Dinger's Sports Bar/ Media-Poker Room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 176 Old 02-18-2008, 10:35 AM - Thread Starter
Dinger23's Avatar
Well after years of planning I am almost done with my "Man Cave" I bought my home in Dec of 04. It took them 18 months to build so I had plenty of time to design and redesign my basement. At 1st I was going to do a dedicated home theater room like the many you see on AVS. After thinking about it I never had the guys over to watch movies. I have them come over to watch sports, drink a little, and watch sports. So I designed this room for the guys to hang out and for me and the wife to watch movies.
Me and a buddy did all of the work ourselves including staining all the wood. My buddy has the skills and the tools. I was the assistant Have to thank the wife too. She let me design the whole thing to what I wanted. Also want to thank the many people on avs. I don't post much but I am lurking all the time. I got a great idea from others posts and photos so I wanted to share mine to maybe help others. We still have some work to do. Mainly the back bar and some trim work. I am not that great in taking photos but I think you will get a good idea of what it looks like.
Check out Dinger's
Dinger23 is offline
post #2 of 176 Old 02-18-2008, 10:42 AM - Thread Starter
Dinger23's Avatar
here are some more
Still got some trim work to do.
lacquer still needs to be laid
I have poker chairs on order.
Our 1st attempt to make a poker table. We found some instructions online and built our own. The logo is taking from the Yankees where I replaced my knickname. I have a friend who owns a advertising company so he had one of his graphic artist touch up my logo.
Check out Dinger's
Dinger23 is offline
post #3 of 176 Old 02-18-2008, 10:55 AM
ftaok's Avatar
Nice!
Two comments.
1. While the poker table looks great, I have to poo-poo the choice of the logo.
2. The movie chairs ... does you head smash into the bar/counter if you lean back?
ft
ftaok is offline
post #4 of 176 Old 02-18-2008, 10:57 AM - Thread Starter
Dinger23's Avatar
A few more
I still have to finish the back bar area.
Check out Dinger's
Dinger23 is offline
post #5 of 176 Old 02-18-2008, 11:02 AM
DixonJDixon's Avatar
Looks great. Thanks for sharing!
DixonJDixon is offline
post #6 of 176 Old 02-18-2008, 11:07 AM - Thread Starter
Dinger23's Avatar
Originally Posted by ftaok View Post
Nice!
Two comments.
ft
The head clears fine when you lean back. As they sit right now when you recline all the way back they just rub up against the back wall. I am still waiting for my 4th chair and I'll find the perfect spot.
As a Yankee fan I am used to people hating
Check out Dinger's
Dinger23 is offline
post #7 of 176 Old 02-18-2008, 11:22 AM
HeyNow^'s Avatar
Wow! Astounding. What a terrific job on the woodwork. I can almost smell the cigars. You should be very proud.
HeyNow^ is offline
post #8 of 176 Old 02-18-2008, 11:28 AM - Thread Starter
Dinger23's Avatar
Thanks HeyNow. your thead was one of the ones I followed the last few months.
Here is an upclose of one of the pillars
Check out Dinger's
Dinger23 is offline
post #9 of 176 Old 02-18-2008, 11:39 AM
BucksWin's Avatar
Do you have a floorplan that you could share? Looks great!
PSN ID: buckswin
BucksWin is offline
post #10 of 176 Old 02-18-2008, 01:10 PM
aham23's Avatar
the woodwork is very nice. how about some 4-1-1 on what equipment you are running?
and, go CUBS.
later.
aham23 is offline
post #11 of 176 Old 02-18-2008, 01:21 PM - Thread Starter
Dinger23's Avatar
well I am a Paradigm fan so speakers are S2 fronts with C3 center. I think the surrounds are cs160s??? what ever in wall goes with the sig line. Pushing the speakers with the Statement D1 pre-pro(soon to be upgraded to the D2 if I can live without it for a month.) and the Statement A5 amp. Projector is the Mits HC4900 and the screen is a Da-Lite 84 inch. Yes only 84 inches. I am only sitting 9ft from the screen. I am waiting fto get a new blu ray dvd player. I am think of getting a PS3 but I am not a big gamer. Want it more for the media server and I don't like that the remote is bluetooth. Won't work with my Mx-850 remote. TV at the bar is a 32in LG. Oh and most important, the kegerator is a Summit undercounter.
