Options for home theater speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-10-2020, 01:56 PM - Thread Starter
dykstrajl's Avatar
Hey all! I am getting ready to finish my basement and build out a dedicated theater room with two rows of seating. The second row will be on a platform. Dimensions of the room will be roughly 21.5' x 13' with an 8.5' ceiling. I am trying to figure out which speakers that I currently own I am going to build the system with. I will need to add speakers to the system unless I use a hodgepodge of them. I will be doing a 7.1.4 system with a projector. 90% of the use will be watching movies/tv.
There will also be a larger open family room roughly 15.6'x28' that I will probably hook up 5.1.4 with some of the speakers I don't use in the theater.
What I need help with is determining which speakers I utilize and add to. I know I will need to get ceiling speakers for the heights, but just curious on your thoughts. I plan to run a processor and amps as well so power shouldn't be an issue.
Speakers I currently have that are available for the theater.
KEF
2 - Q350
1 - Q650c
2 - Kube 12b subs
2 - Q500
2 - Q5
2 - Q1
1 - Q9c
B&W
2 - 704 s1
2 - CDM SNT
1 - HTM7
2 - DS6
Klipsch
2 - Chorus II
1 - RW10d sub
1 - R10SWi sub
Thanks for your input in advance!
dykstrajl is offline
