Mounting TV to Wall with Plywood - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-21-2007, 12:33 PM - Thread Starter
terserterser's Avatar
Hi,
Newbie here. Would forum members be kind enough to provide guidance please?
I will be mounting a 46" LCD or plasma to a wall. Behind the drywall of this wall, where the TV/mount will be placed, there is plywood (instead of studs).
The mount comes with 2.5" screws, designed for mounting to wall studs. Should I use a different kind of screw, because of my plywood?
For example, my drywall plus the plywood will only be about 1.25" total. Would the 2.5" be inappropriate and somehow weakens the support?
terserterser is offline
post #2 of 7 Old 09-22-2007, 11:56 AM
Stew4msu's Avatar
Aren't there studs behind the plywood?
I don't think I'd mount it to just drywall and plywood.
Stew4msu is offline
post #3 of 7 Old 09-22-2007, 12:38 PM
mustardayonnaise's Avatar
eek. yeah, i don't know much about HT installation but I know a thing or two about structural integrity. a 46" lcd + mount will be at least 70-80 lbs- that'll torque right thru your drywall + plywood. you're probably gonna have to find some additional way to reinforce the wall.
mustardayonnaise is offline
post #4 of 7 Old 09-23-2007, 06:45 PM
jwatte's Avatar
That depends on the thickness of the plywood. If it's 3/4", it might hold. That depends what's holding the plywood up? Fasteners for plywood are typically of the "expander" or "anchor" point of view, where you insert some kind of flip-out through a hole, and then screw in the screw so that the anchor fastens to the backside.
I'd have an engineer look at that wall, though, before doing anything. It might be cheaper to just rip it out, put in studs between floor and ceiling, and patch up the wall. That would likely be < $1,000. And you could probably build a recess to put the TV in while you're at it :-)
jwatte is offline
post #5 of 7 Old 09-24-2007, 05:29 AM
Sunrisepilot's Avatar
I mounted my 42" plasma using 2 1"x4" oak strips (solid oak board) spanning 3 studs ... used lags (2 for each stud) into the studs; and a lag for each hole into the strips for the tilt mount.... been up 4 years no problems.
Cheers
Doug
ps
I tried hanging off the oak strips before I hung the mount and they held my weight (200 lbs)
Sunrisepilot is offline
post #6 of 7 Old 09-24-2007, 02:31 PM - Thread Starter
Thanks everyone for the replies thus far. There are some studs behind the plywood. They just may not be in the "correct" positions for the TV mount. In other words, I may not be able to screw in the mount where the studs are.
Any further guidance or experience to share would be greatly appreciated. Thanks very much!
post #7 of 7 Old 09-24-2007, 08:04 PM
Stew4msu's Avatar
Then, as sunrise pilot suggested, you'll probably need to screw in horizontal "studs" to the actual studs and then afix the mount to them.
Stew4msu is offline
