Hannah Montana And Miley Cyrus: Best of Both Worlds Concert Tour comparison *PIX* Ya! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 08-28-2008, 07:40 PM - Thread Starter
Xylon's Avatar
If there is any reason to upgrade to Blu-ray over DVD then this the title to get. No waxy faces. No halos to complain about. This is what every PS3 owner is waiting for. Hanna Cyrus in umm, Miley Montana in glorious 1080p High Definition picture!
But WAIT! Its also in 3D!!!!
Disclaimer: I bought this for the 3D feature. Honest!
The 3D version is what actually intrigued me. There some future BD releases that will be made to specifically take advantage of this "gimmick". I called it like that because if this is the future of 3D then its just a waste of time. It still uses an old fashioned way of getting "3D". Remember those paper cutouts with red and blue plastic that resemble glasses? That is what you will be using. I don't think any AVS'rs will be caught dead using that watching Hanna Cyrus.
As for the regular version the PQ is very good but not as sharp as Dave Matthews and Tim Reynolds: Live at Radio City or Elton 60. I also notice some minor banding in the background and artifacts when the whole scene is getting busy. Not really distracting to me since it doesn't break up like mpeg-2 broadcasts. But I'm sure your kids wont mind as much
Xylon is offline
post #2 of 38 Old 08-28-2008, 07:40 PM - Thread Starter
Xylon's Avatar
This movie was also shown at DisneyHD that I'm able to record:
Code:
Sequence Summary:
File Size Processed: 4.87 GB, Play Time: 01h:25m:40s
59.95 FPS (Average), 7.50 Mbps (Average).
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -27.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
0 of 160655 audio frames found with errors.
0.000000 seconds of audio timestamp gaps.
End of Log
The channel is 720p and like every satellite provider its in HD-Lite PQ.
Xylon is offline
post #3 of 38 Old 08-28-2008, 07:41 PM - Thread Starter
Xylon's Avatar
Code:
        Total   Video
Hannah Montana                                                   AVC     1:22:24 20,341,469,184  48,833,115,022  32.91   21.74   DTS-HD Master 5.1 5476Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
DISC INFO:
Disc Size:      48,833,115,022 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:22:24 (h:m:s)
Total Bitrate:  32.91 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00057.M2TS      20,341,469,184  1:22:24.773     0:00:00.000     1:22:24.773
VIDEO:
Codec               Bitrate         Description
MPEG-4 AVC Video    21742 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         5476 kbps       5.1 / 48kHz / 24-bit / 5476kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48kHz / 640kbps
LPCM Audio                      English         1536 kbps       2.0 / 48kHz / 16-bit / 1536kbps
Dolby Digital Audio             Portuguese      192 kbps        2.0 / 48kHz / 192kbps
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         10 kbps
Presentation Graphics           English         369 kbps
Presentation Graphics           French          6 kbps
Presentation Graphics           Portuguese      9 kbps
Presentation Graphics           Portuguese      1 kbps
Presentation Graphics           Spanish         8 kbps
Presentation Graphics           Spanish         1 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:02:19.806     19,562 kbps     39,459 kbps     00:00:45.254    29,161 kbps     00:00:32.449    28,443 kbps     00:00:32.449    101,986 bytes   475,173 bytes   00:00:45.921
2               0:02:19.806     0:09:33.115     23,309 kbps     49,471 kbps     00:09:39.954    33,758 kbps     00:09:39.954    31,283 kbps     00:04:47.162    121,523 bytes   508,509 bytes   00:09:06.546
3               0:11:52.921     0:04:05.870     26,278 kbps     53,407 kbps     00:12:17.695    33,609 kbps     00:12:16.110    32,009 kbps     00:12:17.695    137,003 bytes   503,330 bytes   00:14:09.057
4               0:15:58.791     0:05:08.475     23,266 kbps     43,127 kbps     00:20:04.954    31,376 kbps     00:19:30.628    30,558 kbps     00:18:36.365    121,300 bytes   507,344 bytes   00:20:29.186
