Pantry/AV closet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-03-2018, 10:55 PM - Thread Starter
northernlights's Avatar
Pantry/AV closet
So I need help with some ideas on how to clean up this mess of cables/power cords and devices. Thats a cable modem, apple router, small switch and network drive with lots of cable splitting going on there. Any products out there that can harmonize this?
northernlights is offline
post #2 of 5 Old 10-05-2018, 07:20 AM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 317
There are a few products out there for cable management.
I know this might sound goofy but when I seen you say it was in a pantry my first thought was cereal boxes with the cables coming in and out of.... cheep easy and falls in the pantry "theme"
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #3 of 5 Old 10-05-2018, 11:40 AM - Thread Starter
There are usually cheetos and cereal boxes there. Any links to cable management?
post #4 of 5 Old 10-05-2018, 11:59 AM
mattztt's Avatar
Quoted: 371 Post(s)
Liked: 376
For that collection of gear I would just do a quick cleanup like so:
1. Remove all connectors from devices so you can move them freely.
2. Attach power strip securely at the back of the shelf (secure to the shelf, the bottom of the shelf above it, or the wall - whatever you like)
3. Place devices neatly on the shelf or two in a way that is pleasing to you and allows for access to the cables without too much difficulty. If a device allows hard mounting (the switch probably does), consider securing it to the shelf.
4. Attach one cord at a time to each device, coiling any extra cable and securing it with Velcro wraps.
I would also consider adding a vertical piece of wood to the shelf with the gear to separate it from the Cheetos and cereal.
mattztt is offline
post #5 of 5 Old 10-05-2018, 01:42 PM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 317
https://www.cabletiesandmore.ca/cabl...IaAqZWEALw_wcB
Family Cave Theater
