Minidsp with 4k - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-16-2019, 01:17 AM - Thread Starter
Liked: 0
Minidsp with 4k
Hi everyone. I recently bought a Minidsp nanoAVR DL but I only found out when I tried to set it up that the unit does not support 4k or 4k pass through. My problem is that my sources are all 4k and I don't want to just set all my sources to 1080p when I paid extra for all the 4k sources. I told Minidsp about this and they said they don't have any products that support 4k and Dirac live. They suggested using a matrix switcher to split the video signal to have the Minidsp receive a 1080p signal but have my projector receive the original 4k signal from my source. I'm not familiar with matrix switchers so I don't know if this is possible. Has anyone here tried anything like this? Can you recommend any products that would be able to do it?
Jreyes111 is offline
post #2 of 7 Old 09-16-2019, 04:04 AM
wpbpete's Avatar
Quoted: 199 Post(s)
Liked: 193
If you want Dirac, look for a used Nad 758v for just a few hundred more= no more problem!
wpbpete is offline
post #3 of 7 Old 09-16-2019, 08:49 AM - Thread Starter
Liked: 0
Problem is I already bought the minidsp. I'm trying to sell my minidsp but so far no takers. I've thought about getting the T758 if I'm able to sell the minidsp but buying the NAD on top of the minidsp is just too expensive. So for now I'm looking at other options like matrix switchers.
post #4 of 7 Old 09-16-2019, 02:47 PM
wpbpete's Avatar
Quoted: 199 Post(s)
Liked: 193
Yea... been there done that. I tried 3 different cheap switchers and they all failed. A good one will cost $300+ so it's not worth it.
wpbpete is offline
post #5 of 7 Old 09-16-2019, 07:43 PM - Thread Starter
Liked: 0
Thanks for the advice. I guess my only real choice is to sell the minidsp
post #6 of 7 Old 09-16-2019, 08:03 PM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 849
Check this out and see if it will help remedy your issue before deciding to sell it.
https://www.minidsp.com/forum/nanoav...in-audio-chain
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is offline
post #7 of 7 Old 09-19-2019, 07:51 AM
sirjaymz's Avatar
Quoted: 471 Post(s)
Liked: 573
This could possibly be a solution for you.
https://www.hdfury.com/product/4k-vertex2-18gbps/
I'd see if you can return the minidsp unit where you bought it from, unless it was directly from them in HK.
HT1.0 | HT2.05
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82/RC-64II/RS-42/RS-41/BS-62/CDT3800-C-II
sirjaymz is offline
