Raising my rack! - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By garygreyh
  • 1 Post By bluer101
  • 1 Post By Screamin
post #1 of 10 Old 06-26-2019, 12:40 PM - Thread Starter
Screamin's Avatar
Raising my rack!
Hey all,
Looking at a 28U rack for my A/V closet! I want to get it up off the floor, but I don't want to permanently install it unless I have to. Do you guys have any ideas to get the rack up off the ground?
Originally Posted by paddlefoot
When it is in your house, it will look like the best tv ever made.
Screamin is offline
post #2 of 10 Old 06-26-2019, 12:49 PM
Quoted: 98 Post(s)
Liked: 196
Originally Posted by Screamin View Post
Hey all,
How far off the ground are you trying to raise it?
garygreyh is offline
post #3 of 10 Old 06-26-2019, 01:12 PM - Thread Starter
Screamin's Avatar
Looking to get 3-4 feet off the ground. The "easiest" solution would be to get a full 42U rack, but my closet is 30" wide by 24" deep. I only have about 80" in height to work with.
Screamin is offline
post #4 of 10 Old 06-27-2019, 09:28 AM
Quoted: 98 Post(s)
Liked: 196
Not sure how elaborate this needs to be. I'd probably build a frame out of 2X4s, put plywood or MDF panels on the top and sides, paint it black and call it a day.
Screamin likes this.
post #5 of 10 Old 06-27-2019, 09:34 AM - Thread Starter
Screamin's Avatar
Thank you sir! I was honestly thinking about doing this, but I wondered if someone else had a different brilliant idea ;-)
Screamin is offline
post #6 of 10 Old 06-27-2019, 09:41 AM
Quoted: 98 Post(s)
Liked: 196
I'll admit there's nothing "brilliant" about the idea, but sometimes "crude but effective" is the way to go. LOL.
Good luck with it.
post #7 of 10 Old 06-28-2019, 07:28 AM
ckronengold's Avatar
Quoted: 272 Post(s)
Liked: 111
Taking the 'crude but effective' approach (which is, admittedly, F'in brilliant) you could also just build a stand and then put something like this on top of it. Maybe they make a bigger one?
https://www.amazon.com/gp/product/B01LX9GU6H/
Video: Epson 5050 / nVidia Shield / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #8 of 10 Old 06-28-2019, 11:02 AM
Neurorad's Avatar
Quoted: 280 Post(s)
Liked: 157
How about a 35U rack?
https://www.middleatlantic.com/produ.../rcs-3524.aspx
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #9 of 10 Old 06-28-2019, 12:26 PM
bluer101's Avatar
Quoted: 636 Post(s)
Liked: 733
I built my rack into a hall closet using plywood and 42u rack rails.
ID:	2585306   Click image for larger version
Boxozaxu likes this.
bluer101 is offline
post #10 of 10 Old 07-01-2019, 10:38 AM - Thread Starter
Screamin's Avatar
You guys are great for inspiration!
I ended up finding a used 42U rack that tops out at 78", so I'm gonna JUST be able to squeeze it into my AV closet (don't worry, the back is open so I'll be rear venting)!
bluer101 likes this.
Screamin is offline
