Metal Studs and 65" (Vizio PQ65-F1). FlipToggles. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-12-2020, 06:40 PM - Thread Starter
alkemyst's Avatar
Quoted: 65 Post(s)
Liked: 32
I got the large Monoprice 6663 model mount, I will be able to hit 3 studs. The community manager said maintenance said that tv couldn't be wall mounted because the walls aren't strong enough.
I got FlipToggles 1/4"x2 1/2". I plan to use at least 6 (one top and one botton into 3 studs). The TV is around 60lbs and the mount is only tilt (not full motion).
I am hoping my stud finder is accurate enough as a 1/2" hole in a 1.5" stud is not leaving alot of room for error.
My only other experience was wood studs and concrete block.
Mains: Klipsch Quartets with upgraded tweeter/midrange diaphragms and X-overs from Mr. Crites.
Center: Klipsch Academy with upgraded tweeter diaphragms and X-overs from Mr. Crites.
Surrounds: Klipsch RS-25's
Sub: Emotiva Ultra 12
AV: Denon AVR-X4100W, Sony BDP-S6500, Vizio M60-D1 60" LCD
alkemyst is offline
post #2 of 3 Old 01-13-2020, 07:03 AM
Quoted: 20 Post(s)
Liked: 2
That should hold it. I have metal studs in my theater but not a wall mount. I regret it because the wall rattle and buzz.
Daniel Ickes is offline
post #3 of 3 Old 01-13-2020, 07:40 AM - Thread Starter
alkemyst's Avatar
Quoted: 65 Post(s)
Liked: 32
metal studs are junk....
alkemyst is offline
