Home Theater: 5.1.4 or 7.1.2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By sdurani
  • 1 Post By sdurani
post #1 of 4 Old 12-10-2019, 02:52 PM - Thread Starter
Liked: 0
Hello everyone!!
I'm trying to decide if I go 5.1.4 or 7.1.2? I do not have the atmos and surround back yet, all the other speakers I already have installed.
I appreciate any suggestions based on the size and equipment that I have.
Tks!
Name:	HT - Rafael.jpg
Rafael Moreira is offline
post #2 of 4 Old 12-10-2019, 03:03 PM
sdurani's Avatar
Quoted: 7460 Post(s)
Liked: 6582
Stay with the 5 speakers you currently have in the base layer. With your couch against the back wall, there is no space behind you for the Rear speakers (i.e., there won't be any meaningful separation between the Sides and Rears). So just add 2 speakers to the height layer. You can do 4 speakers in the height layer, but one of those pairs will end up above you and might be distracting.
Rafael Moreira likes this.
Sanjay
sdurani is offline
post #3 of 4 Old 12-10-2019, 03:10 PM - Thread Starter
Liked: 0
Thank you! What do you think to do 2 CDT-3650 uphead, and get another 2 bookshelf to put in front height above the tv (between ceiling and wall) pointing to the couch?
It would be any better or go just with 5.1.2 with the uphead atmos speakers?
Thank you,
post #4 of 4 Old 12-10-2019, 03:30 PM
sdurani's Avatar
Liked: 6582
If one pair of height speakers is in front of you then the other pair of height speakers should be behind you, to get front-vs-back separation. But that's not possible with the seating against the back wall.
That's what I would do, with the height speakers mounted where you have them in your drawing.
Sanjay
sdurani is offline
