Should I move my 65" down? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-07-2019, 08:43 PM - Thread Starter
mbuck's Avatar
Quoted: 30 Post(s)
Just upgraded from 55" to 65"...is this too high?
mbuck is offline
post #2 of 14 Old 04-07-2019, 09:07 PM
woodgieroo's Avatar
Quoted: 101 Post(s)
Liked: 53
Is that where the 55" was?
My 47" is above the fireplace and while it might be a bit high for couch viewing, it's great from across the room in the kitchen.
woodgieroo is offline
post #3 of 14 Old 04-07-2019, 09:23 PM
Shadowed's Avatar
Quoted: 952 Post(s)
Liked: 912
Depends if you are reclined while watching or not.
Shadowed is offline
post #4 of 14 Old 04-08-2019, 03:10 AM
Aberk's Avatar
Quoted: 289 Post(s)
Liked: 188
Aesthetically, I'd move it down just enough so it is a bit below the crown molding.
Aberk is online now
post #5 of 14 Old 04-08-2019, 06:04 AM - Thread Starter
mbuck's Avatar
Quoted: 30 Post(s)
It is. I’m just questioning if it’s worth moving the whole thing down 2-3” to be closer to eye level. I’d have to reinstall the entire mount on the wall...not looking forward to that.
mbuck is offline
post #6 of 14 Old 04-08-2019, 06:06 AM - Thread Starter
mbuck's Avatar
Quoted: 30 Post(s)
Agreed, but that means reinstalling the entire mount to the wall, not a huge task, but not small for someone less than handy with that sort of thing.
I may keep it for now until I dig in to recess the power behind the tv.
mbuck is offline
post #7 of 14 Old 04-10-2019, 05:15 PM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
I would move it down as low as you can without the IR sensor of the TV being blocked by the soundbar.
And a vertical shift of the mount shouldn't be hard at all.
1. If you can shift the vertical bars attached to the TV up as much as possible, that's the easiest way to drop the TV lower.
2. Take the TV off the wall plate. Remove screws and take the wall plate off. Grab a ruler and/or level and mark holes a couple inches below the existing top screw holes. Remount the wall plate. Top screws first, then just add the bottom screws where they went before. Put TV back up.
Sent from my SM-N960U1 using Tapatalk
dbpaddler is offline
post #8 of 14 Old 04-16-2019, 06:25 AM
Liked: 0
I would move it down. Also check out www.mantelmount.com they have a mount that works perfectly for this application. I have used them several times. The mount allows the TV to be pulled down when being used and returned to its normal position when not in use.
ID:	2553662   Click image for larger version
Jason Maguire is offline
post #9 of 14 Old 04-16-2019, 05:33 PM
Jive Turkey's Avatar
Quoted: 582 Post(s)
Liked: 460
In my life, there will never be a TV over a fireplace. It's too high for comfortable viewing in my opinion, and too far off axis.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #10 of 14 Old 04-16-2019, 06:09 PM
Steve Sleeve's Avatar
Quoted: 84 Post(s)
Liked: 32
It will have a long life there and lot of viewing time, won't be long to change don't be lazy make it perfet . Also clean up those wires, Wires hanging from flat screens drive me crazy, get those in the wall or re routed for a nice clean look.
Denon AVR-X6500h Klipsch RP-8000f RP-440C (4) RP-150MS sides in parallel RB-51 rears, 4 JBL C67P pendants for atmos, 2 monolith 12" subs
Epson 5040UB, Sony Ubp-X700, AC infintiy T9, Nvidia Shield, 142" 2.35 silver ticket screen
Steve Sleeve is offline
post #11 of 14 Old 04-16-2019, 06:49 PM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
If it's the primary viewing area I could agree. If not. Who cares? Aesthetics wins then. With open floor plans locating a TV can be tough. I'm putting my LR TV above the mantle. Haven't put the mantle in yet so I have options for height. I also put in wall speakers above it that are tilted, so it's its own media area and the only place for a TV in the room.
If I want the perfect viewing height, I go up to the theater room.
post #12 of 14 Old 04-17-2019, 04:47 PM
Quoted: 582 Post(s)
Liked: 460
I just have never been able to get used to looking up at TV's in family and friends homes. It bothers my neck after a short period and often requires almost laying down in a couch or chair to offset that. I prefer a TV stand mounted with the top of my head at about center screen height (65" OLED, in my case).
See ya. Dave
post #13 of 14 Old 04-17-2019, 04:55 PM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
Move it down as low as possible.
spyboy is online now
post #14 of 14 Old 04-17-2019, 05:19 PM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
Well some do have ridiculously high mantels, and there's just no way around it. I just mounted a soundbar to a TV at this one house, and they opted to mount the TV on the wall to the right of fireplace with an articulating arm so they can move it. It pushed their viewing distance back a bit. And I probably would have jumped the screen size up 70 or 75 at that point since it's already taking over that wall, and is their main viewing room. But wasn't my place to suggest.
While I like the idea of mantle mounts, when up the TV looks like it sits so far away from the wall. But everyone's room is different. You do the off center TV location and you pretty much need a sectional or sofa love seat to have close to an ideal seating position. And if you're trying to do surround sound it can complicate the setup as well.
