NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #331 of 5106 Old 08-25-2009, 08:22 PM
sschen's Avatar
Quoted: 47 Post(s)
Originally Posted by Cinema Squid View Post
There is a distinct possibility BDInfo was wrong when it said 16-bit, since it just makes a guess. In fact, I'll assume it's wrong and change the entry since, as you say, the numbers don't make much sense. If someone has the UK disc and time to check the actual bit-depth with eac3to that would be appreciated.
I actually have the UK Steelbook version of Sweeney Todd, I am sure the disk is the same as the regular amaray version.
With this check that you are requesting, how is it done? Is eac3to a software I can download? If so, where to download it from? I have a LG HD-DVD/BD combo drive so I can certainly check the disk for you
sschen is online now
post #332 of 5106 Old 08-25-2009, 09:29 PM
Snowknight26's Avatar
Quoted: 31 Post(s)
Hot Fuzz
US Release
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:00:52 32,495,069,184  46,481,716,079  35.84   25.56   DTS-HD Master 5.1 4147Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     HOT_FUZZ
Disc Size:      46,481,716,079 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:00:52 (h:m:s)
Total Bitrate:          35.84 Mbps
Description:
VIDEO:
VC-1 Video              25565 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              750 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
VC-1 Video              617 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         4147 kbps       5.1 / 48 kHz / 4147 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         48.078 kbps
Presentation Graphics           French          32.716 kbps
Presentation Graphics           Spanish         41.999 kbps
FILES:
00010.M2TS      0:00:00.000     2:00:52.662     32,495,069,184  35,843
CHAPTERS:
1               0:00:00.000     0:02:26.646     24,592 kbps     46,711 kbps     00:02:09.504    34,362 kbps     00:01:06.775    33,368 kbps     00:01:05.315    129,836 bytes   493,305 bytes   00:02:09.712
2               0:02:26.646     0:02:56.968     25,635 kbps     38,085 kbps     00:02:37.824    34,574 kbps     00:02:34.946    30,759 kbps     00:02:29.941    133,647 bytes   337,892 bytes   00:03:36.966
3               0:05:23.614     0:01:52.529     24,175 kbps     44,200 kbps     00:05:23.781    35,696 kbps     00:05:35.835    34,770 kbps     00:05:23.698    126,040 bytes   451,907 bytes   00:05:40.631
4               0:07:16.144     0:04:54.210     23,208 kbps     42,093 kbps     00:07:30.158    36,469 kbps     00:07:28.406    33,526 kbps     00:07:23.359    121,013 bytes   349,960 bytes   00:07:18.146
5               0:12:10.354     0:01:57.283     26,178 kbps     45,260 kbps     00:13:46.700    34,887 kbps     00:14:01.966    32,832 kbps     00:13:57.086    136,479 bytes   384,473 bytes   00:13:50.663
6               0:14:07.638     0:07:31.951     25,345 kbps     40,150 kbps     00:17:20.539    34,012 kbps     00:14:14.144    33,701 kbps     00:17:19.663    132,137 bytes   369,316 bytes   00:14:16.355
7               0:21:39.589     0:04:08.414     25,147 kbps     38,360 kbps     00:25:18.975    33,150 kbps     00:25:15.889    31,402 kbps     00:24:53.200    131,106 bytes   328,515 bytes   00:25:09.549
8               0:25:48.004     0:02:58.678     26,242 kbps     41,657 kbps     00:28:41.761    35,076 kbps     00:27:09.669    32,360 kbps     00:27:17.969    136,816 bytes   330,592 bytes   00:27:27.395
9               0:28:46.683     0:03:22.160     30,386 kbps     49,193 kbps     00:31:19.127    35,716 kbps     00:31:18.459    33,932 kbps     00:31:19.127    158,421 bytes   463,349 bytes   00:31:19.752
10              0:32:08.843     0:03:19.157     24,032 kbps     42,007 kbps     00:33:05.233    32,754 kbps     00:33:02.647    28,665 kbps     00:34:45.625    125,293 bytes   368,402 bytes   00:32:13.181
11              0:35:28.000     0:03:39.969     26,203 kbps     38,015 kbps     00:36:08.207    32,824 kbps     00:36:19.510    30,973 kbps     00:36:14.463    136,612 bytes   354,755 bytes   00:36:16.799
12              0:39:07.970     0:03:04.225     24,990 kbps     44,824 kbps     00:40:07.154    34,246 kbps     00:40:06.487    29,884 kbps     00:40:02.400    130,286 bytes   363,578 bytes   00:42:12.196
13              0:42:12.196     0:02:44.038     28,540 kbps     45,862 kbps     00:42:14.073    37,555 kbps     00:44:35.255    33,923 kbps     00:43:55.966    148,794 bytes   464,316 bytes   00:43:51.754
14              0:44:56.235     0:04:30.269     20,915 kbps     39,712 kbps     00:47:46.029    30,728 kbps     00:47:44.945    28,653 kbps     00:47:41.733    109,043 bytes   333,801 bytes   00:48:53.889
15              0:49:26.505     0:05:32.123     26,731 kbps     46,370 kbps     00:51:57.113    36,777 kbps     00:52:25.517    34,815 kbps     00:54:43.738    139,365 bytes   358,940 bytes   00:52:27.853
16              0:54:58.628     0:06:46.656     27,152 kbps     41,048 kbps     00:58:11.070    34,946 kbps     00:58:07.442    33,036 kbps     00:57:04.546    141,560 bytes   495,455 bytes   00:59:31.859
17              1:01:45.284     0:07:39.333     24,637 kbps     40,341 kbps     01:04:38.082    35,622 kbps     01:06:44.208    33,503 kbps     01:03:33.226    128,444 bytes   347,191 bytes   01:02:32.415
18              1:09:24.618     0:07:34.287     26,228 kbps     42,687 kbps     01:13:46.839    36,188 kbps     01:11:14.436    35,041 kbps     01:11:08.389    136,803 bytes   475,030 bytes   01:11:26.782
19              1:16:58.905     0:02:16.219     29,730 kbps     41,352 kbps     01:17:43.950    36,110 kbps     01:17:46.119    35,134 kbps     01:17:41.365    154,999 bytes   439,324 bytes   01:16:59.948
20              1:19:15.125     0:09:44.417     25,797 kbps     44,431 kbps     01:22:22.062    34,564 kbps     01:25:49.894    32,676 kbps     01:26:12.333    134,492 bytes   432,730 bytes   01:21:51.031
21              1:28:59.542     0:02:40.910     28,903 kbps     46,950 kbps     01:30:24.836    36,783 kbps     01:31:01.330    35,127 kbps     01:30:55.032    151,157 bytes   462,727 bytes   01:29:02.587
22              1:31:40.453     0:09:33.739     29,505 kbps     45,094 kbps     01:32:55.027    37,186 kbps     01:38:07.882    35,586 kbps     01:35:26.387    153,838 bytes   443,145 bytes   01:38:17.641
23              1:41:14.193     0:04:16.547     30,727 kbps     45,823 kbps     01:41:18.614    35,765 kbps     01:41:14.902    33,433 kbps     01:41:14.902    160,197 bytes   418,283 bytes   01:45:29.197
24              1:45:30.741     0:05:18.609     30,030 kbps     46,627 kbps     01:49:06.706    35,621 kbps     01:47:26.398    33,778 kbps     01:47:25.480    156,560 bytes   414,875 bytes   01:49:54.462
25              1:50:49.351     0:01:12.822     30,318 kbps     38,513 kbps     01:50:58.068    34,586 kbps     01:50:57.817    33,048 kbps     01:51:04.157    158,063 bytes   409,598 bytes   01:51:12.540
26              1:52:02.173     0:01:52.612     29,912 kbps     42,652 kbps     01:52:22.986    35,235 kbps     01:52:04.134    34,651 kbps     01:52:04.134    155,949 bytes   355,894 bytes   01:52:23.445
27              1:53:54.786     0:01:20.246     28,789 kbps     38,055 kbps     01:55:09.402    34,130 kbps     01:53:55.286    32,712 kbps     01:53:55.370    150,092 bytes   507,291 bytes   01:54:09.801
28              1:55:15.033     0:05:37.628     4,248 kbps      42,146 kbps     01:55:15.450    21,250 kbps     01:55:15.033    12,980 kbps     01:55:15.033    22,422 bytes    389,579 bytes   01:55:15.742
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    7252.537                25,565                  23,176,374,546  126,063,545
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7252.537                4,147                   3,759,337,644   21,562,984
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           7252.537                768                     696,256,512     4,079,628
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            7252.537                768                     696,256,512     4,079,628
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7252.537                192                     174,064,128     1,133,230
00010.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           7252.537                192                     174,064,128     1,133,230
00010.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7252.537                192                     174,064,128     1,133,230
00010.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           7252.537                192                     174,064,128     1,133,230
00010.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           7252.537                192                     174,064,128     1,133,230
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7252.537                48                      43,586,789      251,093
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7252.537                42                      38,075,825      217,783
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7252.537                33                      29,659,650      171,281
00010.M2TS      6912 (0x1B00)   0xEA            VC-1                                    7252.537                750                     679,755,199     3,780,785
00010.M2TS      6913 (0x1B01)   0xEA            VC-1                                    7252.537                617                     559,691,008     3,129,279
Snowknight26 is offline
post #333 of 5106 Old 08-25-2009, 10:56 PM
msgohan's Avatar
I didn't know it was possible for a movie to have two PiP tracks?
