things to consider when choosing a wall mount.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-14-2019, 03:34 PM - Thread Starter
bhome83's Avatar
Hi Everyone,
Just bought a 65' OLED TV (LG C9PUA Series OLED65C9PUA), and was curious what I should look for in a wall mount?
I will be mounting on a brick wall above my fireplace (fireplace won't be used most likely), and don't really need the TV to tilt. Would be nice if it extended out a little to get to the cords (if I used the fireplace, it might keep heat away from TV?)
Anyways, I'm thinking of just buying the best selling wall mount on Amazon that is compatible with 300 x 200 VESA mounting, but am curious why there is such a massive price difference between mounts and whether or not the pricier ones are really worth it.
Appreciate the help!
bhome83 is offline
post #2 of 3 Old 12-14-2019, 04:20 PM
mbroadus's Avatar
Quoted: 1131 Post(s)
Liked: 451
Don’t cheap out on the wall mount...I always buy Sanus wall mounts. They have a Great Wall Mount finder application on their website. How high will the tv be mounted? You may want a tilting mount if it’s above a fireplace. How high is the fireplace mantle and how far back will you be sitting?
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i, Focal Aria 936/CC900
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #3 of 3 Old 12-15-2019, 09:34 AM
airscapes's Avatar
Quoted: 524 Post(s)
Liked: 435
Do a search in this forum, there are multiple threads dealing with buying a wall mount.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