5               0:21:07.266     0:03:42.222     24,464 kbps     43,953 kbps     00:22:44.863    33,371 kbps     00:22:41.986    31,595 kbps     00:21:26.452    127,546 bytes   506,512 bytes   00:23:22.860
6               0:24:49.488     0:05:14.940     27,006 kbps     44,876 kbps     00:25:28.402    33,627 kbps     00:25:28.360    32,217 kbps     00:25:28.360    140,795 bytes   470,432 bytes   00:26:31.965
7               0:30:04.428     0:03:47.852     21,593 kbps     34,337 kbps     00:32:40.542    28,934 kbps     00:33:47.317    27,004 kbps     00:31:36.728    112,577 bytes   411,137 bytes   00:33:13.200
8               0:33:52.280     0:04:05.996     21,655 kbps     44,614 kbps     00:37:26.870    30,007 kbps     00:35:17.073    29,609 kbps     00:35:16.114    112,898 bytes   490,130 bytes   00:37:26.953
9               0:37:58.276     0:04:15.213     20,932 kbps     34,813 kbps     00:39:17.772    31,126 kbps     00:41:24.357    29,351 kbps     00:41:19.769    109,128 bytes   445,681 bytes   00:41:28.695
10              0:42:13.489     0:05:15.607     21,463 kbps     40,104 kbps     00:46:36.252    32,098 kbps     00:46:36.168    31,785 kbps     00:46:27.243    111,900 bytes   375,817 bytes   00:46:37.253
11              0:47:29.096     0:04:09.166     23,177 kbps     43,136 kbps     00:47:45.279    32,617 kbps     00:47:45.279    30,254 kbps     00:47:54.747    120,836 bytes   457,172 bytes   00:50:40.871
12              0:51:38.262     0:04:49.539     21,131 kbps     33,340 kbps     00:52:55.464    31,018 kbps     00:52:51.627    29,084 kbps     00:52:47.289    110,170 bytes   517,829 bytes   00:52:15.424
13              0:56:27.801     0:04:08.248     20,740 kbps     43,377 kbps     00:59:24.186    32,313 kbps     00:59:21.683    27,390 kbps     00:59:20.098    108,128 bytes   387,310 bytes   00:59:24.269
14              1:00:36.049     0:03:33.005     21,428 kbps     37,460 kbps     01:02:00.842    29,680 kbps     01:02:58.316    27,154 kbps     01:02:58.441    111,715 bytes   423,532 bytes   01:03:36.062
15              1:04:09.054     0:05:32.248     19,506 kbps     30,672 kbps     01:07:04.938    26,469 kbps     01:07:18.409    23,687 kbps     01:09:24.202    101,698 bytes   502,844 bytes   01:04:10.638
16              1:09:41.302     0:04:22.012     22,049 kbps     36,522 kbps     01:12:57.248    30,930 kbps     01:12:40.606    29,761 kbps     01:12:35.643    114,954 bytes   683,668 bytes   01:12:45.570
17              1:14:03.314     0:08:21.459     15,174 kbps     38,228 kbps     01:14:36.806    32,125 kbps     01:14:36.806    30,773 kbps     01:14:28.798    79,112 bytes    536,221 bytes   01:15:10.881
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00057.M2TS      4113 (0x1011)   0x1B            4944.77         13,438,654,312  73,105,895      21,742
00057.M2TS      4352 (0x1100)   0x86            4944.77         3,384,477,644   19,164,846      5,476
00057.M2TS      4353 (0x1101)   0x80            4944.77         949,396,800     5,933,730       1,536
00057.M2TS      4354 (0x1102)   0x81            4944.77         395,584,000     2,317,875       640
00057.M2TS      4355 (0x1103)   0x81            4944.77         118,675,200     772,625         192
00057.M2TS      4356 (0x1104)   0x81            4944.77         395,584,000     2,317,875       640
00057.M2TS      4357 (0x1105)   0x81            4944.77         118,675,200     772,625         192
00057.M2TS      4608 (0x1200)   0x90            4944.77         5,997,839       34,841          10
00057.M2TS      4609 (0x1201)   0x90            4944.77         228,230,679     1,269,218       369
00057.M2TS      4610 (0x1202)   0x90            4944.77         3,978,799       23,361          6
00057.M2TS      4611 (0x1203)   0x90            4944.77         4,973,968       28,952          8
00057.M2TS      4612 (0x1204)   0x90            4944.77         5,528,380       32,005          9
00057.M2TS      4613 (0x1205)   0x90            4944.77         482,693         2,795           1
00057.M2TS      4614 (0x1206)   0x90            4944.77         488,726         2,816           1
Xylon is offline
post #4 of 38 Old 08-28-2008, 07:41 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 38 Old 08-28-2008, 07:41 PM - Thread Starter
Xylon's Avatar
The behind the scene stuff is not in 3D.
