Finding someone for home theater consultation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-05-2019, 05:03 PM - Thread Starter
AveryN's Avatar
Hi,
I'm in the middle of a remodel of my home and going to be installing a multi-purpose room with a projector based home theater.
About 10 years ago I setup a similar room in my prior house, and it took a lot of research and time to get it right. Given I'm doing most of the remodel myself, I'm looking to save some of that research time by finding someone who knows these types of home theater setups well and can consult for a few hours. Specifically, determining options for using my space with my seating placement, projector screen size and placement, projector selection and placement for my particular needs, and the same for speakers. It would be nice, but not necessary, if they can also speak to to any nice features that should be included during construction.
I live in Colorado, and am open to finding someone really good who can do this remotely (or open to someone local). I'm not really looking for someone who is looking to sell an install or equipment, rather a guru who has deep working knowledge in home theater and does consulting. I'm already over budget on the project, so budget minded, but do not want to cut corners.
What's the best way to locate someone like this?
Avery
To give an idea of the project and space, here's the plan I had started some time back:
AveryN is offline
post #2 of 2 Old 03-07-2019, 10:51 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
Try a PM to BigMouthinDC, if you haven't already. Tell him I sent you.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
