The Fast and the Furious comparison *PIX* - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 04-05-2009, 03:41 AM - Thread Starter
Xylon's Avatar
Excellent PQ on both HD DVD and Blu-ray. But which one is better? By AVS standard? Well, that will be Blu-ray. It has little bit less artifacting on fast motion. It won't be discernible while in motion doing side by side comparison but its there.
If you are willing to pay for the boxset which is very unfortunate since this movie is the only one worth watching and reviewing for me. Its a safe buy. No additional DNR. Universal batting 1.000 this year.
Xylon is offline
post #2 of 26 Old 04-05-2009, 03:41 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #3 of 26 Old 04-05-2009, 03:41 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #4 of 26 Old 04-05-2009, 03:42 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 26 Old 04-05-2009, 03:42 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #6 of 26 Old 04-05-2009, 03:42 AM - Thread Starter
Xylon's Avatar
HD DVD File size: 18.0 GB
Bitrate: 18.79 mbps
Code:
        Total   Video
Title                                   Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track        IME     Secondary Audio Track
The Fast and the Furious                VC-1    1:46:50 18,338,797,568*~25,360,692,683  22.88  ~18.79   DDPlus 5.1 1536Kbps     Yes
Blu-ray File size: 40.00 GB
Bitrate: 28.52 mbps
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:46:57 31,568,916,480  41,288,419,802  39.35   28.52   DTS-HD Master 5.1
4590Kbps (48kHz/24-bit)
DISC INFO:
Disc Title:     TFATF
Disc Size:      41,288,419,802 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 1:46:57 (h:m:s)
Total Bitrate:          39.35 Mbps
Description:
VIDEO:
VC-1 Video              28517 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              2001 kbps           480p / 23.976 fps / 4:3 / Advanced Profile 2
VC-1 Video              84 kbps             480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         4590 kbps       5.1 / 48 kHz / 4590 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         29.488 kbps
Presentation Graphics           French          24.896 kbps
Presentation Graphics           Spanish         24.598 kbps
FILES:
00010.M2TS      0:00:00.000     1:46:57.411     31,568,916,480  39,354
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max
10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:02:56.885     28,419 kbps     44,271 kbps     00:01:15.492    35,484 kbps     00:01:14.365    33,410 kbps
00:01:23.500    148,936 bytes   496,424 bytes   00:00:39.122
2               0:02:56.885     0:07:23.359     30,138 kbps     43,935 kbps     00:04:11.876    37,434 kbps     00:04:31.521    35,478 kbps
00:03:04.809    157,126 bytes   554,449 bytes   00:03:26.831
3               0:10:20.244     0:04:47.287     29,288 kbps     38,411 kbps     00:10:31.922    32,758 kbps     00:13:24.011    31,145 kbps
00:13:23.844    152,694 bytes   492,141 bytes   00:14:21.485
4               0:15:07.531     0:11:32.942     28,667 kbps     44,037 kbps     00:16:48.674    36,358 kbps     00:17:06.108    35,007 kbps
00:16:35.244    149,454 bytes   512,979 bytes   00:17:58.994
5               0:26:40.473     0:03:18.740     29,352 kbps     40,970 kbps     00:29:27.807    35,088 kbps     00:29:23.845    32,651 kbps
00:29:18.798    153,026 bytes   500,231 bytes   00:27:02.120
6               0:29:59.214     0:04:43.658     29,787 kbps     38,817 kbps     00:30:24.447    35,068 kbps     00:30:20.819    34,399 kbps
00:32:22.774    155,293 bytes   403,140 bytes   00:34:42.872
7               0:34:42.872     0:03:25.622     30,756 kbps     42,856 kbps     00:37:15.483    37,414 kbps     00:38:03.489    34,910 kbps
00:36:17.550    160,347 bytes   535,932 bytes   00:37:14.148
8               0:38:08.494     0:06:47.907     29,656 kbps     47,059 kbps     00:38:48.200    36,233 kbps     00:39:37.833    34,624 kbps
00:39:38.000    154,615 bytes   569,115 bytes   00:40:56.287
9               0:44:56.402     0:10:30.087     29,120 kbps     44,929 kbps     00:53:33.710    38,530 kbps     00:51:34.591    34,639 kbps
00:46:06.054    151,821 bytes   614,747 bytes   00:53:32.584
