Why buy dual-arm TV mount? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By sdesiano
post #1 of 5 Old 11-16-2019, 11:40 PM - Thread Starter
sdesiano's Avatar
Quoted: 13 Post(s)
Question Why buy dual-arm TV mount?
Everything I've read (on this site and elsewhere) makes single-arm articulated mounts sound better. They're easier to position, often lighter, and don't get caught on themselves when being closed. Still, most mounts out there are dual arm.
So: assuming you can find a single-arm mount beefy enough to hold your set, is there any reason you would want to buy a dual-arm mount? Are they less likely to wobble or drift or fall down in an earthquake?
Thank you!
-- Sal
smile.
sdesiano is offline
post #2 of 5 Old 11-17-2019, 06:22 AM
airscapes's Avatar
Quoted: 519 Post(s)
Liked: 432
Guess it's like the 3 little pigs and the big bad wolf.. The brick house didn't fall down..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #3 of 5 Old 11-18-2019, 09:35 AM - Thread Starter
sdesiano's Avatar
Quoted: 13 Post(s)
I just had a thought: do two-arm mounts deflect less when fully extended?
sdesiano is offline
post #4 of 5 Old 11-18-2019, 10:12 AM
barryecohen's Avatar
Quoted: 80 Post(s)
Liked: 38
There is strength in numbers. That said, newer TVs are far lighter than their historic counterparts, so YMMV
I've had my 60" Sharp on a dual arm mount for over a decade now, the TV and mount are both going strong. Generally the mount is flush against the wall, though occasionally, I'll pull the TV out and angle it towards the dining room table for a special event, but even at 99 pounds, the TV doesn't droop or sag in either instance.
P.S. pretty sure this is the mount I've got > https://www.monoprice.com/product?p_id=8588
So much media, so little time...
My Media Room...
barryecohen is offline
post #5 of 5 Old 11-19-2019, 06:03 PM - Thread Starter
sdesiano's Avatar
Quoted: 13 Post(s)
Talking
Interesting... I guess I'll try a single-arm mount and see how it goes. The one I picked is rated for 2.2x the weight of the TV so I'm hoping it will be steady. If I learn anything interesting, I'll update this thread.
Thank you, as always!
barryecohen likes this.
sdesiano is offline