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #334 of 5106 Old 08-26-2009, 12:08 AM - Thread Starter
Cinema Squid's Avatar
Originally Posted by Gekkou View Post
Thanks very much for the swift reply and info! I didn't know how BDInfo worked when it came to finding bit-depth.
Life is a little easier with DTS-HD, since it records the constant bit-depth in the header, but TrueHD is not required to have a constant bit-depth which complicates the situation and makes it necessary to decode and examine every audio sample if you want to know for sure what the average and maximum bit-depth is. Most of the time, a reasonable deduction can be made from the average and peak audio bitrates but this is not completely reliable.
There might be a simpler way to do this and if so someone please chime in, but essentially the process is to use eac3to to convert the TrueHD track to LPCM. During this conversion, every sample is examined and the least significant bytes are checked for zeroes to see what the minimum required uncompressed bit depth is required to losslessly represent the track.
The main support thread for eac3to with download link is here:
http://forum.doom9.org/showthread.php?t=125966
In this case, the main stream file is 00000.m2ts, so you should be able to list the contents of this file as follows (where X: is your BD-ROM drive letter):
Code:
eac3to x:\\bdmv\\stream\\00000.m2ts
Assuming the TrueHD track is #3 (which is probably the case), you can convert it as follows (if the TrueHD is somewhere else, change 3: as needed):
Code:
eac3to x:\\bdmv\\stream\\00000.m2ts 3: test.pcm
After the conversion is complete (might take 30+ minutes as can be seen by the last line below), there should be a report printed to the console of whether the TrueHD has a constant or variable bit depth. More information may be perhaps be found in the log.txt file of the eac3to directory.
Code:
M2TS, 1 video track, 3 audio tracks, 2 subtitle tracks, 1:31:17, 24p /1.001
1: Chapters, 12 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48khz
   (embedded: AC3, 5.1 channels, 640kbps, 48khz)
4: AC3, Spanish, 2.0 channels, 192kbps, 48khz
5: AC3 Surround, English, 2.0 channels, 192kbps, 48khz
6: Subtitle (PGS), English
7: Subtitle (PGS), Spanish
a03 Extracting audio track number 3...
a03 Extracting TrueHD stream...
a03 Decoding with libav/ffmpeg...
a03 Swapping endian...
a03 Remapping channels...
a03 Creating file "test.pcm"...
a03 The original audio track has a constant bit depth of 24 bits.
Video track 2 contains 131328 frames.
eac3to processing took 29 minutes, 30 seconds.
Of course, you will probably want to also cleanup the extracted PCM:
Code:
del test.pcm
This seems to be pretty common for Universal with their crazy multiview U-Control schemes. Often, there is an additional graphics overlay or two (i.e. trivia-esque) which is not a video or presentation graphics stream, but is implemented through BD-J, so doesn't show up in the playlists.
Cinema Squid is offline
post #335 of 5106 Old 08-26-2009, 01:49 AM
msgohan's Avatar
There is indeed an easier way. This simple command-line works on Transformers:
Code:
eac3to -analyzebitdepth X:\\BDMV\\STREAM\\00010.m2ts
msgohan is offline
post #336 of 5106 Old 08-26-2009, 03:04 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Tokyo Drift has 4 PiP tracks.
eric.exe is offline
post #337 of 5106 Old 08-26-2009, 07:28 AM
sschen's Avatar
Quoted: 47 Post(s)
Code:
I just downloaded the eac2to zip file so I am trying it out with the above command on the command line first. There is no 00010.m2ts file on the disk so I am using the tool to analyze 00000.m2ts which has the largest file size.. Here it is:
M2TS, 1 video track, 7 audio tracks, 23 subtitle tracks, 1:56:22, 24p /1.001
1: Chapters, 24 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
4: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
(embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB)
5: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
6: AC3, German, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
7: AC3, Italian, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
8: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
9: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
10: Subtitle (PGS), English
11: Subtitle (PGS), Japanese
12: Subtitle (PGS), French
13: Subtitle (PGS), German
14: Subtitle (PGS), German
15: Subtitle (PGS), Italian
16: Subtitle (PGS), Italian
17: Subtitle (PGS), Spanish
18: Subtitle (PGS), Dutch
19: Subtitle (PGS), Chinese
20: Subtitle (PGS), Korean
21: Subtitle (PGS), Spanish
22: Subtitle (PGS), Portuguese
23: Subtitle (PGS), Danish
24: Subtitle (PGS), Finnish
25: Subtitle (PGS), Norwegian
26: Subtitle (PGS), Portuguese
27: Subtitle (PGS), Swedish
28: Subtitle (PGS), French
29: Subtitle (PGS), German
30: Subtitle (PGS), Italian
31: Subtitle (PGS), Spanish
32: Subtitle (PGS), Spanish
a04 Extracting audio track number 4...
a04 Extracting TrueHD stream...
a04 Decoding with libav/ffmpeg...
a04 libav Lossless check failed - expected 0, calculated 26 <----- not sure why this fails????
a04 The original audio track has a constant bit depth of 16 bits.
Video track 2 contains 167416 frames.
eac3to processing took 29 minutes, 22 seconds.
Done.
post #338 of 5106 Old 08-26-2009, 08:30 AM
Phloyd's Avatar
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [DE] 2007   BloodRayne 2: Deliverance                                       VC-1    1080p24 1.78:1  16.00   1:39:08 16,386,840,576  21,190,963,092  22.04   DTS-HR  5.1    48/16  2046
A number of catch-up titles mixed in here, just in case you were wondering.
The first page has been migrated over to a purely alphabetic listing for reasons of post size limitations as I mentioned in the last update.
This reminds me - it looks like DTS-HD HR that used to report 3039 are now reporting 2046. Is that normal? The PS3 says 3 Mbps for these titles.
BTW, I don't have this one, I have the new BBC titles Dr Who and Torchwood CoE.
Just curious.
Phloyd is offline
post #339 of 5106 Old 08-26-2009, 09:33 AM
House's Avatar
UK version of Labyrinth.
