Overthinking Atmos? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By markmon1
post #1 of 15 Old 12-14-2019, 08:29 PM - Thread Starter
s_mack's Avatar
Overthinking Atmos?
Hi. We converted a bedroom (11.5' wide x 15' long x 9' high) to use as a dedicated small home theatre. I ran speakers in the wall and ceiling while it was getting renovated. I'm not looking at "high end" by any means, but I also don't want crap.
I've picked up a Denon AVR-X3600H and 5x KEF T101 speakers and sub package. I think it sounds fine. The receiver supports 4 ceiling speakers for Atmos and I've already got the wiring. I could also add a couple of rear speakers and go 7.1.4 if I add a 2ch amp.
I start looking for ceiling speakers and I see reviews of $40/pr (all figures Canadian dollars) that make it sound like I can get away with that and be fine. But then I read people saying you "must" timbre-match or the universe ends. I can pick up KEF ceiling speakers on sale right now for $160/pr. That's within my budget, but I don't want to spend 4x as much if there's really no point.
I am *not* a huge audiophile. In fact, this will be my first surround system I've ever installed. I typically figure the TV's speakers suffice. I splurged on a Yamaha YSP2200 sound bar (when sound bars were just coming out) once and honestly couldn't really appreciate it over the TV speaker if it weren't for the sub.
Same question for the rears... do I need to get KEF T101s for the rears (I won't - the pair costs more than I got the whole 5.1 for on Black Friday) or can I buy some cheap-o satellites just to fill in that channel?
Put another way... am I *better* with my KEF 5.1 and leave it at that vs. 5.1.4 or 7.1.4 where the additional 4 or 6 speakers are lesser quality?
s_mack is offline
post #2 of 15 Old 12-14-2019, 08:31 PM - Thread Starter
s_mack's Avatar
Oh, and I also meant to ask... will I see any benefit to adding a 2nd sub? I wired for a 2nd one at the back of the room, but wonder if with the size of the room if it would be a complete waste.
s_mack is offline
post #3 of 15 Old 12-14-2019, 08:33 PM
markmon1's Avatar
Quoted: 5676 Post(s)
Liked: 3727
You do not need to timbre match *anything* but if you are going to do so, you still do not need to timbre match the ceiling speakers. Those speakers are 99% ambiance and quick sounds.
Timbre matching is most important, in my opinion, between the floor speakers only.
As for where your money is better spent, I'd say 5.1.4 is really good with 7.1.4 adding extremely little so you're better off with 5.1.4 with better quality speakers than 7.1.4. You can add satellites as the rear channels, yes.
SuperFist and s_mack like this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #4 of 15 Old 12-14-2019, 09:49 PM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 297 Post(s)
Liked: 135
I have a 7.x.6 system with all 13 identical speakers and you can definitely tell the improvement over 'mismatched' speakers.
So yes it is best to have identical or at least timbre matched speakers all round.
However is it a must ? No ! Like most things AV related, it can sound good no matter what you run until you hear something better
But if you can then you should match as closely as possible for the most cohesive and immersive soundfield.
And although Atmos speakers may not always be active and may be predominantly ambient sounds, you still want the best you can afford and/or fit. There are still a lot of times when there is a lot of discrete lower frequency signal sent to overhead speakers. You don't want a dragon/helicopter/bomb over head that sounds like a butterfly/drone/firecracker
From my interactions on this forum it seems to be that on-ceiling bookshelf speakers are preferred to in-ceiling speakers unless you are using top-tier in-ceilings - have you considered that option ?
5.x.4 with 9 matching speakers should be superior to 7.x.4 with mismatched speakers. So go 5.x.4 and add matching rear surrounds later if required and once funds are available.
2 subs will likely be superior to just one - it all depends on room size/shape and treatments and sub locations. General advice around here is to buy the best sub you can to start with and then save or a second one later. One good sub should be better than 2 crap/average ones until you get the second good one.
niterida is offline
post #5 of 15 Old 12-14-2019, 09:56 PM
markmon1's Avatar
Liked: 3727
I disagree with this. You're better off spending that same money to upgrade your center or left/right front. In fact, if there's a better center, you should spend that money on that until you have the best center possible then upgrade other speakers. For theater, I prioritize center, then sub, then left/right front, then surrounds, then rear surrounds then ceiling. I'd say a system with a $5000 center and $50x4 atmos speakers will sound better than a system with $1000 center and $1000x4 atmos speakers.
post #6 of 15 Old 12-15-2019, 09:07 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 4004 Post(s)
Liked: 1883
And I even more strongly disagree with the above, seeing that it places Atmos capability at a low level. @niterida has it nailed down correctly.
