch? The switches are more robust and should work for you.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #15 of 15 Old 03-07-2019, 01:31 PM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
Duct tape is your friend here.
The string tied to the bag thing will work as long as the bag doesn't get stuck somewhere in the middle and the string pulls off.
Not that I know anything about that from experience. I'm just sayin'.
Tom Logan
