A/V rack options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-12-2018, 08:28 AM - Thread Starter
soccerTOOLsu's Avatar
Quoted: 14 Post(s)
A/V rack options
Has anybody here ever used a Tripp Lite rack to mount A/V equipment in living room? Seems like a cheap option for mounting and just need to add shelves to put equipment on.
What are your thoughts? I did a search and looks like some people have used them but only in dedicated a/v rooms or closets. Here are the rack's I'm looking at.
https://www.tripplite.com/42u-smartr...~SR42UBMDEXPND
or
https://www.tripplite.com/42u-smartr...s~SR42UBSD1032
soccerTOOLsu is offline
post #2 of 5 Old 04-12-2018, 01:43 PM
Neurorad's Avatar
Quoted: 293 Post(s)
Liked: 163
Not cheap, no. Tripp Lite is about the same cost as most rack manufacturers. The side panels, front door, shelves, casters, and screws add up fast.
For a living room, and not in a closet, there are nicer-looking racks - Middle Atlantic RCS and Sanus Component Series, for budget options.
My living room rack looks much like this, a Middle Atlantic BRK20 (black laminate rack, 20U)
Keep the depth of the rack in mind - you linked to racks that are 32" and 36" deep, way deeper than is useful.
Read through the 'Show me your rack' thread, for some good ideas https://www.avsforum.com/forum/19-ded...your-rack.html
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 5 Old 04-13-2018, 05:32 AM - Thread Starter
Quoted: 14 Post(s)
Yes, I've noticed Tripp Lite is much deeper and the shelves cost $88 to $123 each. Thank you for the information on the alternatives.
post #4 of 5 Old 04-17-2018, 02:52 PM
Bacon13's Avatar
Quoted: 31 Post(s)
Liked: 49
If you are using shelves for your equipment and not rack-mounting them, then why would you use a rack and not a residential equipment stand that has built in shelves?
Bacon13 is offline
post #5 of 5 Old 04-29-2018, 04:20 AM
Tedd's Avatar
Quoted: 2292 Post(s)
Liked: 982
I think he meant steel shelves.
Tedd is offline
