AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Blu-ray Software (https://www.avsforum.com/forum/150-blu-ray-software/)
-   -   Afro Samurai Director's Cut comparison *PIX* (https://www.avsforum.com/forum/150-blu-ray-software/1061274-afro-samurai-directors-cut-comparison-pix.html)
Xylon 08-28-2008 06:05 PM
What is up with this HD anime with the overuse of some kind of softening filter? Appleseed Ex Machina got it and even Vexille (which BTW will be available on Blu-ray) has that hazy look. They said its their style but to me it just downgrades the crispness look of animation like those 2D Disney.
No siginificant difference while watching the two versions between the 1080i AVC Japanese release and the 1080p AVC US release. Much like the Terminator 3 comparison I did before.
The TC version has DTS-HD MA, Dolby TrueHD while the DC version has only Dolby TrueHD lossless audio. The AQ is very good. Personally Vexille still has the superior sound with more use of the surrounds and LFE. Then again its not fair since Afro Samurai doesn't have futuristic machines exploding all over the place
Blu-ray TC File size: 32.50 GB
Bitrate: 33.03 mbps
Code:
        Total   Video
Afro Samurai JPN Theatrical Cut                                 AVC     1:52:08 34,954,954,752  38,681,822,520  41.56   33.03   DTS-HD Master 5.1 2408Kbps (48kHz/16-bit) Dolby TrueHD 5.1 1841Kbps (48kHz/16-bit)
DISC INFO:
Disc Size:      38,681,822,520 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:52:08 (h:m:s)
Total Bitrate:  41.56 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00000.M2TS      34,954,954,752  1:52:08.388     0:00:00.000     1:52:08.388
VIDEO:
Codec               Bitrate         Description
MPEG-4 AVC Video    33033 kbps      1080i / 29.970fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2408 kbps       5.1 / 48kHz / 16-bit / 2408kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
Dolby TrueHD Audio              English         1841 kbps       5.1 / 48kHz / 16-bit / 1841kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             Japanese        192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           Japanese        64 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:11:00.527     33,121 kbps     64,757 kbps     00:00:11.078    41,883 kbps     00:00:07.674    40,144 kbps     00:00:21.955    138,141 bytes   638,766 bytes   00:01:54.181
2               0:11:00.527     0:05:47.680     33,645 kbps     64,506 kbps     00:14:17.457    39,373 kbps     00:14:57.597    38,023 kbps     00:14:22.862    140,330 bytes   665,589 bytes   00:14:17.590
3               0:16:48.207     0:08:01.581     32,961 kbps     52,086 kbps     00:24:44.750    39,456 kbps     00:17:08.728    38,620 kbps     00:20:08.174    137,475 bytes   763,837 bytes   00:24:44.783
4               0:24:49.788     0:11:42.669     33,057 kbps     63,329 kbps     00:29:23.996    40,464 kbps     00:28:26.338    39,379 kbps     00:28:21.133    137,876 bytes   739,910 bytes   00:34:59.097
5               0:36:32.457     0:08:06.252     33,048 kbps     64,139 kbps     00:40:23.988    40,645 kbps     00:40:23.988    39,710 kbps     00:43:17.462    137,839 bytes   741,285 bytes   00:40:24.122
6               0:44:38.709     0:09:46.953     33,510 kbps     52,925 kbps     00:44:59.764    38,911 kbps     00:48:29.807    36,754 kbps     00:48:45.423    139,763 bytes   515,423 bytes   00:44:47.685
7               0:54:25.662     0:09:28.235     33,371 kbps     56,024 kbps     01:00:16.379    41,653 kbps     01:00:23.920    39,856 kbps     00:54:38.675    139,183 bytes   657,587 bytes   01:00:16.480
8               1:03:53.897     0:04:40.180     33,478 kbps     53,242 kbps     01:05:50.180    39,697 kbps     01:05:56.853    38,420 kbps     01:05:57.287    139,631 bytes   598,057 bytes   01:05:50.480
9               1:08:34.077     0:15:44.343     33,552 kbps     59,848 kbps     01:08:43.720    40,054 kbps     01:16:02.525    36,893 kbps     01:18:58.434    139,940 bytes   590,589 bytes   01:08:44.287
