My 1500 cu ft media room. - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By Oledurt
post #1 of 6 Old 12-01-2019, 09:54 AM - Thread Starter
Oledurt's Avatar
Quoted: 443 Post(s)
Liked: 583
This is my second attempt at putting together a media room. It’s not perfect, but It looks and sounds great! I have M&K lcr950 bookshelf speakers and two MK X12 subs configured for Atmos 5.2.4. I just upgraded my projector to the JVC NX5. I know it’s off center but there was an air vent in the way so I had to put it there. Anyway here’s a couple pics.
ID:	2648022   Click image for larger version
ID:	2648024   Click image for larger version
Oledurt is offline
post #2 of 6 Old 12-01-2019, 07:18 PM
jamiebosco's Avatar
Quoted: 813 Post(s)
Liked: 2016
Looks pretty close to perfect to me mate! Looks like you're in a space shuttle!
TV: Panasonic P65ST60 AVR: Denon X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
post #3 of 6 Old 12-03-2019, 09:40 AM - Thread Starter
Oledurt's Avatar
Quoted: 443 Post(s)
Liked: 583
Thanks mate! I never thought of it that way before. It does sort of look like the space shuttle 😂
Oledurt is offline
post #4 of 6 Old 12-03-2019, 11:02 AM
mike1sc's Avatar
Location: SC-GA border & neighbors are just far enough away!
Quoted: 21 Post(s)
Nice looking room!
Vizio M70-D3 TV, Denon X4300H AVR w/AC Infinity Fan, Emotiva XPA-3 Gen3 Amp, LG UBK90 4K w/DV, Samsung K8500 4K, Klipsch RP280F (2), RP450C Center, RP250 Surrounds (4), Atmos RP140SA (2), R12SW Subs (2), S-10 Surrounds (using as rear heights) (2), Apple TV 4K, Nvidia Shield 4K, Roku Ultra 4K, Amazon Fire TV Box. Currently running a 9.2.2 setup.
mike1sc is offline
post #5 of 6 Old 12-06-2019, 09:17 AM
robusto400's Avatar
Quoted: 99 Post(s)
Great job. Looks like a "cozy" solution with less than ideal room. I have a similar issue I am trying to work through with even more sloped ceiling than you have (but much larger room I think). What are your room dims? My main challenge is finding best placement for my Atmos speakers on a sloped ceiling and trying to conform as much as possible to Dolby specs. My question is how do your height speakers perform on your sloped ceiling and lower height than full ceiling? Where did you place your front heights? Did you consider using angled baffle speakers like SVS Prime's on front wall at top ceiling height?
TV: Samsung UN65JU7100
AVR: Yamaha RX-V683
Sony UBP-700 UHD, Apple 4kTV, Direct TV
5.1.2 Speakers: Front - Polk RM30, Center - Polk Csi5, Surround and Height (4) - Polk OWM3, Sub - Martin Logan Abyss
robusto400 is offline
post #6 of 6 Old 12-06-2019, 10:19 AM - Thread Starter
Oledurt's Avatar
Quoted: 443 Post(s)
Liked: 583
Hello,
As far as the heights/ceiling speakers go I am perfectly happy with them on the sloped part of my ceiling. In my old media room I had in ceiling speakers, and the difference between the way I have them now vs in ceiling install is not dramatic. When it comes to that I think it is more important to have timbre matched height/ceiling speakers. I also turn up my Atmos speakers about 1.5 db from where Audyssey sets them. I do that to compensate for Audyssey dynamic eq boosting my surrounds, and the fact that the calibration mic is actually placed slightly higher than my head so that it clears the head rest of my chair during setup.
My room is 1500 cubic feet so it's not huge.
Finally I would say that the most dramatic atmos affect will occur not so much from the exact location of them on the wall/ceiling but from the height they are placed. For example, if you had your atmos speakers 15 feet over your head the dispersion would be much greater and the height effects would be better. I can only pull off 8 feet over my head due to ceiling height. It's the best I can do in the room. Ultimately, compromise will always be made in this hobby. In my room the effect of having ceiling/height speakers is greater than not having them so that's good enough for me.
Oledurt is offline