Xylon is offline
post #6 of 38 Old 08-28-2008, 08:11 PM
Kram Sacul's Avatar
Where's my anaglyph glasses? This is the most important comparison of our time.
Kram Sacul is offline
post #7 of 38 Old 08-29-2008, 12:37 AM
CraigCooper's Avatar
Oh no you didn't
CraigCooper is offline
post #8 of 38 Old 08-29-2008, 12:48 AM
whitestang06's Avatar
Miley Cyrus makes me feel like a pervert.
whitestang06 is offline
post #9 of 38 Old 08-29-2008, 06:39 AM
Kram Sacul's Avatar
A definite upgrade from the broadcast and dvd versions. Too they just didn't put both the right and left eye versions on there so those with with the equipment and time could figure out how to turn it into 3-D that can be used with polorized 3-D glasses.
post #10 of 38 Old 08-29-2008, 07:25 AM
jkcheng122's Avatar
Quoted: 215 Post(s)
Liked: 181
does the disc come with color calibrations? otherwise wouldnt ppl who dont have their tv settings done right (esp those who put their sets on dynamic) not be able to see 3D correctly?
these pictures should kill off any idea that HD broadcasts or downloads can rival Blu-ray in quality. i still laugh when i see DishHD mentioning their VOD movies are now Blu-ray quality just b/c it's at 1080p.
jkcheng122 is offline
post #11 of 38 Old 08-29-2008, 07:47 AM
Cinema Squid's Avatar
What's the story with the Portuguese and Spanish audio tracks? Is the musical performance actually dubbed into these two languages with, presumably, a different singer?
Very curious...foreign language audio tracks are not something you'd expect on a concert release.
EDIT: Never mind, I answered my own question by searching around - supposedly just the dialog/conversational parts are dubbed with the songs left intact.
Cinema Squid is offline
post #12 of 38 Old 08-29-2008, 09:04 AM
GregK's Avatar
Any more anaglyphic 3-D pics to share?
GregK is offline
post #13 of 38 Old 08-29-2008, 04:34 PM
joerod's Avatar
Quoted: 1120 Post(s)
Liked: 1196
Great pics! My Daughter wanted to read this thread. Seriously...
4K HDR10- ignore the “rules” and trust your eyes!
joerod is offline
post #14 of 38 Old 08-29-2008, 07:37 PM
Rieper's Avatar
Quoted: 251 Post(s)
Liked: 104
Hahah, Xylon, you perv!!!
At least this is one comparison thread all your own...you can forget about eric.exe trying to compete with your thread here.
Rieper is offline
post #15 of 38 Old 08-30-2008, 04:14 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #16 of 38 Old 08-30-2008, 04:14 AM - Thread Starter
Xylon's Avatar
Originally Posted by CraigCooper View Post
Oh no you didn't
Oh yes I did!
Xylon is offline
post #17 of 38 Old 08-31-2008, 04:21 AM - Thread Starter
Xylon's Avatar
Did not see any calibrations in the disc.
Xylon is offline
post #18 of 38 Old 08-31-2008, 11:05 AM
hobbs47's Avatar
Quoted: 454 Post(s)
Liked: 474
Benq HT3550/LG OLED65B6P /Panny UB820 4k Bluray/Apple TV 4k
Nvidia Shield/HDFury AVRkey/Samsung HW-K950 Soundbar
hobbs47 is offline
post #19 of 38 Old 09-01-2008, 08:59 AM
Preditor
Jet-X's Avatar
Quoted: 35 Post(s)
Liked: 35
When I see commentary in various publications or blogs on "why HD on Demand will over take Blu-Ray" and then I see these screen captures, uh, yeah, right...Blu-Ray for me.
