How can I eliminate some echo in my living room? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By wookiegr
  • 1 Post By Mocs123
post #1 of 17 Old 11-26-2019, 07:37 PM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
I recently moved into my new house, and this sucker has some high ceilings in the living room coming in at 20-feet at one angle. I can hear an echo when I lightly holler in the house, and I am finding that to be the case with my audio as well. As you can see, not only are the ceilings high but it is completely wide and open to the kitchen, dining area, and the huge hallway. I still have to hang some art on the walls, but that will mostly be in the hallway. In the area where the TV is there is this odd area, or lip, which has opportunity to work with. With the speakers facing out from that, I am not sure if that is even worth it? Could audio travel up there and hang out?
Anyway, what do you think would help this out? Acoustic panels or some really large art up on the high wall? Foam in the corners? Dedicated acoustic panels (see link below for some I found). I welcome any ideas and/or links to products which may help this situation, and I thank you all!
https://www.amazon.com/s?k=UA-acoust...=bl_dp_s_web_0
What am I using?
Yamaha RX-685
LG C9
Andrew Jones Pioneer Speakers (I do have the atmos modules on top of the front towers)
Hsu VTF-2 Mk5 subwoofer
ID:	2646114   Click image for larger version
ID:	2646116   Click image for larger version
ID:	2646118   Click image for larger version
Last edited by JaredSD; 11-26-2019 at 07:45 PM. Reason: Because the images NEVER load correctly here
JaredSD is offline
post #2 of 17 Old 11-27-2019, 07:52 AM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
Nothing? Did I post in the wrong thread perhaps?
JaredSD is offline
post #3 of 17 Old 11-27-2019, 08:01 AM
Quoted: 253 Post(s)
Liked: 115
I think it's assumed you must thoroughly scower the acoustical treatments thread here before asking that type of question. My new living room is also echoey and I'll be looking at bookshelves, wall decorations and thicker dampening curtains to reduce it. Home Theater environments require different types of dampening which by the pics, you do not have to worry about.
JaredSD likes this.
wookiegr is offline
post #4 of 17 Old 11-28-2019, 12:04 PM
Craig Peer's Avatar
Quoted: 7212 Post(s)
Liked: 8624
I'd contact GIK and get some recommendations. https://www.gikacoustics.com/
Craig Peer is offline
post #5 of 17 Old 11-28-2019, 12:46 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
GIK Acoustics offers art panels that would blend in nicely with your living room.
https://www.gikacoustics.com/product...ic-art-panels/
Craig Peer likes this.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 530’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is offline
post #6 of 17 Old 12-03-2019, 09:07 AM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
Thanks! I checked them out, and they certainly have some cool options. I already have SO much artwork of my own, which gives me the opportunity to put foam behind the canvas, which I did not think about before. Do you think some regular or eggcrate style 1" foam behind every canvas would help a little?
JaredSD is offline
post #7 of 17 Old 12-03-2019, 09:13 AM
Craig Peer's Avatar
Liked: 8624
Probably not. I'd put white ( if you plan on keeping the walls white ) acoustic panels in various places.
post #8 of 17 Old 12-03-2019, 09:15 AM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
Others may chime in, but I think the canvas needs to be acoustically transparent or the sound will reflect off of it and not be absorbed by the material underneath. I believe they have the ability to put any image on their canvas so you might could get the same picture, but it just wouldn't be the original.
As for the foam (and yes, you can certainly make your own), most use Owen Corning 703 foam that comes in 1", 2", and 4" varieties. OC703's specific use is for acoustic panels so it's purpose built for that use. You can also use Rockwool insulation. The thicker the panel the lower the frequency it will absorb.
Mocs123 is offline
post #9 of 17 Old 12-03-2019, 09:23 AM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
Thanks for chiming in again. Good point about the canvas. I suppose most artist canvas, especially with paint, is already a little solid as far as the surface area. I will have to do some digging around to see if foam behind it would help at all. Surely someone out there has done some test to determine this, but I do think you are probably right.
I will check out that foam. I found these as well. http://www.usafoam.com/acousticfoam/acousticfoam.html
JaredSD is offline
post #10 of 17 Old 12-03-2019, 09:27 AM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
I do have an opportunity to use something as I am going to create a project similar to this which will be about 68" by 68". It will be more porous than canvas perhaps. I could easily stuff some foam behind this.
http://www.houseofjadeinteriorsblog....rtain-Art3.jpg
JaredSD is offline
post #11 of 17 Old 12-03-2019, 09:38 AM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
JaredSD is offline
post #12 of 17 Old 12-03-2019, 12:35 PM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
I have decided I am going to build my own panels such as in the last link I posted. If I use a porous cotton colored fabric from Hobby Lobby, with a furring strip frame, and the insulation in the middle......do you think that would help the echo? I would build about 15 of them in 20x20 squares and place them in that large area on the wall up top. The speakers are much lower at ground level of course and would not directly hit these panels. However, would it potentially solve for the echo? Is there a certain thickness of material I need to use?
JaredSD is offline
post #13 of 17 Old 12-03-2019, 02:47 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
My guess is it will help some but I’d use OC703, Linacoutic Duct Liner, or even acoustic drop ceiling tile. Acousimac sells DIY kits with everything you need to build panels in lots of different shapes and I think will also give some advice on where to hang them in your room.
Mocs123 is offline
post #14 of 17 Old 12-04-2019, 10:13 AM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
They got back to me, and def said I needed more than the room can handle, which of course I expected that response.
Check out the link below. Is this decent foam to use as well or is it not advised compared to the others you mentioned? I wondered if the pyramid shape does anything "special".
http://www.usafoam.com/acousticfoam/pyramidfoam.html
JaredSD is offline
post #15 of 17 Old 12-04-2019, 12:00 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
It looks like it takes 4" of foam to provide similar results to 1" of Owens Corning 703.
At least they pubish the data so you know what you're getting.
ID:	2649328   Click image for larger version
Mocs123 is offline
post #16 of 17 Old 12-04-2019, 12:53 PM - Thread Starter
JaredSD's Avatar
Quoted: 97 Post(s)
Math doesn't lie, usually. Thank you for pointing this out. The 1" is def the way to go with this in mind. Now to decide whether to DIY it or just buy some and pay double (or more) the price.
JaredSD is offline
post #17 of 17 Old 12-04-2019, 01:09 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
I've never used it, but the Eco-Core material from Acoustimac looks even better than OC703. Specs for 1" attached.
Name:	Eco Friendly.JPG
Mocs123 is offline
