Avrak? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-16-2019, 09:32 AM - Thread Starter
Liked: 0
Avrak?
I have an Avrak shelving system and want to update it, but I can't find Avrak on the web except for an Australian web page. Are they still in business here? They had a wonderful system that, so far as I know, no one else makes.
Any help would be appreciated.
[email protected] is offline
post #2 of 7 Old 06-17-2019, 03:36 AM
Tedd's Avatar
Quoted: 2037 Post(s)
Liked: 827
Tedd is offline
post #3 of 7 Old 06-17-2019, 07:34 AM - Thread Starter
Liked: 0
Thanks. I've seen this. Unfortunately, that's from 2014 and I can't find anything on the web that would enable me to contact them and order upgrades to my shelving. They seem to have just disappeared.
post #4 of 7 Old 06-17-2019, 07:39 AM
Tedd's Avatar
Liked: 827
Now that I know exactly what rack we are talking about...
What upgrades, and do you need to be limited to oem shelves? You might clone shelves, either by DIY, or see what a cabinet shop would charge.
One shelf would pride you with a template.
Or you might put in an Ebay search, and see if any cheap units come up, that would give you what you need.
Tedd is offline
post #5 of 7 Old 06-17-2019, 07:46 AM - Thread Starter
Liked: 0
Tedd, I guess the answer is that they have folded their tents and gone into that good night. Really a shame because it was such a useful and novel product.
post #6 of 7 Old 06-17-2019, 08:03 AM
Tedd's Avatar
Liked: 827
I owned one for awhile, but even if they have disappeared, I would build shelves or whatever is needed, if the AVRAK is in good shape.
I have moved on to Middle Atlantic av racks, but I often whip up something custom for them, using a $10 Harbor Freight 4" angle grinder,
and some rattle can spray paint.
Tedd is offline
post #7 of 7 Old 06-21-2019, 04:11 PM
Tedd's Avatar
Liked: 827
Tedd is offline