Nice job Xylon.
Jet-X is offline
post #20 of 38 Old 09-06-2008, 10:58 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #21 of 38 Old 09-07-2008, 01:27 AM
ChuckZ's Avatar
If LazyTown ever gets a domestic Blu-ray release, all of us in this thread are done for.
ChuckZ is offline
post #22 of 38 Old 09-11-2008, 07:44 PM
David Susilo's Avatar
Quoted: 751 Post(s)
Liked: 648
I find that with these anaglyph releases (Spy Kids 3D etc included) I always see shadowing (image doubling) as opposed to clear 3D depth. Is this due to my eyes or my TV settings? (all 4 of my TVs are ISF calibrated). I only see very extremely slight doubling in the theatres but the home version is very apparent. Furthermore I don't think anaglyph to be the problem because when I look at anaglyph comic books, I don't see doubling at all.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #23 of 38 Old 09-11-2008, 09:22 PM
cnikirk's Avatar
Originally Posted by hobbs47 View Post
Ha! Lol, this is great. Well at least we didn't meet her in a chat room. She is awfully cute.
cnikirk is offline
post #24 of 38 Old 09-28-2008, 06:10 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #25 of 38 Old 09-28-2008, 08:15 AM
GregK's Avatar
There's a reason for that. Anaglyph is what I refer to as a VERY fragile format. And that increases times two or three when color anaglyph is attempted. And when a stereoscopic source is encoded as a "Color" anaglyph in an attempt to preserve the original colors, it often distorts color and can inadvertently increases crosstalk. Most anaglyph comic books do what is called B&W anaglyph.
But more to the point- With comic books, b&w anaglyph can use selective inks to optimize color accuracy. Color can also be optimized on a computer. When I make an anaglyph jpeg, I don't handle it like I would make a standard jpeg. The color is degraded in typical jpeg encodes .. which can result in increased ghosting. The same goes for video. In both the analog and digital consumer delivery formats for video, the image is compressed in some form or another to get it to fit in the space needed. While digital provides component video, which helps reduce ghosting, the color spectrum in both digital SD and HD is decimated quite a bit. Unlike a professional video master which is often 4:4:4 (the color has full bandwidth), DVD and all of the Blu-Ray video specified video codecs are 4:2:0. That's a big limitation for anaglyph on video, right after color anaglyph encoding. Because it is HD, Blu inherently provides more chroma bandwidth than DVD, so it's a smidge better ..but still has the 4:2:0 limitation.
GregK is offline
post #26 of 38 Old 09-28-2008, 08:19 AM
Quoted: 751 Post(s)
Liked: 648
Thanks GregK for the explanation.
However, it still doesn't explain (or I just don't get it ) why I still see doubling (although at a far less severity, not distracting, but still noticable) at Disney World (polarization technique, with digital projection) and at Imax (LCD sequential technique).
my home theatre
post #27 of 38 Old 09-28-2008, 08:43 AM
GregK's Avatar
Each 3-D delivery format can have crosstalk if various things are not set up properly. Add to that "torture test" material with high contrasts, and ghosting may be more noticable during those times than in others. There are things that can be done with each respective 3-D format to minimize or totally eliminate crosstalk, depending on the 3-D format and the given set-up. One could end up writing a book on the subject, but just remember anaglyph is by far normally the worst offender.
GregK is offline
post #28 of 38 Old 09-28-2008, 10:44 AM
GregK's Avatar
Xylon, I just noticed you posted a new 3-D pic earlier today! ...Is it possible for you to post a "gimmick" 3-D shot, like the 2-D pics shown in post #2?
GregK is offline
post #29 of 38 Old 09-29-2008, 05:22 AM - Thread Starter
Xylon's Avatar
Sure, just keep watching this Chris Hans . . . . . eerr Miley Cyrus thread
Xylon is offline
post #30 of 38 Old 11-30-2008, 05:55 AM - Thread Starter
Xylon's Avatar
Xylon is offline
Reply Blu-ray Software