Check out Dinger's
Dinger23 is offline
post #12 of 176 Old 02-18-2008, 01:25 PM
chpwaman's Avatar
Wow!!! Very, Very Nice! Could you give some detail on how you did the woodwork on the bottom portion of your walls? Material type, etc.
chpwaman is offline
post #13 of 176 Old 02-18-2008, 04:17 PM
RETIRED theater builder
Quoted: 6696 Post(s)
Liked: 6580
post #14 of 176 Old 02-18-2008, 05:00 PM - Thread Starter
Dinger23's Avatar
The wood is maple. I didn't want a bunch of grain with the dark stain. For the panels on the walls we nailed up 1/4 inch plywood and basically made a picture frame in 3/4 inch ply by making pocket holes and screwing them together. Then we just put some trim on the inside boxes. Some chair rail on top and the baseboards are 2 pieces. On the Bars we made it more of a raised panel look
Bar siding
Check out Dinger's
Dinger23 is offline
post #15 of 176 Old 02-18-2008, 07:00 PM
chpwaman's Avatar
So, Maple Plywood for the panels, framed in with a maple plywood frame and trimmed out with the various trim pieces in the picture...correct? What color is that stain. I really like the way it turned out.
chpwaman is offline
post #16 of 176 Old 02-18-2008, 08:44 PM - Thread Starter
Dinger23's Avatar
Well we mixed the stain from a cross of mahogany and dark walnut. I didn't want a red tint which the flash from the photos gives and I didn't want it too dark. We mixed and matched to get to the finished product. 2 coats of stain and a coat of a lacquer and a coat finish to get the look. We used a safe oil base
Check out Dinger's
Dinger23 is offline
post #17 of 176 Old 02-19-2008, 03:17 AM
Artcon's Avatar
Great job! I can definitely relate to the work and planning that goes into a room like yours.
http://picasaweb.google.com/bchidef
Bob
Artcon is offline
post #18 of 176 Old 02-19-2008, 05:27 AM
chpwaman's Avatar
Thanks for the info Dinger.
chpwaman is offline
post #19 of 176 Old 02-19-2008, 09:39 AM
JBUNGIE's Avatar
Looks awesome, kind of reminds me of the Maggiano's resturaunt decor.
Only 1 beer on tap?!
JBUNGIE is offline
post #20 of 176 Old 02-19-2008, 03:04 PM - Thread Starter
Dinger23's Avatar
I only drink one type of beer at a time
Check out Dinger's
Dinger23 is offline
post #21 of 176 Old 02-19-2008, 03:10 PM
Audixium's Avatar
Quoted: 89 Post(s)
Liked: 158
Looks great! I'll be borrowing some of your work.
And at the risk of showing my true fair weather baseball fan status...go Rockies?
Audixium is offline
post #22 of 176 Old 02-20-2008, 09:32 AM
JBUNGIE's Avatar
But having a choice makes it that much better..plus you can keep a light brew & something a little heavier/stronger. Works great if you have picky friends!
As I said the room looks great..love all the dark wood!
JBUNGIE is offline
post #23 of 176 Old 02-20-2008, 02:42 PM - Thread Starter
Dinger23's Avatar
It would be nice but not worth the extra $$$. If my friends are too picky to drink my free beer then they can bring their own. Thanks for the kind words. This weekend I am going to do some more work on the bar. I will update with more photos.
Check out Dinger's
Dinger23 is offline
post #24 of 176 Old 02-21-2008, 08:02 AM
BucksWin's Avatar
Do you have any floorplans that you would be willing to share?
PSN ID: buckswin
BucksWin is offline
post #25 of 176 Old 02-21-2008, 01:58 PM
jntart's Avatar
Great room. love the woodwork. What about the textured walls? Is that faux finish or painted over wallpaper?
jntart is offline
post #26 of 176 Old 02-21-2008, 03:25 PM - Thread Starter
Dinger23's Avatar
Basically its a L shape room with the theater and poker table in an area 28x19. the bar area is in 9x14 area then down the hallway is 2 bedrooms and a full bath. Basement homes are rare in Phoenix and come finished so I couldn't design the entire layout.
As for the paint most homes here have texture walls. I think it's called orange peel. Painting in dark blue can be tricky to some I do need to touch up some areas. I was also flirting with putting faberic on the walls for sound treatment because of all the hard surfaces but as the room lays it hasn't been an issue
Check out Dinger's
Dinger23 is offline
post #27 of 176 Old 02-23-2008, 04:57 AM
Netko350Z's Avatar
Nice looking area. As you know, I love the look of wood in bar areas. Real classy place.
I would look into doing some in-walls for the front channels.
Netko350Z is offline
post #28 of 176 Old 02-23-2008, 06:00 AM
Wazzey's Avatar
Beautiful area. Love the whole idea.
Mike's attempt at a Theater
DIY motorized masking system
"Name?" Shropshire Slasher
"Occupation?" Shropshire Slasher
Wazzey is offline
post #29 of 176 Old 02-24-2008, 01:51 AM
coolhand's Avatar
Quoted: 83 Post(s)
Liked: 43
VERY NICE. I am very impressed in your (and mostly your friend's) DYI prowess.
Beautiful manspace.
coolhand is offline
post #30 of 176 Old 02-25-2008, 08:41 AM
puskarich's Avatar
Wow, this is very nice. Excellent work.
puskarich is offline
