Is it upgrade time? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-03-2020, 08:42 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
Is it upgrade time?
So first off everything works, Ijust think it's time to upgrade. Currently running an Mix of Energy connoisseur cf 30 5.1 system with an pair of pioneer elite rear's( with atoms), I have an pair of SVS elevation speakers that I can use as hights/ overheads but these are still in the box. I run everything off an Dennon 4400 and spend my time watching Movies via 4k uhd-60. I have added some sound treatment panels to the room which helps with Reverb and all those other fancy words people use. Iam looking at moving to an total SVS system or even KEF or Klipish. I want to stay under 3k.... I know, not a whole lot to spend. Or should I dump the 4400 and go to an Pre/pro and direct amp to get more cleaner power, but then the cf-30's are only rated to 200w. Everything is set up in the main room of an townhome and not in an sealed and dedicated HT. Looking for suggestions and advice. Thanks
FN2817 is offline