10              0:55:26.489     0:03:13.943     23,303 kbps     36,841 kbps     00:55:29.492    33,556 kbps     00:55:27.949    32,594 kbps
00:55:27.324    121,491 bytes   447,111 bytes   00:57:45.712
11              0:58:40.433     0:03:05.310     27,560 kbps     45,391 kbps     01:00:44.140    37,012 kbps     01:00:43.973    34,017 kbps
01:00:42.347    143,686 bytes   470,727 bytes   01:00:47.101
12              1:01:45.743     0:07:39.375     29,465 kbps     42,820 kbps     01:02:33.833    34,160 kbps     01:01:53.918    33,751 kbps
01:01:53.918    153,615 bytes   673,613 bytes   01:03:06.783
13              1:09:25.119     0:02:36.906     30,753 kbps     45,607 kbps     01:11:01.215    35,240 kbps     01:11:11.934    33,828 kbps
01:11:11.767    160,333 bytes   523,285 bytes   01:11:01.257
14              1:12:02.026     0:03:21.659     30,547 kbps     43,422 kbps     01:12:57.456    35,031 kbps     01:12:53.535    34,512 kbps
01:12:48.530    159,258 bytes   525,258 bytes   01:12:55.079
15              1:15:23.685     0:05:20.486     25,950 kbps     38,383 kbps     01:15:53.799    32,993 kbps     01:15:51.129    31,894 kbps
01:15:46.291    135,294 bytes   514,173 bytes   01:17:55.420
16              1:20:44.172     0:09:15.638     28,041 kbps     39,727 kbps     01:25:49.936    32,447 kbps     01:21:57.704    31,034 kbps
01:27:10.767    146,193 bytes   424,717 bytes   01:28:55.455
17              1:29:59.811     0:04:58.506     29,230 kbps     39,843 kbps     01:31:41.412    33,172 kbps     01:33:33.816    31,664 kbps
01:32:18.407    152,390 bytes   589,825 bytes   01:33:32.857
18              1:34:58.317     0:03:07.145     29,075 kbps     42,244 kbps     01:35:52.788    34,589 kbps     01:35:22.633    32,429 kbps
01:35:22.466    151,581 bytes   565,040 bytes   01:36:35.414
19              1:38:05.462     0:01:52.529     29,090 kbps     42,618 kbps     01:39:29.546    35,199 kbps     01:39:28.671    33,061 kbps
01:39:28.671    151,661 bytes   537,969 bytes   01:39:08.192
20              1:39:57.992     0:06:59.418     23,370 kbps     41,657 kbps     01:45:09.553    34,447 kbps     01:46:37.474    32,485 kbps
01:46:32.469    122,033 bytes   599,705 bytes   01:45:03.422
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Language                Seconds                 Bitrate                 Bytes
Packets
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    6417.286                28,518                  22,875,721,905
124,417,319
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6417.286                4,591                   3,682,385,432
21,013,594
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           6417.286                768                     616,072,192
3,609,798
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6417.286                768                     616,072,192
3,609,798
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6417.286                192                     154,018,560
1,002,725
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6417.286                29                      23,654,487
136,935
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6417.286                25                      19,732,120
113,664
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6417.286                25                      19,971,163
114,956
00010.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           6417.286                192                     154,019,840
902,460
00010.M2TS      6912 (0x1B00)   0xEA            VC-1                                    6417.286                2,001                   1,605,232,829
8,816,634
00010.M2TS      6913 (0x1B01)   0xEA            VC-1                                    6417.286                84                      67,738,712
468,534
Xylon is offline
post #7 of 26 Old 04-05-2009, 05:17 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
BD cap looks better than the HD DVD with slightly elevated contrast/black levels and fine grain structure.
Blu-ray : 340
lgans316 is offline
post #8 of 26 Old 04-05-2009, 06:30 AM
this BD was the reference for sound quality,the engine sound kicked my room.
butsu is offline
post #9 of 26 Old 04-05-2009, 09:16 AM
Toe
Toe's Avatar
Quoted: 2661 Post(s)
Liked: 3383
I dont see any significant dif.