Code:
        Total   Video
Labyrinth                                                       AVC     1:41:03 30,274,363,392  36,612,245,432  39.95   27.41   Dolby TrueHD 5.1 1581Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LABYRINTH
Disc Size:      36,612,245,432 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:41:03 (h:m:s)
Total Bitrate:          39.95 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        27413 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        946 kbps            480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
Dolby TrueHD Audio              English         1581 kbps       5.1 / 48 kHz / 1581 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
Dolby TrueHD Audio              French          1637 kbps       5.1 / 48 kHz / 1637 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
Dolby TrueHD Audio              German          1568 kbps       5.1 / 48 kHz / 1568 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         24.353 kbps
Presentation Graphics           English         19.977 kbps
Presentation Graphics           English         47.119 kbps
Presentation Graphics           Arabic          12.586 kbps
Presentation Graphics           Danish          21.008 kbps
Presentation Graphics           Dutch           20.340 kbps
Presentation Graphics           Dutch           41.894 kbps
Presentation Graphics           Finnish         20.568 kbps
Presentation Graphics           French          20.249 kbps
Presentation Graphics           French          44.649 kbps
Presentation Graphics           French          20.676 kbps
Presentation Graphics           German          23.020 kbps
Presentation Graphics           German          48.628 kbps
Presentation Graphics           German          23.954 kbps
Presentation Graphics           Hindi           21.351 kbps
Presentation Graphics           Norwegian       20.143 kbps
Presentation Graphics           Swedish         19.838 kbps
Presentation Graphics           Turkish         23.673 kbps
FILES:
00011.M2TS      0:00:00.000     1:41:03.057     30,274,363,392  39,946
CHAPTERS:
1               0:00:00.000     0:04:09.207     19,557 kbps     56,200 kbps     00:02:47.375    34,394 kbps     00:02:47.375    31,312 kbps     00:02:47.375    101,946 bytes   776,067 bytes   00:02:47.417
2               0:04:09.207     0:07:35.329     28,812 kbps     38,268 kbps     00:04:47.203    32,600 kbps     00:04:47.078    31,152 kbps     00:04:46.452    150,212 bytes   422,043 bytes   00:06:33.726
3               0:11:44.537     0:05:13.438     27,758 kbps     38,383 kbps     00:11:44.537    30,996 kbps     00:11:51.919    30,222 kbps     00:11:46.872    144,715 bytes   500,117 bytes   00:16:11.679
4               0:16:57.975     0:05:22.780     27,298 kbps     35,795 kbps     00:18:10.506    31,631 kbps     00:19:43.557    30,800 kbps     00:19:38.552    142,321 bytes   522,501 bytes   00:20:03.785
5               0:22:20.756     0:06:32.767     28,631 kbps     36,289 kbps     00:26:48.773    31,939 kbps     00:23:46.425    31,023 kbps     00:26:40.599    149,269 bytes   498,551 bytes   00:26:48.815
6               0:28:53.523     0:04:18.132     27,471 kbps     34,893 kbps     00:28:53.523    30,528 kbps     00:28:53.523    29,462 kbps     00:28:53.523    143,219 bytes   385,232 bytes   00:33:04.190
7               0:33:11.656     0:05:41.341     27,466 kbps     36,671 kbps     00:34:12.133    31,862 kbps     00:33:11.781    30,932 kbps     00:38:20.089    143,195 bytes   501,421 bytes   00:38:52.997
8               0:38:52.997     0:06:12.663     29,124 kbps     38,819 kbps     00:43:08.669    31,672 kbps     00:43:08.544    30,885 kbps     00:42:37.930    151,839 bytes   569,742 bytes   00:42:25.000
9               0:45:05.661     0:05:42.717     27,524 kbps     33,757 kbps     00:46:59.691    29,560 kbps     00:50:20.517    29,270 kbps     00:50:15.804    143,498 bytes   491,064 bytes   00:50:07.546
10              0:50:48.378     0:06:31.641     27,897 kbps     38,434 kbps     00:51:00.766    32,016 kbps     00:57:14.430    31,360 kbps     00:57:08.591    145,442 bytes   504,795 bytes   00:57:06.756
11              0:57:20.019     0:06:05.448     27,783 kbps     40,994 kbps     01:00:41.763    32,437 kbps     01:01:15.880    31,051 kbps     01:01:26.808    144,848 bytes   550,352 bytes   01:01:44.659
12              1:03:25.468     0:06:32.392     28,068 kbps     39,243 kbps     01:09:38.424    31,907 kbps     01:09:37.631    30,588 kbps     01:09:19.864    146,336 bytes   443,035 bytes   01:09:38.632
13              1:09:57.860     0:05:52.268     27,872 kbps     36,182 kbps     01:15:18.472    31,484 kbps     01:15:18.472    30,414 kbps     01:14:17.494    145,310 bytes   417,296 bytes   01:10:15.794
14              1:15:50.128     0:08:15.870     27,874 kbps     37,467 kbps     01:17:53.502    32,054 kbps     01:19:55.207    31,233 kbps     01:19:55.957    145,321 bytes   442,508 bytes   01:18:27.953
15              1:24:05.999     0:06:41.567     28,098 kbps     37,220 kbps     01:24:11.963    31,691 kbps     01:25:16.653    31,090 kbps     01:26:15.086    146,492 bytes   424,102 bytes   01:25:12.398
16              1:30:47.567     0:10:15.489     25,489 kbps     36,690 kbps     01:40:18.554    32,858 kbps     01:38:16.557    31,610 kbps     01:38:15.681    132,907 bytes   459,665 bytes   01:32:56.404
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6062.974                27,413                  20,775,866,362  112,997,873
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6062.974                2,029                   1,538,033,078   11,947,146
00011.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            6062.974                2,085                   1,580,308,310   12,667,288
00011.M2TS      4354 (0x1102)   0x83            TrueHD          deu (German)            6062.974                2,016                   1,527,965,774   11,949,923
00011.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6062.974                192                     145,513,728     947,355
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6062.974                24                      18,456,923      107,160
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6062.974                20                      15,140,275      90,455
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6062.974                20                      15,346,632      88,427
00011.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            6062.974                23                      17,446,704      100,865
00011.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            6062.974                13                      9,538,424       58,510
00011.M2TS      4613 (0x1205)   0x90            PGS             dan (Danish)            6062.974                21                      15,921,736      92,141
00011.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             6062.974                20                      15,415,667      88,213
00011.M2TS      4615 (0x1207)   0x90            PGS             fin (Finnish)           6062.974                21                      15,587,995      90,176
00011.M2TS      4616 (0x1208)   0x90            PGS             hin (Hindi)             6062.974                21                      16,181,653      94,605
00011.M2TS      4617 (0x1209)   0x90            PGS             nor (Norwegian)         6062.974                20                      15,266,148      89,653
00011.M2TS      4618 (0x120A)   0x90            PGS             swe (Swedish)           6062.974                20                      15,034,963      88,376
00011.M2TS      4619 (0x120B)   0x90            PGS             tur (Turkish)           6062.974                24                      17,941,463      104,189
00011.M2TS      4620 (0x120C)   0x90            PGS             eng (English)           6062.974                47                      35,710,337      203,594
00011.M2TS      4621 (0x120D)   0x90            PGS             fra (French)            6062.974                45                      33,838,736      193,117
00011.M2TS      4622 (0x120E)   0x90            PGS             deu (German)            6062.974                49                      36,853,942      209,977
00011.M2TS      4623 (0x120F)   0x90            PGS             nld (Dutch)             6062.974                42                      31,750,861      181,349
00011.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            6062.974                21                      15,670,164      89,541
00011.M2TS      4625 (0x1211)   0x90            PGS             deu (German)            6062.974                24                      18,154,673      103,041
00011.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           6062.974                192                     145,514,496     852,624
00011.M2TS      6912 (0x1B00)   0x1B            AVC                                     6062.974                946                     717,209,583     3,975,717
House is offline
post #340 of 5106 Old 08-26-2009, 10:43 AM
Gekkou's Avatar
Interesting, thanks again.
"Out of the mists of history, the legendary Esquilax! A horse with the head of a rabbit... and the body... of a rabbit."
