Replace or repair Panasonic projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-30-2019, 06:13 PM - Thread Starter
PopDisplay's Avatar
I have a Panasonic PT-AE3000U which lasted 9 years on the same bulb. The bulb and fan need to be replaced. Is it worth the cost?
I have a pretty large (29x18) dedicated theater. Onkyo 5.1 receiver (also 10 years old), 9' diag screen, AV123 Rocket speaker system (don't ask), twin Outlaw Ultra-X12 subs (newer).
Should I just repair the projector or replace it and the Onkyo? We watch cable and movies. No gaming. We spend maybe 10 hours/month in the theater. The projector is 13' from the screen.
If replace, let's work with a $3,000 budget for the projector and receiver. Will the current 40' HDMI cable need to be replaced?
Suggestions on replacements are really needed as I've been out of this arena for some time.
Thanks in advance.
ID:	2647754   Click image for larger version
PopDisplay is offline
post #2 of 5 Old 12-01-2019, 08:39 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3896 Post(s)
Liked: 1815
Well I'd recommend replacement. Even if the Panny was a PT-AE8000 I'd still suggest the same.
Get yourself a Epson 5050 for under $2700 at the current sale price. E-Shift 4K, outrageously better Contrast and brightness. No contest nor contesting there at all.
If you do...consider going with a 2.39:1 Format screen with the same height as that 9' -16:9 ( 54") The 5050 will light it up and you can move comfortably into a C.I.H. situation without making any structural changes. You have a very nice Theater...it certainly deserves the upgraded image and Formatting.
7 Channel Onkyo's can be had on Amazon for really advantageous prices...and while I'll not ask the obvious about the rest of the speakers, I gotta ask"Why in the 'ell do you have those incredible Outlaw Ultras x-12's matched up with those "who cannot be asked about" speakers?* They are "Da Bomb!"
(ps. the Top end "Rockets" were not bad...just way over priced...)
MississippiMan is offline
post #3 of 5 Old 12-01-2019, 09:17 AM - Thread Starter
PopDisplay's Avatar
We bought the house because, in part, the basement was tricked out. Card room, billiard room, bar, theater, etc.
The theater was as shown in the photos. Except- no electronics. Just the room, cabinets, riser, and carpeting.
Not shown in the photos is the "cabling room" which runs the entire width of the theater, behind the screen wall.
I bought the speaker system because I was younger, inexperienced, and they were attractive and had a pretty good reputation among the AV123 cult (no surprise).
That they were very reasonably priced was also a factor.
And then I started assembling the theater components.
Panny PJ
Onkyo 5.1
Oppo DVD
Control 4 remote for the AV and illumination
Acoustic panels
I had an AV123 sub. When that fizzled out I bought the 2 Outlaws.
Aside from the sub, the system has performed well to my novice ears and eyes. Considering that we use the theater for at most 10 hours per month, there needs to be a balance between money in and enjoyment out.
Finances and perhaps necessity allow/require an upgrade-
As far as the Epson, am I wrong to see the white housing as an eyesore? It just seems logical that the housing should be black- to blend in with the support pole and ceiling.
post #4 of 5 Old 12-02-2019, 09:45 AM
Liked: 1815
In the world of Projectors, far more have White or Grey casings than have Black. But it can be something a style conscious individual my take umbrage with.
Epson has a model # 6050ub that has a Black Housing, however it is labeled as a "Pro" model and cost significantly more. It does however come with extras....a additional Lamp as well as a Custom Projector Mount.
As far as the unit being a eyesore....I've seen few complaints along that line. Mostly owning to the Pj's considerable Lens Shift and the ability to mount it so closeto the Ceiling.
Doing so in such a manner usually results in very few visitors even noticing it's presence. Of course YOU will always see it, so judge accordingly.
post #5 of 5 Old 12-02-2019, 08:32 PM - Thread Starter
PopDisplay's Avatar
He speaks my language