10              1:24:18.420     0:14:46.319     33,108 kbps     59,310 kbps     01:27:15.664    41,176 kbps     01:38:13.521    38,728 kbps     01:38:13.454    138,089 bytes   735,263 bytes   01:27:15.931
11              1:39:04.739     0:08:30.710     32,534 kbps     56,816 kbps     01:43:39.380    41,779 kbps     01:42:01.115    39,709 kbps     01:42:01.415    135,692 bytes   711,249 bytes   01:43:12.386
12              1:47:35.449     0:04:32.939     28,784 kbps     49,630 kbps     01:47:46.226    42,396 kbps     01:49:59.827    39,886 kbps     01:49:54.555    120,053 bytes   474,147 bytes   01:48:58.599
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00000.M2TS      4113 (0x1011)   0x1B            6728.39         27,782,151,567  151,208,977     33,033
00000.M2TS      4352 (0x1100)   0x83            6728.39         2,086,301,730   17,212,163      2,481
00000.M2TS      4353 (0x1101)   0x86            6728.39         2,025,220,488   12,053,467      2,408
00000.M2TS      4354 (0x1102)   0x81            6728.39         161,481,984     1,051,315       192
00000.M2TS      4608 (0x1200)   0x90            6728.39         53,885,999      305,705         64
Blu-ray DC File size: 20.30 GB
Bitrate: 16.99 mbps
Code:
        Total   Video
Afro Samurai US Director's Cut                                  AVC     2:11:22 21,888,215,040  24,953,097,283  22.21   16.99   Dolby TrueHD 5.1 1856Kbps (48kHz/16-bit)
DISC INFO:
Disc Size:      24,953,097,283 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         2:11:22 (h:m:s)
Total Bitrate:  22.21 Mbps
Description:
FILES:
00035.M2TS      4,400,117,760   0:26:15.657     0:00:00.000     0:26:15.657
00036.M2TS      4,352,710,656   0:26:17.534     0:26:15.657     0:52:33.191
00037.M2TS      4,401,266,688   0:26:17.534     0:52:33.191     1:18:50.725
00038.M2TS      4,406,169,600   0:26:17.450     1:18:50.725     1:45:08.176
00039.M2TS      4,327,409,664   0:26:13.446     1:45:08.176     2:11:21.623
00007.M2TS      540,672         0:00:01.001     2:11:21.623     2:11:22.624
VIDEO:
MPEG-4 AVC Video    16986 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1856 kbps       5.1 / 48kHz / 16-bit / 1886kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             English         640 kbps        2.0 / 48kHz / 448kbps
CHAPTERS:
1               0:00:00.000     0:04:38.361     19,778 kbps     40,590 kbps     00:04:34.608    32,154 kbps     00:04:33.356    25,352 kbps     00:00:21.897    103,115 bytes   615,709 bytes   00:04:34.274
2               0:04:38.361     0:04:57.047     15,758 kbps     40,600 kbps     00:07:48.468    34,633 kbps     00:07:48.301    26,378 kbps     00:07:41.378    82,153 bytes    430,109 bytes   00:07:49.344
3               0:09:35.408     0:05:11.311     15,405 kbps     48,279 kbps     00:13:57.754    23,179 kbps     00:13:53.750    19,479 kbps     00:13:53.708    80,315 bytes    536,579 bytes   00:13:58.546
4               0:14:46.719     0:04:43.742     19,185 kbps     38,542 kbps     00:17:53.572    30,716 kbps     00:16:39.123    28,775 kbps     00:19:02.600    100,022 bytes   407,881 bytes   00:19:10.858
5               0:19:30.461     0:04:59.007     18,630 kbps     31,699 kbps     00:23:30.034    28,404 kbps     00:24:01.482    26,861 kbps     00:22:34.353    97,130 bytes    379,032 bytes   00:22:40.693
6               0:24:29.468     0:01:46.189     7,142 kbps      40,116 kbps     00:26:06.023    26,384 kbps     00:26:02.728    21,153 kbps     00:25:57.097    37,236 bytes    490,045 bytes   00:25:55.596
7               0:26:15.657     0:00:30.030     15,652 kbps     29,303 kbps     00:26:24.124    23,931 kbps     00:26:24.124    21,157 kbps     00:26:23.999    81,602 bytes    329,627 bytes   00:26:36.553