Gekkou is offline
post #341 of 5106 Old 08-26-2009, 02:37 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 1 Disc 1 Miniseries Parts 1 & 2     VC-1    3:04:09 39,177,117,696  44,362,322,036  28.37   20.61   DTS-HD Master 5.1 4284Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S1_D1
Disc Size:      44,362,322,036 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:04:09 (h:m:s)
Total Bitrate:          28.37 Mbps
Description:
VIDEO:
VC-1 Video              20605 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              1184 kbps           480p / 23.976 fps / 16:9 / Advanced Profile 2
VC-1 Video              199 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         4284 kbps       5.1 / 48 kHz / 4284 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         43.334 kbps
Presentation Graphics           French          38.666 kbps
Presentation Graphics           Spanish         38.510 kbps
FILES:
00368.M2TS      0:00:00.000     1:34:39.298     20,173,664,256  28,417
00369.M2TS      1:34:39.298     1:29:29.989     19,003,453,440  28,311
CHAPTERS:
1               0:00:00.000     1:34:39.298     20,568 kbps     38,124 kbps     00:58:53.571    36,590 kbps     00:58:51.236    34,464 kbps     00:58:46.314    107,606 bytes   436,644 bytes   00:37:35.044
2               1:34:39.298     1:29:29.989     20,644 kbps     42,180 kbps     01:55:14.324    39,218 kbps     02:09:42.149    36,546 kbps     01:36:58.687    107,784 bytes   595,638 bytes   01:55:14.365
STREAM DIAGNOSTICS:
00368.M2TS      4113 (0x1011)   0xEA            VC-1                                    5679.174                20,569                  14,601,818,430  79,439,912
00368.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5679.174                4,303                   3,054,367,924   17,481,848
00368.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5679.174                192                     136,303,872     887,395
00368.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5679.174                45                      32,000,459      182,527
00368.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5679.174                40                      28,499,857      162,779
00368.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5679.174                39                      27,459,187      157,085
00368.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           5679.174                192                     136,304,640     798,660
00368.M2TS      6912 (0x1B00)   0xEA            VC-1                                    5679.174                1,268                   899,824,398     4,981,913
00368.M2TS      6913 (0x1B01)   0xEA            VC-1                                    5679.174                180                     127,663,315     788,750
00369.M2TS      4113 (0x1011)   0xEA            VC-1                                    5369.865                20,644                  13,857,038,058  75,387,688
00369.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5369.865                4,265                   2,862,738,040   16,397,855
00369.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5369.865                192                     128,880,384     839,065
00369.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5369.865                41                      27,851,151      159,464
00369.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5369.865                37                      24,689,259      141,311
00369.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5369.865                39                      25,944,740      148,141
00369.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           5369.865                192                     128,880,640     755,160
00369.M2TS      6912 (0x1B00)   0xEA            VC-1                                    5369.865                1,095                   734,885,550     4,081,107
00369.M2TS      6913 (0x1B01)   0xEA            VC-1                                    5369.865                219                     146,816,353     886,597
eric.exe is offline
post #342 of 5106 Old 08-26-2009, 03:56 PM - Thread Starter
I just double-checked a few DTS-HD titles from my collection with different rates and BDInfo is matching up to what PowerDVD reports as the CBR: Stir of Echoes @ 3039, First Blood @ 3018 and the French/German tracks on The Fog @ 2046.
Are you saying that BDInfo is misreporting the Torchwood and Doctor Who rates, or that I typed in the rates incorrectly for some of the catchup titles? BloodRayne was is in the old thread @ 2046, so I'm not sure if you meant that as an example as well.
Thanks! That is so weird - I guess I have to change the UK Sweeney Todd entry back to 16-bit.
The TrueHD track on the US release of Sweeney Todd tells a different tale:
Code:
16-bit @ 3339 + 24-bit @ 3494 =
post #343 of 5106 Old 08-26-2009, 04:00 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Code:
Perhaps Sweeney Todd UK was scanned with an older version of BDInfo which overstated TrueHD tracks.
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #344 of 5106 Old 08-26-2009, 06:13 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 1 Disc 2 Episodes 1-5               VC-1    3:39:30 40,909,645,824  43,673,752,414  24.85   19.80   DTS-HD Master 5.1 3147Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S1_D2
Disc Size:      43,673,752,414 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:39:30 (h:m:s)
Total Bitrate:          24.85 Mbps
Description:
VIDEO:
VC-1 Video              19802 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              237 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3147 kbps       5.1 / 48 kHz / 3147 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         41.979 kbps
Presentation Graphics           French          36.522 kbps
Presentation Graphics           Spanish         37.600 kbps
FILES:
00063.M2TS      0:00:00.000     0:44:43.680     8,480,894,976   25,281
00065.M2TS      0:44:43.680     0:43:39.617     8,110,012,416   24,767
00066.M2TS      1:28:23.298     0:43:45.372     8,082,825,216   24,630
00067.M2TS      2:12:08.670     0:43:36.447     8,086,499,328   24,725
00068.M2TS      2:55:45.117     0:43:45.205     8,149,413,888   24,834
CHAPTERS:
1               0:00:00.000     0:44:43.680     20,120 kbps     54,046 kbps     00:04:48.329    38,374 kbps     00:31:32.181    35,883 kbps     00:31:32.015    105,381 bytes   539,056 bytes   00:04:49.289
2               0:44:43.680     0:43:39.617     20,046 kbps     45,720 kbps     00:45:49.371    40,186 kbps     01:06:35.533    35,296 kbps     00:54:24.010    104,958 bytes   501,324 bytes   01:18:23.532
3               1:28:23.298     0:43:45.372     19,588 kbps     43,793 kbps     01:57:05.393    36,552 kbps     01:57:02.682    34,818 kbps     01:56:57.343    102,427 bytes   531,410 bytes   01:35:57.877
4               2:12:08.670     0:43:36.447     19,641 kbps     43,306 kbps     02:14:20.260    37,429 kbps     02:15:49.224    35,213 kbps     02:14:20.218    102,757 bytes   473,173 bytes   02:17:40.377
5               2:55:45.117     0:43:45.205     19,607 kbps     47,641 kbps     03:15:05.735    38,148 kbps     03:06:20.335    35,433 kbps     03:06:18.959    102,594 bytes   543,104 bytes   03:28:38.672
STREAM DIAGNOSTICS:
00063.M2TS      4113 (0x1011)   0xEA            VC-1                                    2683.598                20,121                  6,749,543,608   36,721,135
00063.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2683.598                3,214                   1,078,157,000   6,276,574
00063.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2683.598                192                     64,409,088      419,330
00063.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2683.598                38                      12,907,955      74,126
00063.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2683.598                35                      11,897,175      68,004
00063.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2683.598                33                      11,219,825      64,328
00063.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2683.598                229                     76,976,487      457,877
00065.M2TS      4113 (0x1011)   0xEA            VC-1                                    2619.492                20,047                  6,564,189,567   35,712,892
00065.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2619.492                3,019                   988,575,204     5,781,470
00065.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2619.492                44                      14,562,567      83,301
00065.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2619.492                39                      12,783,359      73,060
00065.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2619.492                37                      12,221,754      70,011
00065.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2619.492                220                     72,173,460      431,112
00066.M2TS      4113 (0x1011)   0xEA            VC-1                                    2625.289                19,589                  6,428,238,425   34,974,128
00066.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.289                3,097                   1,016,207,768   5,932,902
00066.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.289                192                     63,009,024      410,215
00066.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.289                49                      16,079,225      92,477
00066.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.289                46                      15,051,992      85,744
00066.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.289                43                      14,059,655      80,357
00066.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2625.289                222                     72,750,536      434,230
00067.M2TS      4113 (0x1011)   0xEA            VC-1                                    2616.364                19,641                  6,423,640,785   34,949,010
00067.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2616.364                3,143                   1,027,985,336   5,996,459
00067.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2616.364                192                     62,794,752      408,820
00067.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2616.364                38                      12,281,570      70,692
00067.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2616.364                32                      10,539,791      60,339
00067.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2616.364                33                      10,919,419      62,408
00067.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2616.364                250                     81,607,532      481,772
00068.M2TS      4113 (0x1011)   0xEA            VC-1                                    2625.081                19,608                  6,433,967,658   35,005,240
00068.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.081                3,258                   1,069,198,868   6,220,288
00068.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.081                192                     63,005,184      410,190
00068.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.081                40                      13,278,422      76,399
