Looking for help with speaker purchase - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-25-2019, 06:55 PM - Thread Starter
Liked: 0
Hello! I'm in the process of furnishing my recently finished basement. I just got a new 75" TV (Samsung Q80) set up and a place for my gaming consoles to go. Now I'm looking to add a decent speaker system, but I'm quite uneducated in this area and was hoping someone could advise! Attaching how things look currently.
I just purchased the SVS PB12-NSD Subwoofer for $499, and now I'm trying to pick out some speakers. Going to just start with 3.1, and I was looking at Q Acoustics 3020i which are $268 and the matching center 3090Ci for $170. I'll get some generic speaker stand to raise them up 2 feet. Does anyone have thoughts on my setup and the speakers I'm considering? Thanks!
cbr00 is offline
post #2 of 2 Old 11-29-2019, 09:07 PM
Superman07's Avatar
Quoted: 175 Post(s)
Liked: 45
I suspect you’ll have better luck on your speaker question in the speaker section of the forum. Plus you’ll likely be asked for: budget and objectives (% split between movies/music/tv/games).
If possible, I’d recommend putting the cables behind the wall, or covering them with channels and painting.
Superman07 is offline
