Accoustics treatment suggestions for small home theatre - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-14-2019, 05:57 AM - Thread Starter
patoberli's Avatar
Quoted: 155 Post(s)
Liked: 62
Send a message via Skype™ to patoberli
Question Accoustics treatment suggestions for small home theatre
Hello all
I recently moved into a new flat and moved all my audio/video equipment with me. I have built a small home cinema, which I also use for gaming and everything else.
To the room, all walls are drywall, the roof is 2.4 meters high and made of drywall on top of concrete. The floor is wooden tiles.
So I would say I have the most horrible acoustic room possible here, but that can't be changed.
Anyway, on the left side of my seating position are lots of windows (each around 60 cm wide, frame, then the next window).
Speakers are tuned with Audyssey build into my Denon X4300H AVR. I have one sub plus various speakers. It's actually a 7.1.4 Atmos system, but I didn't add the Atmos speakers to my drawing.
As you can guess, the sound is currently far from great and I also have a bit of echo in the room.
I'm considering currently some sound absorbing curtains (with an NRC of 0.75), which will at least should help with > 350 Hz.
I though about adding some absorbers to the rear wall, because there is nothing else currently there, just a flat, white wall.
Important, if I add something, it must look like it fits into a living room
Anyway, suggestions / ideas?
Patrick
patoberli is offline
post #2 of 3 Old 05-15-2019, 12:08 PM
bpape's Avatar
Send a message via AIM to bpape
I would swap the left speaker and sub position to provide better symmetry and get the left out of the corner. Bass traps in both left side corners given the open space on the other side. If tolerable, some thicker panels with a membrane on them centered on the wall behind you to help with rear wall cancellations and help with the overall decay time in the room. What do you have over the windows? curtains? Shades? Blinds? Nothing?
I am serious...and don't call me Shirley.
Owner - Sensible Sound Solutions
bpape is offline
post #3 of 3 Old 05-16-2019, 01:20 AM - Thread Starter
patoberli's Avatar
Quoted: 155 Post(s)
Liked: 62
Thanks for the inputs. You think along the same lines as I do
At the moment, there is nothing covering the windows, but I've just ordered some semi-transparent acoustic curtains, which should at least reduce the echo somewhat. They have a NRC (ASTM C423, ISO 354) of 0.75 or SAA 0.77. They offer 0.62 @315 Hz and > 0.87 @500 Hz. The curtain is the Creation Baumann MEGACOUSTIC model.
The subwoofer actually sounded a tad better when I had it at the current position instead of the corner, which is why it's currently standing there.
For the rear wall, would you rather got for bass traps style panels or the somewhat slimmer higher frequency ones? I tend to get something like this, as they are fairly good available here in Switzerland:
https://artnovion.com/product-catego...agad-bass-trap
https://artnovion.com/product-catego...andes-absorber
If you know of cheaper/better products for here in Europe, I'm open for suggestions.
