Need options for recessed lighting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-14-2020, 11:08 AM - Thread Starter
MrDennis's Avatar
Quoted: 73 Post(s)
Liked: 31
I'm will be putting in recessed cans and lighting in my home theater and am getting information overload doing internet searches. My room is 18' X 23' with 8' ceiling and based on various calculators I need 9-12 remodel cans. What I really want is a smart wi-fi type light setup I can control the brightness in addition to the color of the light.
Anyone done this and if so what products did you use? I'm also thinking these 9-12 remodel cans need to be 6" cans, does that sound right?
Dennis
Sony VPL-VW285ES Projector / Denon AVR-X6500H Receiver / Aircom T10 Cooling Fan
Sony BDP-S790 3D/Blu-Ray / Sony UBP-X700 4K UHD
Pioneer DVL-909 Laserdisc / Lexicon LDD-1 Demodulator
Samsung DVD-VR375 DVD/VHS
MrDennis is online now
post #2 of 4 Old 01-15-2020, 10:18 AM
Liked: 4
Dennis
Why not go with can-less LED lights? https://www.acuitybrands.com/en/prod...ssed-downlight
They are ~$15 a pop on Amazon and are super easy to wire/install.
https://www.amazon.com/Lithonia-Ligh...9108669&sr=8-4
pondo is offline
post #3 of 4 Old 01-15-2020, 03:56 PM - Thread Starter
MrDennis's Avatar
Quoted: 73 Post(s)
Liked: 31
Pondo
Thanks for the info and links. While it doesn't have the option to change the color (not a big deal) it does meet all my needs and the reviews are solid. This will fit my needs.
Dennis
post #4 of 4 Old 01-15-2020, 05:42 PM
Liked: 4
Pondo
Dennis
The same manufacturer makes a model where you can select the color temperature, 2700k, 3000k and 4000k if my memory is correct. Browse through their site, they have a ton of offerings and their products are all well rated and not cheap knock-offs.
pondo is offline
