Looking for a 5.1 for under $2k
https://imgur.com/gallery/BYdAfDX
Hello everyone,
I’m hoping to put together my first 5.1 setup with this current layout but also was curious if it would be possible for a 5.2.2 in the future due to the floor plan. Will be using it for only movies and streaming.
Room dimensions.
Length: 23.5ft
Width: 12.5ft
Vaulted ceiling: 8-12ft
Viewing distance from TV is 9ft
Budget is $2k for speakers, sub and receiver. I’m open to buying used to get a better bang for my buck or wait for a sale. After my setup is up and running, what should I be looking for as far as room treatment goes?
As for equipments, I currently have a PX75, Apple TV 4K and Shield.
Not sure if it’ll make a difference but the corner of the sectional is along a 5ft wall. I know the sectional will have to move a bit in order to put the surround there but was wondering if that’ll make a difference in speaker selection.
Any suggestion or advice is greatly appreciated.
Thank you.
