Dipole/Dipole vs in wall for surrounds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-06-2019, 03:57 PM - Thread Starter
purduesd's Avatar
Liked: 2
Bipole/Dipole vs in wall for surrounds
My gear so far:
Dennon x3500
Polk A9 towers
Polk Csi 4 center, (will possibly upgrade to csi6 )
PSW10 sub
another sub to be added
I need some surrounds! Looking at the Dipole/ Dipole Polk Fxi4/6 vs In wall RC85i Polks
Would love some input!
I have a large open basement room (see attached layout) My couch will be in the middle of the room.
For my 5.2 setup
My surround speakers will go on the sides -one on the stair wall and the end of the room wall on the other which is about 4' further away from the center of the couch
purduesd is offline
post #2 of 2 Old 11-21-2019, 02:31 PM
GoZags13's Avatar
Quoted: 183 Post(s)
Liked: 92
Will you ever convert to a 7 channel setup? If so then that future change could influence the choice. I think another major driver should be your feeling about the looks of in vs on wall speakers. Both can perform well but the ascetic will be very different. Along those lines, are you putting wire in the wall for both? In which case both speakers are locked in position...and it'd be good to verify you like the sound of the placement first.
Center room is difficult for bass, they recommend 1/3 or 2/3 for better response. You might find yourself in a null.
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
