Question about upgrading projector and reciever in basement to 4k - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By MrDennis
post #1 of 17 Old 02-01-2020, 02:38 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
I am ready to to upgrade my projector in my basement to 4K. I currently have the BenQ W1070 with a home theater in the box Onkyo 5.1 DTS surround system with all of the speakers mounted professionally. I set it up with all of this about 6 years ago when we finished our basement.
If I am going to upgrade to a new 4K projector, do I need to upgrade at the very least the reciever as well? I ask this because I currently have the HDMI from my Nvidia Shield and Bluray player going through the Onkyo reciever as pass through video. The problem is I do not believe my Onkyo reciever is compatible with 4K. I believe it to be too old of a model and I thought I read online that if you are using your reciever as a pass thru for 4K video you need to have a reciever that is compatible with 4k? Also, if this is true, would I need to upgrade my speakers too? Aren't the receivers that handle 4k typically ones made for Dolby Atmos? I don't think my standard 5.1 speaker set up is compatible with Atmost? Am I wrong?
Also, is there any way around this so that I only need to get a new projector and that is it? Or if I want to watch 4K on my screen with the full surround experience, do I need to route the 4K video through the reciever?
Any help would be much appreciated.
Sent from my SM-N950U using Tapatalk
SteveS78 is offline
post #2 of 17 Old 02-01-2020, 05:49 PM
m0j0's Avatar
Quoted: 1031 Post(s)
Liked: 1358
Short answer is yes, you should definitely start with a recent 4K and Dolby Atmos capable receiver. I went with the Denon x4400h and have had no issues with it. Speakers don’t necessarily need replacing but if you want atmos, you will need more speakers (the 4 atmos speakers if you go 5.1.4).
m0j0 is online now
post #3 of 17 Old 02-01-2020, 08:22 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
Or else I won't be able to watch in 4k, correct?
If I went with the extra speakers, where would I mount them? I currently have a center channel, the 2 front speakers mounted on either side of the screen and the 2 rear speakers mounted high up on the wall behind the seating...
SteveS78 is offline
post #4 of 17 Old 02-02-2020, 06:29 AM
Laughorgy's Avatar
Quoted: 18 Post(s)
Does your Nvidia Shield and Blu Ray player already support 4K , otherwise that'll be something else to upgrade. There are several ways to incorporate atmos but typically 2/4 speakers are placed on/in the ceiling slightly forward/behind your listening position. If doing so you'll also want to lower your rear surrounds to be level with your front channels. The upgrade to 4k does not require an upgrade to atmos but most modern receivers will be capable of both.
Laughorgy is offline
post #5 of 17 Old 02-02-2020, 08:18 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
The bluray player doesn't. But I certainly plan on upgrading that. The Shield does I believe.
EDIT- this is the exact Shield I own:
NVIDIA SHIELD TV Gaming Edition | 4K HDR Streaming Media Player with GeForce NOW https://www.amazon.com/dp/B01N1NT9Y6..._FHUnEbMQQS1HG
SteveS78 is offline
post #6 of 17 Old 02-02-2020, 08:42 AM
bud16415's Avatar
Quoted: 2253 Post(s)
Liked: 1177
There is nothing saying your video has to go thru your AVR to the projector. You can run the HDMI straight from the BD player to the projector and pick another audio source to feed the AVR and still maintain your 5.1. Or you can buy a HDMI splitter or switching box and do it that way.
I’m cheap and I have 2 HDMI cables running from my equipment rack to my projector one for TV one for BD. I just select input 1 or 2 on the projector.
Sure its nice to have it all packaged together but to save some money you can get started this way.
Bud
bud16415 is online now
post #7 of 17 Old 02-02-2020, 09:05 AM
m0j0's Avatar
Liked: 1358
Just to clarify, if you want to keep things like you have them passing through the AVR, and you want to take advantage of 4K and atmos, a new AVR would be a good place to start. As mentioned by @bud16415 , you can just run hdmi directly and bypass the AVR or use a switch, but in the end, I think you will save yourself some time and hassle by just getting a decent AVR and let it take care of everything. As for mounting, typically you want a 45 degree angle front and back for a 5.1.4 atmos placement, so measure ears at seated height, then go forward and behind the main listening position that far to get 45 degree angle, and width wise place them in line with your front left and right speakers.
m0j0 is online now
post #8 of 17 Old 02-02-2020, 11:39 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
Only thing is, we watch by far most of our content via the Shield. I think that only has one output which is the HDMI. I don't think I would be able to run the HDMI from the shield directly to the projector and then another output source from the shield to the AVR for the sound. I could be wrong though?
