Recommendations for height adjustable wall mount for my 77" TV - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By mbroadus
  • 1 Post By voodoocurt
post #1 of 3 Old 01-27-2020, 03:04 PM - Thread Starter
obonillaf's Avatar
Quoted: 132 Post(s)
Liked: 47
Hi. I bought a 77" OLED C9 tv and because I'm a little OCD about having my tv at the right height, which means nights and nights of experimentation and trial and error, I will need a height adjustable mount because the Omnimount mount I'm using with my 65" TV is not enough for my 77" TV and they don't have a bigger model than the one I'm using with the 65" TV.
I've read about these mounts called MANTEL MOUNT but I'm not sure if they would work with my TV because I'm not using my TV above any fireplace, I'm placing it just against a concrete wall.
Any suggestions will be greatly appreciated! Thank you much!
obonillaf is offline
post #2 of 3 Old 01-28-2020, 12:37 PM
mbroadus's Avatar
Quoted: 1193 Post(s)
Liked: 494
I only use Sanus wall mounts and they have handy tool called the mount and height finder.
Mount finder - https://www.sanus.com/en_US/mountfinder/#!step1
Height finder - https://www.sanus.com/en_US/heightfinder/#!step1
obonillaf likes this.
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i, Focal Aria 936/CC900, SVS SB-3000
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #3 of 3 Old 02-04-2020, 05:04 AM
Liked: 1
I have the Mantle Mount 540 on a 70” and it’s awesome. I lowers up and down over a 9 1/2 inch mantle at 6 feet. Unlike your situation mine is over a large fireplace. Casual viewing and background noise is fine when it’s up higher but my living space is short so you are slightly looking up. When we watch movies as a family we bring it down and it is awesome. Very happy with the mantle mount and it is very sturdy and well built.
Voo
voodoocurt is offline