00068.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.081                35                      11,628,107      66,354
00068.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.081                36                      11,705,350      66,781
00068.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2625.081                266                     87,129,517      511,626
eric.exe is offline
post #345 of 5106 Old 08-26-2009, 10:17 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 1 Disc 3 Episode 6-10               VC-1    3:38:45 41,861,449,728  44,622,838,116  25.51   20.56   DTS-HD Master 5.1 3076Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S1_D3
Disc Size:      44,622,838,116 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:38:45 (h:m:s)
Total Bitrate:          25.51 Mbps
Description:
VIDEO:
VC-1 Video              20563 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              273 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3076 kbps       5.1 / 48 kHz / 3076 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         43.433 kbps
Presentation Graphics           French          38.592 kbps
Presentation Graphics           Spanish         38.240 kbps
FILES:
00063.M2TS      0:00:00.000     0:43:42.620     8,290,695,168   25,290
00065.M2TS      0:43:42.620     0:43:46.248     8,314,073,088   25,326
00066.M2TS      1:27:28.868     0:43:46.457     8,313,434,112   25,322
00067.M2TS      2:11:15.325     0:43:45.247     8,477,454,336   25,834
00068.M2TS      2:55:00.573     0:43:44.955     8,465,793,024   25,801
CHAPTERS:
1               0:00:00.000     0:43:42.620     20,512 kbps     47,617 kbps     00:20:11.835    38,529 kbps     00:12:01.637    36,790 kbps     00:11:56.006    107,282 bytes   551,087 bytes   00:20:12.461
2               0:43:42.620     0:43:46.248     20,405 kbps     49,522 kbps     01:01:11.918    38,675 kbps     01:01:10.792    35,978 kbps     01:13:56.640    106,724 bytes   517,187 bytes   00:51:12.110
3               1:27:28.868     0:43:46.457     20,586 kbps     47,568 kbps     01:28:18.626    38,758 kbps     01:48:49.814    34,582 kbps     01:33:23.889    107,660 bytes   574,781 bytes   01:34:18.319
4               2:11:15.325     0:43:45.247     20,748 kbps     40,444 kbps     02:19:44.667    34,585 kbps     02:49:03.508    31,347 kbps     02:49:02.215    108,503 bytes   393,266 bytes   02:12:26.438
5               2:55:00.573     0:43:44.955     20,565 kbps     47,488 kbps     02:57:40.858    37,109 kbps     03:34:56.717    36,013 kbps     03:34:51.044    107,577 bytes   432,623 bytes   02:57:40.399
STREAM DIAGNOSTICS:
00063.M2TS      4113 (0x1011)   0xEA            VC-1                                    2622.537                20,513                  6,724,412,267   36,583,708
00063.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2622.537                3,033                   994,244,312     5,810,409
00063.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2622.537                46                      15,230,723      87,288
00063.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2622.537                42                      13,811,082      78,835
00063.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2622.537                41                      13,525,893      77,306
00063.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2622.537                234                     76,686,682      455,252
00065.M2TS      4113 (0x1011)   0xEA            VC-1                                    2626.124                20,406                  6,698,720,315   36,444,016
00065.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2626.124                3,124                   1,025,545,212   5,980,822
00065.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2626.124                42                      13,669,042      78,490
00065.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2626.124                37                      12,089,193      69,185
00065.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2626.124                37                      12,070,567      69,103
00065.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2626.124                300                     98,557,241      572,841
00066.M2TS      4113 (0x1011)   0xEA            VC-1                                    2626.332                20,587                  6,758,493,737   36,768,955
00066.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2626.332                3,019                   991,071,380     5,795,198
00066.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2626.332                42                      13,692,702      79,011
00066.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2626.332                37                      11,986,438      68,795
00066.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2626.332                38                      12,529,045      71,737
00066.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2626.332                218                     71,486,576      427,401
00067.M2TS      4113 (0x1011)   0xEA            VC-1                                    2625.123                20,749                  6,808,428,679   37,040,450
00067.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.123                3,050                   1,000,906,088   5,848,146
00067.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.123                42                      13,705,824      79,037
00067.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.123                38                      12,464,419      71,116
00067.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.123                38                      12,434,940      70,940
00067.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2625.123                285                     93,524,424      545,554
00068.M2TS      4113 (0x1011)   0xEA            VC-1                                    2624.831                20,566                  6,747,749,511   36,710,576
00068.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2624.831                3,155                   1,035,143,356   6,034,712
00068.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2624.831                46                      14,962,658      86,074
00068.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2624.831                38                      12,388,548      71,011
00068.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2624.831                39                      12,757,484      73,035
00068.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2624.831                327                     107,205,460     619,129
eric.exe is offline
post #346 of 5106 Old 08-27-2009, 07:21 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 1 Disc 4 Episode 11-13              VC-1    2:11:14 34,934,464,512  37,990,765,980  35.49   29.95   DTS-HD Master 5.1 3096Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S1_D4
Disc Size:      37,990,765,980 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:11:14 (h:m:s)
Total Bitrate:          35.49 Mbps
Description:
VIDEO:
VC-1 Video              29946 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              306 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3096 kbps       5.1 / 48 kHz / 3096 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         39.301 kbps
Presentation Graphics           French          35.469 kbps
Presentation Graphics           Spanish         35.401 kbps
FILES:
00011.M2TS      0:00:00.000     0:43:45.247     11,721,842,688  35,720
00012.M2TS      0:43:45.247     0:43:43.621     11,615,213,568  35,417
00013.M2TS      1:27:28.868     0:43:45.247     11,597,408,256  35,341
CHAPTERS:
1               0:00:00.000     0:43:45.247     30,063 kbps     48,226 kbps     00:42:13.072    38,695 kbps     00:35:59.490    37,074 kbps     00:02:30.316    157,727 bytes   593,076 bytes   00:42:32.049
2               0:43:45.247     0:43:43.621     29,975 kbps     50,561 kbps     00:46:23.322    38,977 kbps     01:09:13.941    36,865 kbps     01:06:46.919    157,419 bytes   832,028 bytes   01:17:16.256
3               1:27:28.868     0:43:45.247     29,799 kbps     50,555 kbps     02:07:00.529    37,828 kbps     01:35:35.688    36,695 kbps     01:33:29.145    156,225 bytes   636,120 bytes   01:48:13.486
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0xEA            VC-1                                    2625.123                30,064                  9,865,348,071   53,653,945
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.123                3,156                   1,035,756,700   6,037,759
00011.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.123                192                     63,005,952      410,195
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.123                53                      17,327,765      99,265
00011.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.123                47                      15,271,261      87,088
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.123                48                      15,695,067      89,402
00011.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2625.123                307                     100,863,841     585,638
00012.M2TS      4113 (0x1011)   0xEA            VC-1                                    2623.538                29,976                  9,830,356,569   53,463,820
00012.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2623.538                3,022                   991,084,940     5,794,366
00012.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2623.538                192                     62,967,552      409,945
00012.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2623.538                37                      12,013,917      69,040
00012.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2623.538                34                      11,192,888      64,356
00012.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2623.538                34                      11,162,109      64,195
00012.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2623.538                283                     92,840,342      542,256
00013.M2TS      4113 (0x1011)   0xEA            VC-1                                    2625.123                29,800                  9,778,726,887   53,183,312
00013.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.123                3,108                   1,019,949,220   5,951,358
00013.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.123                192                     63,005,952      410,195
00013.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.123                28                      9,340,695       54,054
00013.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.123                26                      8,379,552       48,046
00013.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.123                25                      8,054,098       46,310
00013.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2625.123                328                     107,618,167     621,916
eric.exe is offline
post #347 of 5106 Old 08-27-2009, 10:29 AM
Phloyd's Avatar
I guess I was saying that PS3 != BDInfo. I thought they were all 3039 Mbps... my mistake.
I guess the PS3 is not accurate. I will check it out again some time but it is not a big deal if we are correct
Cheers!
