Help with planning placement of 7.2.4 setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-25-2018, 08:28 PM - Thread Starter
Liked: 4
I have a new construction going up and I am getting pre-wires put in for a 7.4.2 setup.
I am hoping to get help in deciding how I need to space this out as this is my first going through this process.
The room itself is 21ft by 14ft 9in.
All of my equipment will be purchased new but as of right now this is what I currently have in mind.
Projector : BenQ HT2550 - 120" Screen
Ceiling Speakers : Kplisch DS-160C x4 (pre-installed can change later)
Rears : Flaunce XLBP x4
Fronts : Not Really Sure Yet
Subwoofer : Not Really Sure Yet
Receiver : Marantz 9.2 (will add an amp later)
The goal is to be up and running with 5.2.4 the day I move in and add an amp and the other 2 rears down the road.
From the image.
Couch will be about 10 ft from the front wall with the 120" Screen
Ceiling speakers will be about 7 ft from the front wall with 6 ft between the 1st and 2nd row.
Making them sit 3ft in front and behind the couch and roughly 8ft between then left to right.
Now I am not opposed to spreading this out along the length of the room I just don't know if that would make it feel better or worse.
StampedAurean is offline
post #2 of 6 Old 06-28-2018, 09:21 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
you want your atmos ideally at a 45 degree vertical angle between ceiling to your ears, and then aligned with your front L/R see here:
https://www.dolby.com/us/en/guide/do...-4-setups.html
in summary, calculate the distance between your ears and the ceiling, and assuming your atmos will be flush installed into the ceiling, the distance in front of and behind your seating area that the atmos speakers should be is equal to the distance from ceiling to your ears.
as an example, if your ceiling is 8ft tall and your ears are 3ft (36") up from the ground, that's 5ft from ceiling to ears. thus your front row of atmos speakers should be 5ft ahead of your seating position and the rear row should be 5ft behind your seating position. the left speakers should generally be in-line with your front left speaker and similarly for the 2 right atmos speakers and your right front channel.
From the image.
rukus29 is offline
post #3 of 6 Old 06-28-2018, 09:40 AM
RayOnTheRun's Avatar
Quoted: 17 Post(s)
Liked: 7
I don't think even Dolby knows! Their own documentation contradicts itself. On page 8 and 9 it states that it goes inside the surrounds at .5 to .7 x W. Ok. But then the images all over the internet for a 7.1.4 setup (p. 26) shows the rear speakers inside and close to the Atmos speakers?!?!
I did it with the rears inside because that is what my room allowed but now I'm not sure what is the correct standard.
Thanks a lot guys!!
RayOnTheRun is offline
post #4 of 6 Old 06-28-2018, 10:59 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Thanks a lot guys!!
i think a bit depends how far away your surrounds are from the MLP, since that changes the angles that the surrounds present to the MLP - the further the surrounds are from the MLP, the 'wider' they will need to be to get back to the same angles relative to the MLP that surrounds closer to the MLP might present. i think i have always seen atmos specified as being aligned with the fronts though, not specified in relation to the surrounds.
rukus29 is offline
post #5 of 6 Old 06-29-2018, 02:31 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3522 Post(s)
Liked: 1639
So much depends upon the dispersion characteristics of the Speakers used that any discussion "before" a choice is made is premature.
If you stay with Klispch, you can get models that have Tweeters that have adjustable angles. Other Mfg also have pivoting Woofers as well, and as such are preferred.
Before the choice is made, at best one can only make assumptions based on what would be ideally suited. You stated you already have 4 Klispch installed...and those units do not have any directional adjustment.
MississippiMan is online now
post #6 of 6 Old 06-29-2018, 11:22 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
generally agree with MMAn - but i would qualify that and say i would choose equipment/speakers that allow me to place them at the optimal locations if possible, ie atmos speakers in the ideal locations would require very good dispersion or aimable tweeters per MMan's comments above. choosing non-aimable speakers or narrow dispersion speakers and then being forced to move them significantly outside ideal locations just to deal with those shortfalls is a bit silly if you ask me!
rukus29 is offline