Toe is offline
post #10 of 26 Old 04-05-2009, 09:50 AM
AmishFury's Avatar
similar improvement as seen with the bourne trilogy (though a little less obvious)
not quite enough to make me trade in my HD DVD (unless i find the bluray dirt cheap)
AmishFury is offline
post #11 of 26 Old 04-05-2009, 10:38 AM
rover2002's Avatar
HD DVD has noticeable blocking in the close ups.
rover2002 is offline
post #12 of 26 Old 04-05-2009, 02:08 PM
Rieper's Avatar
Quoted: 251 Post(s)
Liked: 104
Anyone have trouble with the dialog/center channel audio on The Fast and the Furious 1? The sound effects were pumped up way loud, and the dialog seemed it was recorded too low.
Rieper is offline
post #13 of 26 Old 04-05-2009, 06:22 PM
rover2002's Avatar
Where do you have your Center speaker?
post #14 of 26 Old 04-05-2009, 07:09 PM
iSean's Avatar
I noticed this too.
iSean is offline
post #15 of 26 Old 04-05-2009, 07:17 PM
phisch's Avatar
Quoted: 63 Post(s)
Liked: 47
They look very close to me. I'll probably hold on to my HD DVD for awhile.
phisch is offline
post #16 of 26 Old 04-05-2009, 07:36 PM
joemama127's Avatar
You have better eyes than me....I have a NEC 20WMGX2 (AS-IPS panel) calibrated with an Eye-one Pro and I can't much if any difference at all..
"The quickest way to get over your fear of plasma is to actually own *one"- joemama127
*or 3 :)
joemama127 is offline
post #17 of 26 Old 04-05-2009, 11:54 PM
ChuckZ's Avatar
This is exactly like the Bourne releases; excellent PQ but now more finely resolved grain structure! They are plenty good enough on HD DVD, but get that little extra oomph on Blu-ray. You'd really never notice the blocking artifacts in the scene with Paul Walker, but it's great that they didn't re-purpose the old transfer.
ChuckZ is offline
post #18 of 26 Old 04-06-2009, 09:12 AM
Rieper's Avatar
Quoted: 251 Post(s)
Liked: 104
Check out the Paul Walker face comparison.
There seems to be some slight horizontal stretching on the Blu-ray version...
Rieper is offline
post #19 of 26 Old 04-06-2009, 04:39 PM
Mr. Hanky's Avatar
Quoted: 124 Post(s)
Liked: 99
For those still on the fence on if the blocking is there or not there, here is an assist on where to look:
hdvd HFview
br HFview
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #20 of 26 Old 04-06-2009, 05:16 PM
Stevie76's Avatar
Holy crap! the HD-DVD is a blockfest in comparision.
Though I doubt I would be able to notice it in motion
Thanx again Universal for NOT using DNR
Stevie76 is offline
post #21 of 26 Old 04-06-2009, 07:06 PM
Mr. Hanky's Avatar
Quoted: 124 Post(s)
Liked: 99
If you can't see it, it didn't happen!
post #22 of 26 Old 04-06-2009, 07:38 PM
AmishFury's Avatar
nope... if you really want to test put your mouse pointer on any reference point then scroll up/down
post #23 of 26 Old 04-06-2009, 07:53 PM
Deviation's Avatar
Your eyes are playing tricks on you.
Deviation is offline
post #24 of 26 Old 04-07-2009, 02:50 AM
Stevie76's Avatar
+1
There is NO stretching at all compared to the HD-DVD.
Stevie76 is offline
post #25 of 26 Old 04-07-2009, 05:49 AM
metalsaber's Avatar
Quoted: 1048 Post(s)
Liked: 858
They look pretty much the same to me. The only reason I'd want to upgrade would be for the sound.
metalsaber is offline
post #26 of 26 Old 04-12-2009, 05:39 AM - Thread Starter
Xylon's Avatar
Xylon is offline
Reply Blu-ray Software