Phloyd is offline
post #348 of 5106 Old 08-27-2009, 03:39 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 2 Disc 1 Episodes 1-5               AVC     3:38:29 40,976,345,088  44,187,545,890  25.01   18.99   DTS-HD Master 5.1 3840Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S2_D1
Disc Size:      44,187,545,890 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:38:29 (h:m:s)
Total Bitrate:          25.01 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        18990 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        522 kbps            480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3840 kbps       5.1 / 48 kHz / 3840 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         41.441 kbps
Presentation Graphics           French          35.068 kbps
Presentation Graphics           Spanish         35.942 kbps
FILES:
00380.M2TS      0:00:00.000     0:43:41.076     8,231,319,552   25,123
00381.M2TS      0:43:41.076     0:43:33.277     8,141,776,896   24,924
00382.M2TS      1:27:14.354     0:43:46.290     8,124,794,880   24,749
00383.M2TS      2:11:00.644     0:43:47.291     8,306,835,456   25,294
00384.M2TS      2:54:47.935     0:43:41.660     8,171,618,304   24,936
CHAPTERS:
1               0:00:00.000     0:43:41.076     18,996 kbps     35,264 kbps     00:01:46.523    33,242 kbps     00:01:46.439    31,081 kbps     00:01:41.684    99,037 bytes    535,852 bytes   00:32:24.108
2               0:43:41.076     0:43:33.277     18,985 kbps     35,222 kbps     01:22:37.035    33,857 kbps     01:22:33.657    32,111 kbps     01:22:32.656    98,980 bytes    541,154 bytes   00:43:48.083
3               1:27:14.354     0:43:46.290     18,987 kbps     42,494 kbps     01:45:48.050    34,888 kbps     01:45:44.046    32,986 kbps     02:01:22.358    98,989 bytes    437,370 bytes   01:27:21.361
4               2:11:00.644     0:43:47.291     18,991 kbps     34,345 kbps     02:25:26.426    30,176 kbps     02:42:22.357    28,450 kbps     02:17:47.884    99,009 bytes    549,198 bytes   02:30:31.522
5               2:54:47.935     0:43:41.660     18,990 kbps     35,668 kbps     03:20:37.191    32,886 kbps     03:20:35.022    32,093 kbps     03:20:10.540    99,009 bytes    429,553 bytes   03:01:28.252
STREAM DIAGNOSTICS:
00380.M2TS      4113 (0x1011)   0x1B            AVC                                     2620.993                18,997                  6,223,842,711   33,861,618
00380.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2620.993                3,941                   1,291,311,432   7,425,385
00380.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2620.993                192                     62,906,112      409,545
00380.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2620.993                40                      13,116,835      75,655
00380.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2620.993                35                      11,593,410      66,744
00380.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2620.993                32                      10,639,058      61,563
00380.M2TS      6912 (0x1B00)   0x1B            AVC                                     2620.993                486                     159,365,884     883,097
00381.M2TS      4113 (0x1011)   0x1B            AVC                                     2613.111                18,986                  6,201,714,081   33,741,231
00381.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2613.111                3,737                   1,220,573,748   7,041,418
00381.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2613.111                192                     62,718,720      408,325
00381.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2613.111                37                      12,215,830      70,637
00381.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2613.111                34                      10,990,079      62,895
00381.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2613.111                32                      10,424,296      59,843
00381.M2TS      6912 (0x1B00)   0x1B            AVC                                     2613.111                516                     168,453,813     933,164
00382.M2TS      4113 (0x1011)   0x1B            AVC                                     2626.124                18,988                  6,233,140,894   33,912,236
00382.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2626.124                3,812                   1,251,411,628   7,210,387
00382.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2626.124                46                      15,175,372      86,899
00382.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2626.124                39                      12,678,251      72,580
00382.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2626.124                39                      12,794,389      73,206
00382.M2TS      6912 (0x1B00)   0x1B            AVC                                     2626.124                480                     157,587,425     873,326
00383.M2TS      4113 (0x1011)   0x1B            AVC                                     2627.208                18,990                  6,236,461,503   33,930,328
00383.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2627.208                3,983                   1,308,105,816   7,518,143
00383.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2627.208                192                     63,055,104      410,515
00383.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2627.208                50                      16,305,340      93,974
00383.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2627.208                42                      13,799,882      79,197
00383.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2627.208                41                      13,490,171      77,515
00383.M2TS      6912 (0x1B00)   0x1B            AVC                                     2627.208                587                     192,862,973     1,067,027
00384.M2TS      4113 (0x1011)   0x1B            AVC                                     2621.577                18,992                  6,223,622,125   33,860,541
00384.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2621.577                3,726                   1,220,965,136   7,044,210
00384.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2621.577                192                     62,919,936      409,635
00384.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2621.577                34                      11,095,701      64,030
00384.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2621.577                30                      9,835,980       56,696
00384.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2621.577                31                      10,117,627      58,235
00384.M2TS      6912 (0x1B00)   0x1B            AVC                                     2621.577                540                     176,928,789     979,315
eric.exe is offline
post #349 of 5106 Old 08-27-2009, 07:14 PM - Thread Starter
[US] Duplicity (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8)
Studio: Universal
Release Date: 2009-08-25
UPC: 025195046152
Aspect Ratio: 2.40:1
Code:
        Total   Video
Duplicity                                                       VC-1    2:05:08 23,524,380,672  24,157,189,520  25.06   17.83   DTS-HD Master 5.1 3863Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     DUPLICITY
Disc Size:      24,157,189,520 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:05:08 (h:m:s)
Total Bitrate:          25.06 Mbps
Description:
VIDEO:
VC-1 Video              17825 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3863 kbps       5.1 / 48 kHz / 3863 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         50.768 kbps
Presentation Graphics           French          44.266 kbps
Presentation Graphics           French          0.598 kbps
Presentation Graphics           Spanish         42.038 kbps
Presentation Graphics           Spanish         0.310 kbps
FILES:
00010.M2TS      0:00:00.000     2:05:02.495     23,518,513,152  25,078
00079.M2TS      2:05:02.495     0:00:06.214     5,867,520       7,553
CHAPTERS:
1               0:00:00.000     0:05:53.478     19,250 kbps     42,606 kbps     00:00:23.690    36,402 kbps     00:00:37.120    31,260 kbps     00:00:37.120    100,815 bytes   630,873 bytes   00:03:26.372
2               0:05:53.478     0:04:22.387     19,680 kbps     29,838 kbps     00:07:17.979    26,258 kbps     00:07:14.267    24,020 kbps     00:09:59.307    102,604 bytes   476,666 bytes   00:08:06.027
3               0:10:15.865     0:05:38.254     20,445 kbps     27,455 kbps     00:14:30.703    24,510 kbps     00:13:02.114    23,849 kbps     00:13:02.114    106,588 bytes   375,523 bytes   00:13:02.156
4               0:15:54.119     0:05:34.625     22,154 kbps     35,459 kbps     00:21:00.175    32,519 kbps     00:18:28.440    32,340 kbps     00:18:23.435    115,500 bytes   468,280 bytes   00:21:28.745
5               0:21:28.745     0:07:02.547     19,122 kbps     36,813 kbps     00:22:15.167    33,860 kbps     00:22:13.623    32,915 kbps     00:22:09.119    99,696 bytes    581,905 bytes   00:21:31.748
6               0:28:31.292     0:05:26.492     18,482 kbps     29,068 kbps     00:30:42.340    26,541 kbps     00:30:42.340    24,963 kbps     00:30:38.586    96,357 bytes    458,967 bytes   00:30:42.382
7               0:33:57.785     0:06:39.774     15,135 kbps     25,791 kbps     00:36:02.451    24,277 kbps     00:35:59.949    22,543 kbps     00:35:56.070    78,909 bytes    378,991 bytes   00:34:33.780
8               0:40:37.560     0:08:57.119     19,126 kbps     38,819 kbps     00:49:11.740    37,763 kbps     00:49:09.738    31,559 kbps     00:49:05.609    99,714 bytes    422,891 bytes   00:44:48.477
9               0:49:34.680     0:11:26.852     18,889 kbps     39,387 kbps     00:56:32.347    33,733 kbps     00:53:52.646    29,815 kbps     00:53:49.351    98,477 bytes    534,560 bytes   00:56:32.389
10              1:01:01.532     0:05:39.672     16,722 kbps     25,739 kbps     01:03:34.393    22,428 kbps     01:03:18.252    21,390 kbps     01:06:01.999    87,182 bytes    379,950 bytes   01:01:41.280
11              1:06:41.205     0:05:41.257     18,782 kbps     29,078 kbps     01:09:56.942    26,053 kbps     01:07:08.232    25,036 kbps     01:09:53.689    97,918 bytes    416,496 bytes   01:06:46.210
12              1:12:22.463     0:04:54.919     19,554 kbps     29,972 kbps     01:13:12.596    26,141 kbps     01:13:12.596    24,533 kbps     01:13:08.842    101,948 bytes   331,436 bytes   01:14:08.026
13              1:17:17.382     0:09:24.230     16,955 kbps     27,601 kbps     01:21:36.892    22,622 kbps     01:18:25.575    21,300 kbps     01:18:24.366    88,397 bytes    602,073 bytes   01:21:38.810
14              1:26:41.613     0:10:12.737     18,727 kbps     31,731 kbps     01:33:13.629    26,730 kbps     01:33:11.335    24,617 kbps     01:33:06.205    97,635 bytes    508,676 bytes   01:33:13.838