8               0:26:45.687     0:04:59.675     20,099 kbps     30,508 kbps     00:28:15.193    29,775 kbps     00:28:14.902    27,922 kbps     00:28:09.897    104,785 bytes   325,462 bytes   00:31:44.486
9               0:31:45.362     0:06:15.208     18,570 kbps     43,448 kbps     00:37:44.846    30,653 kbps     00:37:40.967    25,615 kbps     00:34:20.475    96,816 bytes    300,276 bytes   00:37:45.430
10              0:38:00.570     0:07:06.885     18,558 kbps     26,502 kbps     00:41:02.502    25,479 kbps     00:41:02.502    24,385 kbps     00:40:58.748    96,754 bytes    289,009 bytes   00:40:30.803
11              0:45:07.455     0:05:39.672     14,016 kbps     41,203 kbps     00:47:58.000    28,529 kbps     00:47:53.996    22,155 kbps     00:47:51.619    73,072 bytes    270,581 bytes   00:47:58.501
12              0:50:47.127     0:01:46.065     6,232 kbps      40,100 kbps     00:52:23.557    23,658 kbps     00:52:19.762    18,527 kbps     00:52:14.673    32,490 bytes    455,357 bytes   00:52:13.255
13              0:52:33.192     0:00:30.030     19,554 kbps     35,974 kbps     00:52:41.658    29,006 kbps     00:52:41.658    25,804 kbps     00:52:41.617    101,947 bytes   385,092 bytes   00:52:54.046
14              0:53:03.222     0:06:49.742     16,913 kbps     40,203 kbps     00:55:21.360    39,247 kbps     00:55:17.356    37,032 kbps     00:55:13.101    88,178 bytes    395,729 bytes   00:55:16.647
15              0:59:52.964     0:07:02.673     17,798 kbps     30,245 kbps     01:04:26.988    27,058 kbps     01:04:26.988    23,459 kbps     01:04:26.988    92,792 bytes    215,346 bytes   01:01:21.344
16              1:06:55.637     0:05:16.399     17,400 kbps     42,600 kbps     01:10:04.909    38,994 kbps     01:10:58.963    30,320 kbps     01:10:54.959    90,717 bytes    405,349 bytes   01:09:42.804
17              1:12:12.036     0:04:52.626     18,533 kbps     42,365 kbps     01:12:33.099    38,871 kbps     01:12:35.434    36,628 kbps     01:12:33.099    96,624 bytes    404,505 bytes   01:12:33.766
18              1:17:04.662     0:01:46.064     7,656 kbps      40,021 kbps     01:18:41.050    26,816 kbps     01:18:37.212    21,781 kbps     01:18:32.166    39,916 bytes    496,934 bytes   01:18:30.706
19              1:18:50.726     0:00:30.030     14,656 kbps     28,100 kbps     01:18:59.151    22,580 kbps     01:18:59.151    19,639 kbps     01:18:59.109    76,412 bytes    310,375 bytes   01:19:11.538
20              1:19:20.756     0:04:56.505     13,486 kbps     39,654 kbps     01:22:25.858    22,899 kbps     01:22:25.566    18,679 kbps     01:22:18.100    70,311 bytes    458,399 bytes   01:22:26.150
21              1:24:17.261     0:06:31.891     19,365 kbps     31,586 kbps     01:27:30.203    27,671 kbps     01:27:28.660    25,552 kbps     01:27:24.656    100,961 bytes   265,323 bytes   01:27:30.245
22              1:30:49.152     0:06:01.528     19,599 kbps     29,134 kbps     01:32:28.585    25,115 kbps     01:32:15.196    24,025 kbps     01:32:15.321    102,179 bytes   223,143 bytes   01:32:29.169
23              1:36:50.680     0:06:31.516     18,060 kbps     41,762 kbps     01:39:13.281    32,988 kbps     01:39:11.863    31,997 kbps     01:39:11.112    94,157 bytes    570,022 bytes   01:41:31.294
24              1:43:22.196     0:01:45.981     5,998 kbps      39,231 kbps     01:44:58.542    22,906 kbps     01:44:54.705    16,963 kbps     01:44:49.658    31,270 bytes    406,950 bytes   01:44:49.200
25              1:45:08.177     0:00:30.030     16,526 kbps     31,045 kbps     01:45:28.239    25,302 kbps     01:45:16.519    22,096 kbps     01:45:16.519    86,158 bytes    341,081 bytes   01:45:28.948
26              1:45:38.207     0:05:52.435     14,959 kbps     27,238 kbps     01:48:47.813    21,805 kbps     01:46:12.199    19,364 kbps     01:46:11.407    77,991 bytes    273,573 bytes   01:50:03.639
27              1:51:30.642     0:04:57.506     19,639 kbps     46,165 kbps     01:56:25.729    40,411 kbps     01:56:21.683    37,341 kbps     01:56:16.928    102,391 bytes   320,847 bytes   01:55:16.701
