ISO TV mount w/ 47" horizontal motion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2017, 07:14 PM - Thread Starter
sdesiano's Avatar
Question ISO TV mount w/ 47" horizontal motion
[edited 10/7 to be far less mathy and focus on wall]
tl;dr I am looking for a wall mount that will let me move and rotate a TV between two viewing positions 47" and 40° apart.
I have a 9 month old and I need to get my TV off its stand (picture 3). Ideally, it would be able to sit stably in two positions -- in the corner of the room (blue position in picture 4) and in front of the pocket door (red position). I have no idea if such a mount even exists -- putting 70 pounds on an arm that has to be at least two feet long and hang off of a wall seems pretty insane to me.
All told, I'm looking for something that:
  • Supports a 65", 70lb television.
  • Holds the TV 26" off of the floor.
  • Is stable in two positions (see picture #4):
    • Blue: In the corner (21" out from the wall, 0" horizontal from the mount, 40° relative to the wall)
    • Red: Across the doorway (0" out, 47" horizontal, parallel to wall)
Worth noting:
  • The wall is not solid; the pocket door slides into it.
  • I'd rather not completely destroy the wall.
  • I'd be open to building something, but I'd much rather buy.
  • It would be awesome if it could also allow the TV to face the doorway, but that's just a dream.
Does this kind of thing exist?
-- Sal
smile.
ID:	2294004   Click image for larger version
ID:	2294006   Click image for larger version
ID:	2294008   Click image for larger version
Name:	Screen Shot 2017-10-07 at 8.56.35 AM.png
sdesiano is offline
post #2 of 2 Old 10-07-2017, 08:27 AM
airscapes's Avatar
Quoted: 496 Post(s)
Liked: 415
not sure exactly what you are looking for, your description is a bit to technical for me.
However I have a TV in a similar location using a Chief mount (very expensive but built to last decades).
This is probably the one you would need but please, call their tech support, they were very helpful in making sure i got the proper mount.
http://www.chiefmfg.com/Series/PDR
Picture of my install Livingroom update
My IP had change and I just fixed it.. the above link may take an hour or so to work, just try back if it does not function now.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
mount , stand , television