15              1:36:54.350     0:04:13.503     15,800 kbps     24,834 kbps     01:37:46.652    22,387 kbps     01:37:43.732    21,330 kbps     01:37:43.732    82,372 bytes    416,955 bytes   01:36:58.354
16              1:41:07.853     0:04:20.969     18,586 kbps     26,351 kbps     01:42:21.343    24,240 kbps     01:41:11.065    23,357 kbps     01:41:08.020    96,901 bytes    341,498 bytes   01:41:38.425
17              1:45:28.822     0:06:04.906     19,251 kbps     36,247 kbps     01:50:26.578    28,434 kbps     01:50:23.074    26,198 kbps     01:50:22.907    100,364 bytes   405,650 bytes   01:47:52.841
18              1:51:33.728     0:04:51.958     18,983 kbps     34,565 kbps     01:55:47.440    29,359 kbps     01:55:47.440    25,436 kbps     01:55:43.603    98,969 bytes    368,978 bytes   01:55:50.902
19              1:56:25.687     0:03:10.857     14,509 kbps     24,635 kbps     01:57:37.675    20,288 kbps     01:57:35.882    19,309 kbps     01:58:21.886    75,641 bytes    301,203 bytes   01:58:22.637
20              1:59:36.544     0:05:32.165     3,145 kbps      16,973 kbps     02:00:07.992    11,163 kbps     02:00:05.198    9,739 kbps      02:00:03.362    16,525 bytes    283,831 bytes   02:00:08.576
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    7502.370                17,838                  16,728,399,658  91,023,874
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7502.370                3,864                   3,623,921,760   20,863,200
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           7502.370                768                     720,239,616     4,220,154
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            7502.370                768                     720,239,616     4,220,154
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7502.370                192                     180,059,904     1,172,265
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7502.370                51                      47,649,954      273,574
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7502.370                42                      39,456,254      225,708
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7502.370                44                      41,547,394      237,085
00010.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7502.370                0                       290,815         1,642
00010.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            7502.370                1                       561,058         3,224
00079.M2TS      4113 (0x1011)   0xEA            VC-1                                    6.089                   2,622                   1,995,425       10,933
00079.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6.089                   2,533                   1,928,188       11,382
00079.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           6.089                   784                     596,992         3,498
00079.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6.089                   784                     596,992         3,498
00079.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6.089                   197                     149,760         975
00079.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6.089                   0                       70              7
00079.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6.089                   0                       70              7
00079.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6.089                   0                       70              7
00079.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6.089                   0                       70              7
00079.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6.089                   0                       70              7
post #350 of 5106 Old 08-27-2009, 07:19 PM - Thread Starter
[US] Mad Men: Season 2 (Additional Details)
Studio: Lionsgate
Release Date: 2009-07-14
UPC: 031398106692
Aspect Ratio: 1.78:1
Code:
        Total   Video
Mad Men: Season 1: Disc 1: Episodes 1-5                         AVC     4:01:26 47,036,313,600  47,533,118,776  25.97   20.70   DTS-HD Master 5.1 3218Kbps (48kHz/24-bit)
                   Disc 2: Episodes 6-9                         AVC     3:13:23 41,209,024,512  47,731,219,463  28.41   23.00   DTS-HD Master 5.1 3250Kbps (48kHz/24-bit)
                   Disc 3: Episodes 10-13                       AVC     3:11:35 31,758,637,056  49,161,620,617  22.10   17.00   DTS-HD Master 5.1 3226Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MAD_MEN_SEASON2_DISC1
Disc Size:      47,533,118,776 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 4:01:26 (h:m:s)
Total Bitrate:          25.97 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        20698 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3218 kbps       5.1 / 48 kHz / 3218 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         67.755 kbps
Presentation Graphics           English         71.803 kbps
Presentation Graphics           Spanish         67.417 kbps
FILES:
00252.M2TS      0:00:00.000     0:48:59.978     9,579,177,984   26,066
00284.M2TS      0:48:59.978     0:48:18.937     9,446,762,496   26,070
00285.M2TS      1:37:18.916     0:47:06.865     9,169,453,056   25,949
00286.M2TS      2:24:25.782     0:48:10.929     9,367,818,240   25,923
00287.M2TS      3:12:36.711     0:48:49.968     9,473,101,824   25,865
CHAPTERS:
1               0:00:00.000     0:48:59.978     20,695 kbps     37,274 kbps     00:00:24.983    35,732 kbps     00:47:14.540    33,028 kbps     00:00:12.470    107,894 bytes   406,201 bytes   00:48:51.345
2               0:48:59.978     0:48:18.937     20,694 kbps     37,611 kbps     01:28:04.779    35,202 kbps     01:01:13.920    33,945 kbps     01:01:13.920    107,891 bytes   406,131 bytes   01:37:10.741
3               1:37:18.916     0:47:06.865     20,696 kbps     37,417 kbps     01:54:29.445    36,497 kbps     01:46:45.190    34,155 kbps     01:54:29.445    107,901 bytes   408,983 bytes   02:24:17.523
4               2:24:25.782     0:48:10.929     20,703 kbps     36,742 kbps     03:10:41.179    34,514 kbps     03:10:38.593    32,283 kbps     03:10:37.551    107,937 bytes   409,001 bytes   03:12:28.119
5               3:12:36.711     0:48:49.968     20,702 kbps     41,460 kbps     03:43:40.949    36,274 kbps     03:42:07.731    33,826 kbps     03:43:32.106    107,931 bytes   305,708 bytes   03:12:57.774
STREAM DIAGNOSTICS:
00252.M2TS      4113 (0x1011)   0x1B            AVC                                     2939.812                20,696                  7,605,413,610   41,375,134
00252.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2939.812                3,302                   1,213,441,860   7,054,029
00252.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2939.812                192                     70,560,000      459,375
00252.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2939.812                192                     70,560,000      459,375
00252.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2939.812                69                      25,224,177      143,205
00252.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2939.812                75                      27,537,095      156,606
00252.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2939.812                70                      25,612,646      145,290
00284.M2TS      4113 (0x1011)   0x1B            AVC                                     2898.771                20,696                  7,498,963,142   40,796,124
00284.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2898.771                3,313                   1,200,624,444   6,976,800
00284.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2898.771                192                     69,574,656      452,960
00284.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2898.771                192                     69,574,656      452,960
00284.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2898.771                68                      24,654,085      139,645
00284.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2898.771                70                      25,447,608      144,285
00284.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2898.771                69                      25,074,247      141,971
00285.M2TS      4113 (0x1011)   0x1B            AVC                                     2826.699                20,698                  7,313,236,679   39,785,640
00285.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2826.699                3,173                   1,121,156,272   6,534,900
00285.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2826.699                192                     67,845,120      441,700
00285.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2826.699                192                     67,845,120      441,700
00285.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2826.699                75                      26,572,738      150,471
00285.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2826.699                80                      28,276,195      160,437
00285.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2826.699                74                      26,119,117      147,981
00286.M2TS      4113 (0x1011)   0x1B            AVC                                     2890.846                20,704                  7,481,442,968   40,700,689
00286.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2890.846                3,171                   1,145,786,604   6,679,783
00286.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2890.846                192                     69,382,656      451,710
00286.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2890.846                192                     69,382,656      451,710
00286.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2890.846                65                      23,534,293      133,710
00286.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2890.846                69                      25,075,302      142,626
00286.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2890.846                65                      23,509,673      133,607
00287.M2TS      4113 (0x1011)   0x1B            AVC                                     2929.885                20,702                  7,581,932,443   41,247,418
00287.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2929.885                3,130                   1,146,441,756   6,690,009
00287.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2929.885                192                     70,319,616      457,810
00287.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2929.885                192                     70,319,616      457,810
00287.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2929.885                62                      22,708,577      129,111
00287.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2929.885                65                      23,686,543      134,717