SteveS78 is offline
post #9 of 17 Old 02-02-2020, 02:53 PM
bud16415's Avatar
Liked: 1177
Something like this.
https://www.amazon.com/HDMI-Splitter...4-3e7a9c0027d0
Bud
post #10 of 17 Old 02-03-2020, 09:19 AM
MrDennis's Avatar
Quoted: 76 Post(s)
Liked: 32
If your goal is to move on to 4K content and you currently have a six year old 5.1 system it just make sense to move on to at least a 4K 5.1.2 system depending on the size of your HT room. This would require a 4K projector, 4K Receiver and at least two ceiling mounted Atmos speakers.
My HT room is 18' (120" screen wall) X 23', my theater seating is 3 wide with soon to be 3-4 seat bar behind seating so I only really needed two 8" Atmos speakers above seating area. I have a 4K 7.2.2 system.
Sony VPL-VW285ES Projector
Denon AVR-X6500H Receiver
Klipsch RF-7 III Fronts X 2
Klipsch RC-64 III Center X1
Klipsch R-112SW Subs X 2
Klipsch CDT-5800-Cii Atmos X 2
Klipsch RP-502S Surround X 2
Klipsch CDT-5800-Cii Rears X 2
Dennis
Sony VPL-VW285ES Projector / Denon AVR-X6500H Receiver / Aircom T10 Cooling Fan
Sony BDP-S790 3D/Blu-Ray / Sony UBP-X700 4K UHD
Pioneer DVL-909 Laserdisc / Lexicon LDD-1 Demodulator
Samsung DVD-VR375 DVD/VHS
MrDennis is offline
post #11 of 17 Old 02-09-2020, 08:40 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
Dennis
How about this Onkyo 5.1.2 Atmos system. Looks like it has the typical 5 speakers (center, 2 front and 2 rear) plus subwoofer. The difference is it appears the two front speakers have additional speakers on the top of the cabinet the fire upwards thus simulating the 5.1.2 effect...
Onkyo HT-S5800 5.1.2-Channel Dolby Atmos Home Theater Package https://www.amazon.com/dp/B00YMN69XS..._eCcqEbW203F65
Does this system seem like it could get the job done as a good Dolby Atmos system?
SteveS78 is offline
post #12 of 17 Old 02-09-2020, 03:28 PM
MrDennis's Avatar
Quoted: 76 Post(s)
Liked: 32
Steve
What size is your HT room? The Onkyo HT-S5800 5.1.2-Channel Dolby Atmos Home Theater Package seems like it will get the job done but from all the research I did on my system most people with high end systems preferred ceiling mounted Atmos vice upfiring atmos.
MrDennis is offline
post #13 of 17 Old 02-09-2020, 03:31 PM
MrDennis's Avatar
Quoted: 76 Post(s)
Liked: 32
Steve
What speakers do you currently have? Sound like all you really need is to upgrade your AVR and add 2-4 ceiling Atmos speakers and your sound part of this is solved.
MrDennis is offline
post #14 of 17 Old 02-09-2020, 05:50 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
I currently have an Onkyo home theater in a box 5.1 system. It is not high end, but still sounds great. My basement is not large at all.
SteveS78 is offline
post #15 of 17 Old 02-10-2020, 12:01 PM
MrDennis's Avatar
Quoted: 76 Post(s)
Liked: 32
Steve, if you're operating in a small space and your current speakers sound good than don't fix what's not broken. Start out with a new AVR and Atmos speakers and go from there.
MrDennis is offline
post #16 of 17 Old 02-12-2020, 07:52 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 0
Would the atmos speakers with the two front channels having upfiring speakers in the top of the cabinet be sufficient for my set up?
SteveS78 is offline
post #17 of 17 Old 02-13-2020, 06:38 AM
MrDennis's Avatar
Quoted: 76 Post(s)
Liked: 32
Check out this YouTube vid;
I haven't listened to up firing Atmos so I can't say one way or the other but my in ceiling Atmos do make a difference and I can tell they're up there, I see no reason why the up firing wouldn't produce the same results or people wouldn't be buying them.
SteveS78 likes this.
MrDennis is offline