28              1:56:28.148     0:06:25.176     19,396 kbps     45,336 kbps     01:59:42.175    39,813 kbps     01:56:59.804    39,176 kbps     01:59:58.608    101,124 bytes   498,732 bytes   02:00:08.493
29              2:02:53.324     0:06:41.818     17,410 kbps     44,340 kbps     02:03:52.800    39,193 kbps     02:03:24.814    34,100 kbps     02:03:23.438    90,767 bytes    369,855 bytes   02:06:44.806
30              2:09:35.142     0:01:47.483     6,107 kbps      39,286 kbps     02:11:11.572    24,466 kbps     02:11:08.277    17,557 kbps     02:11:02.730    31,838 bytes    443,682 bytes   02:11:02.146
STREAM DIAGNOSTICS:
00035.M2TS      4113 (0x1011)   0x1B            1575.66         3,344,399,252   18,198,094      16,980
00035.M2TS      4352 (0x1100)   0x83            1575.66         497,542,386     4,173,952       2,526
00035.M2TS      4353 (0x1101)   0x81            1575.66         88,238,080      492,400         448
00036.M2TS      4113 (0x1011)   0x1B            1577.53         3,350,536,125   18,231,586      16,991
00036.M2TS      4352 (0x1100)   0x83            1577.53         472,641,432     3,892,906       2,397
00036.M2TS      4353 (0x1101)   0x81            1577.53         88,342,016      492,980         448
00037.M2TS      4113 (0x1011)   0x1B            1577.53         3,347,641,160   18,215,772      16,977
00037.M2TS      4352 (0x1100)   0x83            1577.53         519,241,686     4,161,614       2,633
00037.M2TS      4353 (0x1101)   0x81            1577.53         88,342,016      492,980         448
00038.M2TS      4113 (0x1011)   0x1B            1577.45         3,352,487,064   18,242,299      17,002
00038.M2TS      4352 (0x1100)   0x83            1577.45         496,280,888     4,160,671       2,517
00038.M2TS      4353 (0x1101)   0x81            1577.45         88,338,432      492,960         448
00039.M2TS      4113 (0x1011)   0x1B            1573.45         3,341,557,908   18,182,717      16,990
00039.M2TS      4352 (0x1100)   0x83            1573.45         473,458,170     3,811,414       2,407
00039.M2TS      4353 (0x1101)   0x81            1573.45         88,114,432      491,710         448
00007.M2TS      4113 (0x1011)   0x1B            1.00            101,406         576             810
00007.M2TS      4352 (0x1100)   0x83            1.00            173,626         1,692           1,388
00007.M2TS      4353 (0x1101)   0x81            1.00            81,920          480             655
House 08-28-2008 06:32 PM
1080i vs 1080p? Was the Japanese release a significantly higher bitrate?
lgans316 08-28-2008 07:11 PM
http://blurayblog.blog79.fc2.com/?q=afro
http://blog-imgs-24.fc2.com/b/l/u/bl...rosamurai1.jpg
http://blog-imgs-24.fc2.com/b/l/u/bl...rosamurai2.jpg
http://blog-imgs-24.fc2.com/b/l/u/bl...rosamurai3.jpg
Code:
(J) Afro Samurai (1080i59.94)                   AVC     1:52:08 34,954,954,752 ~38,681,822,520  41.56   33.03   DTS-HD Master Audio 5.1 Dolby TrueHD 5.1 16-bit
DTS-HD MA - English
Dolby True HD - Japanese
Subtitles: Japanese
Pony Canyon
Price: $45
jkcheng122 08-28-2008 09:20 PM
Code:
DTS-HD MA - English
Subtitles: Japanese
Pony Canyon
Price: $45
this is the movie and not the season1 dvd release coming on blu-ray soon in US? is there any difference?
lgans316 08-28-2008 09:28 PM
No idea boss. Just searched through the blog and found this.
http://www.amazon.co.jp/dp/B00104Y8XA
Kenneth Brown's review is up at HDD. PQ: 3/5, SQ: 4.5/5.
Phantom Stranger 08-28-2008 09:31 PM
I can already tell you the U.S. release has a much lower average video bitrate than the posted one for the Japanese import. I've watched the first two episodes and the U.S. one is encoded in AVC where it ranges between 12 to 36 Mbps with many scenes staying in the teens. The runtime on the U.S. disc is 131 minutes. The U.S. disc hasn't impressed me that much so far. I haven't seen the import in action.