That example above.....now that's just not making much sense because anyone who would lay out $5k for a Center (high end KEF) isn't going to waffle on spending $150.00 / $200.00 on decent Atmos Seakers. Probably a LOT more. I know of some DefTech and KEF speakers that the $5K-Guy would drop some coin on in a heartbeat. All under $1K too.
Unless an austere budget rules all buying decisions, Atmos speakers should at minimum be chosen for the Future...because you had better believe that the amount of content, as well as the "mixed-in" volume and intensity is only going to get more and more extensive...and extended.
Consider all the individuals who felt the same way 1st with Rear Surround. Then came Center Rears...and considerably more content in what had become Side Surrounds.
Atmos is a extension of the older High-Wide &/or High Front Channels on so many pre-Atmos Receivers. Now it's called "Object Based"...why? Because it's easier to describe the mixed effects in terms of "Rain & Thunder"...Bullets and shells whizzing...Helicopters passing. The 1st and last items can have a tremendous amount of low end and mid-Bass frequency...as well as piercing mid-range, and you cannot send a Boy to do a Man's job when impactful effects are needed.
Certainly for some there are both limits and limited need....but when one starts describing Atmos systems in terms of 5.2.4 or 7.2.4, then the Atmos should take it's place as being something well considered vital for both the present and the future.
There are spectacular performing, positional Woofer/Tweeter 6.5" Ceiling Speakers with Bass porting that can be had for under $150 ea. Suggesting a $50.00 In-Ceiling is simply telling someone; "Buy some cheap crap now so you can spend more later, and lose your modest investment in the original choices."
MississippiMan is offline
post #7 of 15 Old 12-15-2019, 09:48 PM - Thread Starter
s_mack's Avatar
Oh man... if I ever came home with a $5k speaker, it had better come with divorce papers already filled out!
I'm sure the KEF speakers I bought are far from "high end". All five plus the sub cost me C$600 (black Friday package).
I can get four KEF 6.5" ceilings on sale right now for another C$320. I think I'll go that route given what's been said here. Not cheap cheap, but still in budget and I'd say they are probably a good match for the T101s, no?
Thanks for the input.
s_mack is offline
post #8 of 15 Old 12-15-2019, 10:04 PM
Jonas2's Avatar
Quoted: 2934 Post(s)
Liked: 1888
Dunno how close of a match they are - but I'm guessing they'll do you just fine. Why not call KEF support and see what they say?
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #9 of 15 Old 12-15-2019, 10:11 PM
Liked: 1883
@s_mack ......or PM me with the model number and as a KEF-Direct Dealer I can give you the straight skinny on what to expect...and what not to as well.
4 - 6.5"ers for $320 seems like an awfully good deal on KEF, so I'm thinking you need to snacth 'em up fast!
BTW...virtually all KEFs are tonally matched...certainly more so than most since KEF places a high priority on aural quality.
post #10 of 15 Old 12-15-2019, 10:14 PM - Thread Starter
s_mack's Avatar
PM sent. Model number is CI160ER for the ceilings
s_mack is offline
post #11 of 15 Old 12-15-2019, 10:17 PM
nathan_h's Avatar
Quoted: 2791 Post(s)
Liked: 1981
If you only have one seat you really care about, then a single sub is fine. Otherwise, two, in diagonal corners from one another in a room like you describe, will help get more even response across multiple seats.
But if you can't swing the budget for two, get one now and one later. Personally, I'd get the second sub before going beyond 5 speakers, but that's just me, and there is a wow factor to putting in those overhead speakers (and you get that wow factor without spending a lot on the overheads).
nathan_h is offline
post #12 of 15 Old 12-15-2019, 10:20 PM
Liked: 1883
Absewlewtlye Killer units for that price. Specifically designed for Atmos too!
post #13 of 15 Old 12-15-2019, 10:22 PM - Thread Starter
s_mack's Avatar
good 'nuf 4 me! Thx
s_mack is offline
post #14 of 15 Old 12-16-2019, 03:10 PM
bearr48's Avatar
Quoted: 28 Post(s)
Liked: 32
One or 2 pair overhead speakers, small room?
I have a small room appx 17' L x 11' W x 8' Hi, with side surrounds and back surrounds, and 1 pair of SVS elevation speakers at ceiling, about 30 degrees forward from MLP. (Also two subs, but that's not relevant to my inquiry). Is it worthwhile, given the small size of the room, to add another pair of overhead speakers? Or should I call it good and just sell the second pair of elevation speakers? Thanks for opinions/advice. Jack
bearr48 is offline
post #15 of 15 Old 12-16-2019, 07:18 PM
Jonas2's Avatar
Liked: 1888
My room is 16' long, and I've got front and rear overheads. Your idea works in my book. You've got the speakers, give it a go. More is better, you'll get the front-back pan more effectively with 4 speakers, not just the side-to side, so you'd be bringing in the 2nd axis by adding the other two. You don't want the two pairs squished too closely together though.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
