Scrubs: 16x9 vs 4x3 comparison - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-25-2009, 12:13 PM - Thread Starter
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
So...
With the announcement of Scrubs season 8 on Blu-ray, there has been some debate as to whether the other 7 seasons would benefit from a blu-ray transfer. I took my HD capture of the last eppy (which began with flashbacks of the very first episode) and compared it to the DVD version. The results are below.
There is some slight cropping at the top and bottom but there is definitely more information on the sides. I wonder if this means HD versions of all 7 seasons could follow? 8 comes out in November.
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #2 of 7 Old 05-25-2009, 01:13 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Nice, it was probably protected for 16:9, and I'm guessing we'll see widescreen versions of several shows from around that time (stuff like Six Feet Under which only had 4:3 DVDs for the early seasons.)
paku is offline
post #3 of 7 Old 05-25-2009, 01:16 PM
giantchicken's Avatar
So you're gaining information on the sides, but losing information on the top and bottom. Look at the contents of the red box in that last picture. Interesting.
PETER JACKSON: The theatrical versions are the definitive versions.
giantchicken is offline
post #4 of 7 Old 05-25-2009, 01:30 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
It was likely shot on Super16 (with an aspect ratio of 1.66:1), so that the full frame is somewhere between 4:3 and 16:9 makes sense.
paku is offline
post #5 of 7 Old 05-25-2009, 01:51 PM - Thread Starter
Quoted: 127 Post(s)
what's the max resolution of Super16?
post #6 of 7 Old 05-25-2009, 04:56 PM
SirDrexl's Avatar
Well, this is one where I don't know how I feel.
I am very much against the practice of forcing widescreen on material that was originally composed for 4:3. (OAR is not just about preserving widescreen.) That also goes for material that may have been protected for 16:9. After all, people are up in arms when a DVD is released open matte. As with open matte, what matters is what it was composed for, not what it was shot in.
Here, I'm just not sure what the OAR is. It may be a case where neither is really "correct."
SirDrexl is offline
post #7 of 7 Old 05-25-2009, 05:40 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
No idea, but it's certainly enough to make use of 1080p. The thing about 16mm is that the harsher grain size likely means the image is more susceptible to manipulation like DNR, sharpening and poor compression, so you really need a quality transfer to make the most of it.
paku is offline
Reply Blu-ray Software