Xylon 08-30-2008 04:10 AM
Xylon 08-30-2008 04:12 AM
Yes. But the lower US version PQ is the same. At least when watching it. This anime is just too darn soft.
paku 08-30-2008 04:43 AM
The softness is to keep it from looking like this. It's just the way they do things and it's the same with most digital anime. Lower budgets prohibit drawing/rendering in the same extremely high resolutions as the Disney CAPS and Pixar titles, and production is also often split between many different animation studios, where each may be doing things a bit differently.
So basically it's a choice between an overall softer look, or sharper but with lots of aliasing and inconsistent animation.
If you want really beautiful and sharp animation, you need to go back to the titles made with cels and film. Most of Bandai Visual's older titles like the Patlabor movies look fantastic, and I can't wait for Disney to start releasing the Ghibli catalogue on Blu-ray.
shadowrage 08-30-2008 09:20 AM
i don't think it was a budget issue. It had about a million an episode. That's a lot for an American animation series.
I saw the first episode on spike and hated it. Maybe HD will make me change my mind, the $10 price tag is worth the risk.
What sucks is that this just made me want Samurai Champloo in HD even more, now that series has a real killer soundtrack.
Originally Posted by paku View Post
And most of it probably went to Samuel L. Jackson.
And I would be surprised if Samurai Champloo was animated in HD.
That would make sense. I'm pretty sure SC has been broadcast in HD in Japan.
paku 08-30-2008 09:30 AM
paku 08-30-2008 10:01 AM
An example of what I mean by inconsistent animation. These are all from the same movie, RahXephon: Pluralitas Concentio (HD DVD).
Sharp, but the lines are all aliased and squiggly like in Justice League:
An example of a softer type, more like Afro Samurai:
Here the look is a bit different. What's more, the character in the middle is drawn differently from the rest of the frame:
No comment...
Upon a second look though, Afro Samurai does seem even fuzzier than normal, so maybe a lot of it was intentional.
Decado2 08-30-2008 10:13 AM
Does this disc have Japanese audio? I found Jackson to be really annoying (as the chatterbox guy).
paku 08-30-2008 10:29 AM
No, and as far as I know no Japanese dub of Afro Samurai even exists.
shadowrage 08-30-2008 10:36 AM
I actually think those are somewhat consistent. A a lot of anime uses soft lighting, especially under lamp posts at night(pic #2). With that one I think the lighting just changed from scene to scene.
But I know what you mean when you say they can be inconsistent. Because they take so long to animate, and sometimes they have to go to different animation houses and post production and things like that.
With AS I'm betting the director was going for something of a foggy look. Comparable to the dust one would find in the west, since the series borrows so much from westerns. Well maybe just softening it to make it look a little more old-world, that's probably a better way to put it. It's probably the best it can look.
One more thing - The more HD animation the better. Nothing benefits more from hi-res than the little drawings.
Xylon 08-31-2008 04:49 AM
I really looked for some kind of discernible difference between the two while in motion especially high motion scenes. The PQ is solid no macroblocking at all. The US Director's Cut gets my nod of course because its . . . err ..Director's Cut
eric.exe 08-31-2008 05:10 PM
The Director's cut lacks the sweet RZA song during the intro.
Kentai 08-31-2008 06:24 PM
I've yet to see the theatrical version, but when you factor in how many openings, "last time" clips and credit sequences there are on the Director's Cut, I'd imagine the differences are minimal. The DC moniker was created before the Theatrical Cut even even existed, to differentiate it from the edited Spike TV version. Wither or not Fumoniro Kizaki actually likes the TC or the DC better, I don't know. The TC features a commentary in Japanese... that might shed more light on the whole thing?
As always, thanks for the caps Xylon. FUNimation has been known for producing some pretty ugly low-bitrate DVDs (with Afro Samurai being one of their better transfers!), so I'm glad to see the BD look as good as it does. The Japanese transfer is ever so slightly sharper, but that's the only difference I can find.
Xylon 09-06-2008 10:37 PM
Xylon 09-06-2008 10:39 PM
Banding. It may not be as obvious as Appleseed but its there.
Phantom Stranger 09-07-2008 06:34 PM
Definitely. Like you I'm not a big fan of whatever the animators are applying to soften up or create a hazy look in the image.
Xylon 12-25-2008 03:23 PM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
