My Listening Room AKA CptSpig - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By CptSpig
post #1 of 4 Old 11-14-2019, 12:24 PM - Thread Starter
CptSpig's Avatar
Quoted: 216 Post(s)
Liked: 89
AKA CptSpig's Listening Room
The purpose of this thread is to document my listening room, equipment, and the room's audio performance. I welcome comments or questions and I will answer to the best of my knowledge.
Equipment List:
Nvidia Shield Pro 2019
HDHomerun Extend HDTC-2US-M
OPPO 103d,
Xbox ONE,
SONY KDL-65W850A,
SONY VPL-VW295ES,
SI 120" 2:35 Pure White,
Furman Elite-20 PF I,
Audiocontrol Maestro X7,
CROWN DCi 8|300N,
JBL 708i (LCR),
JBL 705i Surrounds (4) Speakers
SDA-4600 Amp,
JBL Synthesis S2S-EX Subwoofers (2)
Cables: AudioQuest
Acoustical Treatments:
(2) GIK Monster Bass Traps and (3) DIY Corner Traps
Listening Room Plan View, Elevation, Section and Pictures
Calibration Files for DiracLive Harman Curve with 3db Bass Bump 80Hz crossover
REW SPL Screen Shots Harman Curve wi 3db Bass Bump 80Hz crossover
Balbolito likes this.
CptSpig is online now
post #2 of 4 Old 03-29-2020, 12:09 PM
Balbolito's Avatar
Quoted: 493 Post(s)
Liked: 875
@CptSpig Nice, love the setup too.
Question how would you say the 708's compare to the 705's? as i am planning to get some 705i's to use later for wides and front heights? how far are they in your room to your MLP?
Do you listen loud like at or close to reference?
Processors Marantz AV8805 & miniDSP 2x4 HD Amps Crown DCI/N x2 CT8150 x1 Speakers JBL PRO M2 x3 708i x4 328c x6 Subs SVS SB16 x4 Screen SI 160 Slate AT 1.2 Projector Optoma UHZ65 4K Media HTPC w/madVR Cables Wireworld,Hosa & Belden
Balbolito is offline
post #3 of 4 Old 03-29-2020, 12:45 PM - Thread Starter
CptSpig's Avatar
Quoted: 216 Post(s)
Liked: 89
The HF drivers are identical with reference to both speakers. The 8" LF driver of the 708i peaks at about 30Hz and the 5" driver of the 705i peaks at about 50 Hz. With my crossover set to 80Hz with the subs picking up the LF it's really a moot point. My furthest speaker is 15' to the MLP. I have a Crown DCi 8|300n amp which has level adjustment for all speakers. This allows me to balance all for the speaker levels before calibration. I have had the system to -10 from reference and the SPL meter shows 103db with plenty of head room. 103db is very loud in my room. These speakers will match your M2's HF very well. I am very happy with my system. Thanks for the questions.
post #4 of 4 Old 03-30-2020, 12:05 AM
Balbolito's Avatar
Quoted: 493 Post(s)
Liked: 875
I just got a Crown DCi 8|300n too, that is why i am asking. i should get it in a few days. deal was too good to pass!!
Honestly will be in storage for a while till my new house, but as amps don't change a lot over time and i already have two DCI/N amps so i thought i would get a third matching one.
