Connecting my projector to a sliding mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-06-2019, 06:38 AM - Thread Starter
Liked: 0
Hi I saw people posted telling someone to email about putting a projector on the ceiling where you could slide it, but I couldn’t DM anyone.
Can someone help point me in the right direction? I want to mount my projector on a track of some sort only one axis so that I can hide it away when it’s not in use. I was looking at using a track from track lightning or something like that but I don’t know if that will hold the projector or if a mount will connect to it.
Any ideas? I’m using an Optoma HD143X.
Would appreciate any help.
Kenny Idan Rub is offline
post #2 of 7 Old 05-06-2019, 08:00 AM
bud16415's Avatar
Quoted: 2171 Post(s)
Liked: 1097
I track mounted my projector but for a different reason. Mine is to extend the zoom range so I can use my projector for variable image sizes and brightness issues.
It shouldn’t be too hard to find a track to do what you want but even when you hide the projector the track will still be in view.
Here is a thread about mine.
https://www.avsforum.com/forum/68-di...on-method.html
Bud
bud16415 is offline
post #3 of 7 Old 05-06-2019, 10:34 AM - Thread Starter
Liked: 0
I saw your thread and your track being so visible is why I’m looking for a different option. I wanted something much more subtle like the picture attached. Is there a projector mount that could attach into this? Then I’d just slide it back and forth?
post #4 of 7 Old 05-07-2019, 09:43 AM
ckronengold's Avatar
Quoted: 303 Post(s)
Liked: 123
I would be very concerned hanging a projector and a mount from a track that "light weight."
Video: Epson 5050 / nVidia Shield / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #5 of 7 Old 05-09-2019, 12:10 PM
Sonyad's Avatar
Quoted: 247 Post(s)
Liked: 140
This would be a proper track https://www.bhphotovideo.com/c/produ...ing_Plate.html
Sonyad is offline
post #6 of 7 Old 05-10-2019, 09:56 AM
bud16415's Avatar
Liked: 1097
There are any number of tracks and they all have different weight capacities.
Unistrut is one such company and 80/20 Inc. is another. Google will show you their building block components you can buy.
Google ceiling tracks and you will find many more. Some are made to hold the weight of a person.
I wanted my track system to make a statement in the room or at least I wasn’t trying to hide it. It is a dedicated projection room that is also a place to do other activities so it doesn’t bother me showing off the equipment. I do understand others might want something trying to blend into the room and not look like a projector rig. Mine is more pronounced because it is inclined to cause an image height change at the same time it is causing a size change. I’m sure I could design something to do that and not show in the room but it would be more complex and cost as much as a projector that had those functions built in.
Bud
bud16415 is offline
post #7 of 7 Old 05-10-2019, 03:16 PM
bpape's Avatar
Send a message via AIM to bpape
https://www.homedepot.com/p/Everbilt...ZP-W/302867516
Pending the projector depth, where it is wired, etc., they make several different lengths. These are rated to 50 lbs.
I am serious...and don't call me Shirley.
Owner - Sensible Sound Solutions
bpape is offline
