Blackout curtains? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By toddwz
  • 1 Post By shivaji
post #1 of 11 Old 07-29-2019, 07:39 AM - Thread Starter
xp0z3d's Avatar
Quoted: 79 Post(s)
Blackout curtains?
I have an HT space in the loft. On the right side, there is an opening down to foyer which brings in a lot of light during the day. To counter this, I have installed a ceiling track to put on some blackout curtains. During this, I ended up putting this track on the whole right side which is almost 5 meters in length, and then decided to go ahead and added another 5-meter track at the back of the room to block out the windows completely. Now I need some good and cheap blackout curtains to run on this track to make the room completely dark during the day.
I was wondering what curtains to buy which won`t break the bank. I would need 10 meters of length and height can be around 3 meters. And in inches, it will be 393 inches in length and 120 inches in height.
Please suggest some blackout curtains?
xp0z3d is offline
post #2 of 11 Old 07-29-2019, 11:55 AM
toddwz's Avatar
Quoted: 58 Post(s)
Liked: 32
If you're in US, you may consider https://www.amazon.com/gp/product/B07DPGFMNB. Return seems easy (a visit to Kohl's.) You needs 10 feet high so you may need to be creative.
Or https://syfabrics.com/collections/ve...triple-velvet1 and DIY.
xp0z3d likes this.
toddwz is offline
post #3 of 11 Old 07-30-2019, 05:29 AM - Thread Starter
xp0z3d's Avatar
Quoted: 79 Post(s)
First one looks good, but with a rod, I do not know how I will make it work with a ceiling track.
xp0z3d is offline
post #4 of 11 Old 07-30-2019, 06:19 AM
shivaji's Avatar
Quoted: 1355 Post(s)
Liked: 1390
Ikea sells blackout curtains, but it appears to be only in 98" lengths.
https://www.ikea.com/ms/en_US/usearc...out%20curtains
xp0z3d likes this.
shivaji is offline
post #5 of 11 Old 07-30-2019, 09:12 AM
toddwz's Avatar
Quoted: 58 Post(s)
Liked: 32
What kind of ceiling track do you have? For https://www.amazon.com/dp/B01B15K48K, you can just hang the curtain, right?
toddwz is offline
post #6 of 11 Old 07-30-2019, 09:26 AM - Thread Starter
xp0z3d's Avatar
Quoted: 79 Post(s)
This is the one. Also because of I had used the other one, it would leave a lot of room on top for light to sneak in. With the one i have along with a pinch pleat curtain, it should block max light.
xp0z3d is offline
post #7 of 11 Old 07-30-2019, 02:20 PM
toddwz's Avatar
Quoted: 58 Post(s)
Liked: 32
Not quite sure what your ceiling track looks like. Can you upload a photo?
toddwz is offline
post #8 of 11 Old 07-30-2019, 02:22 PM - Thread Starter
xp0z3d's Avatar
Quoted: 79 Post(s)
Sorry about that, here is the pic and amazon link. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
xp0z3d is offline
post #9 of 11 Old 08-01-2019, 12:01 PM
toddwz's Avatar
Quoted: 58 Post(s)
Liked: 32
My apologies. It was my terrible English.
I think you can use some strings to hang the blackout curtains to those small rings on your ceiling track. Or you can first hang the white curtain shown in your link, and stitch blackout curtains/black fabric to both sides of the white curtain.
toddwz is offline
post #10 of 11 Old 10-10-2019, 07:40 PM
Liked: 0
I want 100% Blackout Curtains
I like this blackout curtains but this one, but just not 100% blackout, can anyone help me?
I want to buy Blackout Curtains like this:https://www.amazon.com/Jarl-home-Three-Color-Stitching-Blackout/dp/B07HRNFDXZ like this, but this one is not 100%.
White Lee is offline
post #11 of 11 Old 05-23-2020, 09:52 AM
Liked: 0
If you looking for 100% blackout curtains then go for custom made to measure curtains. If you are in Dubai you can find those with 99Blinds. They will take the measurements and will bring the catalogues to choose your curtains home. I have recently done my curtains with them. Found very professional.
Hospos Gaming is offline