00287.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2929.885                59                      21,765,942      123,999
Code:
DISC INFO:
Disc Title:     MAD_MEN_SEASON2_DISC2
Disc Size:      47,731,219,463 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:13:23 (h:m:s)
Total Bitrate:          28.41 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        22998 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3250 kbps       5.1 / 48 kHz / 3250 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         68.400 kbps
Presentation Graphics           English         73.721 kbps
Presentation Graphics           Spanish         68.277 kbps
FILES:
00290.M2TS      0:00:00.000     0:48:15.934     10,326,484,992  28,527
00291.M2TS      0:48:15.934     0:47:53.912     10,216,833,024  28,440
00292.M2TS      1:36:09.847     0:48:40.959     10,333,495,296  28,302
00293.M2TS      2:24:50.807     0:48:32.951     10,332,211,200  28,376
CHAPTERS:
1               0:00:00.000     0:48:15.934     23,000 kbps     36,654 kbps     00:10:45.770    36,292 kbps     00:13:10.372    34,077 kbps     00:03:05.018    119,907 bytes   406,275 bytes   00:48:07.467
2               0:48:15.934     0:47:53.912     22,993 kbps     37,278 kbps     01:10:08.996    36,482 kbps     01:26:43.531    35,106 kbps     01:13:09.384    119,875 bytes   422,411 bytes   01:20:09.095
3               1:36:09.847     0:48:40.959     23,002 kbps     36,182 kbps     01:36:34.830    34,222 kbps     01:49:21.096    32,875 kbps     01:49:16.341    119,921 bytes   338,321 bytes   02:24:19.108
4               2:24:50.807     0:48:32.951     22,997 kbps     37,435 kbps     02:31:48.307    36,491 kbps     02:40:45.677    36,258 kbps     02:40:43.216    119,900 bytes   406,127 bytes   03:13:15.125
STREAM DIAGNOSTICS:
00290.M2TS      4113 (0x1011)   0x1B            AVC                                     2895.768                23,001                  8,325,636,407   45,288,654
00290.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2895.768                3,372                   1,220,613,656   7,084,799
00290.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2895.768                192                     69,502,464      452,490
00290.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2895.768                192                     69,502,464      452,490
00290.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2895.768                65                      23,601,700      134,090
00290.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2895.768                69                      24,892,681      141,604
00290.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2895.768                64                      23,269,486      132,603
00291.M2TS      4113 (0x1011)   0x1B            AVC                                     2873.746                22,994                  8,259,970,697   44,931,536
00291.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2873.746                3,281                   1,178,755,804   6,854,604
00291.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2873.746                192                     68,974,080      449,050
00291.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2873.746                192                     68,974,080      449,050
00291.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2873.746                69                      24,711,076      140,232
00291.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2873.746                75                      27,029,372      153,689
00291.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2873.746                68                      24,291,927      138,202
00292.M2TS      4113 (0x1011)   0x1B            AVC                                     2920.876                23,002                  8,398,394,289   45,684,471
00292.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2920.876                3,126                   1,141,403,276   6,656,494
00292.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2920.876                192                     70,103,040      456,400
00292.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2920.876                192                     70,103,040      456,400
00292.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2920.876                73                      26,594,030      150,544
00292.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2920.876                80                      29,366,119      166,313
00292.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2920.876                73                      26,770,907      151,790
00293.M2TS      4113 (0x1011)   0x1B            AVC                                     2912.785                22,999                  8,373,813,504   45,550,931
00293.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2912.785                3,222                   1,173,181,792   6,830,774
00293.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2912.785                192                     69,911,040      455,150
00293.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2912.785                192                     69,911,040      455,150
00293.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2912.785                67                      24,305,890      137,967
00293.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2912.785                70                      25,642,510      145,725
00293.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2912.785                68                      24,700,889      140,277
Code:
DISC INFO:
Disc Title:     MAD_MEN_SEASON2_DISC3
Disc Size:      49,161,620,617 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:11:35 (h:m:s)
Total Bitrate:          22.10 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        17000 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3226 kbps       5.1 / 48 kHz / 3226 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         61.047 kbps
Presentation Graphics           English         64.252 kbps
Presentation Graphics           Spanish         59.890 kbps
FILES:
00284.M2TS      0:00:00.000     0:47:37.896     7,875,686,400   22,046
00285.M2TS      0:47:37.896     0:47:58.917     7,981,756,416   22,180
00286.M2TS      1:35:36.814     0:47:49.908     7,935,369,216   22,120
00455.M2TS      2:23:26.723     0:48:08.927     7,965,825,024   22,059
CHAPTERS:
1               0:00:00.000     0:47:37.896     16,998 kbps     29,541 kbps     00:08:57.703    27,333 kbps     00:27:24.351    26,921 kbps     00:09:29.735    88,621 bytes    330,951 bytes   00:47:05.072
2               0:47:37.896     0:47:58.917     17,001 kbps     34,744 kbps     01:08:24.016    31,553 kbps     01:08:20.638    28,231 kbps     01:08:20.513    88,637 bytes    406,127 bytes   01:35:27.221
3               1:35:36.814     0:47:49.908     16,999 kbps     36,976 kbps     02:22:03.431    35,132 kbps     02:21:59.677    33,641 kbps     02:22:09.312    88,624 bytes    406,195 bytes   02:23:17.880
4               2:23:26.723     0:48:08.927     17,002 kbps     30,239 kbps     03:01:55.571    28,517 kbps     03:01:51.567    27,767 kbps     03:01:46.812    88,644 bytes    346,297 bytes   03:11:13.628
STREAM DIAGNOSTICS:
00284.M2TS      4113 (0x1011)   0x1B            AVC                                     2857.813                16,999                  6,072,476,785   33,042,821
00284.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2857.813                3,180                   1,136,039,612   6,619,802
00284.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2857.813                192                     68,590,080      446,550
00284.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2857.813                192                     68,590,080      446,550
00284.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2857.813                60                      21,465,895      121,942
00284.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2857.813                62                      22,232,007      126,347
00284.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2857.813                59                      20,984,358      119,413
00285.M2TS      4113 (0x1011)   0x1B            AVC                                     2878.834                17,002                  6,118,180,466   33,291,577
00285.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2878.834                3,303                   1,188,674,948   6,909,128
00285.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2878.834                192                     69,094,656      449,835
00285.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2878.834                192                     69,094,656      449,835
00285.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2878.834                60                      21,693,156      123,205
00285.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2878.834                63                      22,768,369      129,416
00285.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2878.834                60                      21,482,818      122,181
00286.M2TS      4113 (0x1011)   0x1B            AVC                                     2869.742                17,000                  6,098,119,274   33,182,436
00286.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2869.742                3,245                   1,164,149,940   6,775,442
00286.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2869.742                192                     68,878,080      448,425
00286.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2869.742                192                     68,878,080      448,425
00286.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2869.742                61                      21,747,348      123,773
00286.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2869.742                66                      23,753,235      135,288
00286.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2869.742                59                      21,070,423      120,095
00455.M2TS      4113 (0x1011)   0x1B            AVC                                     2888.761                17,003                  6,139,874,472   33,409,626
00455.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2888.761                3,177                   1,147,355,528   6,688,411
00455.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2888.761                192                     69,334,272      451,395
00455.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2888.761                192                     69,334,272      451,395
00455.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2888.761                63                      22,815,199      129,428
00455.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2888.761                65                      23,573,608      133,752
00455.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2888.761                62                      22,521,822      127,838
post #351 of 5106 Old 08-28-2009, 06:30 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
*episode 10 (00074.m2ts) is the broadcast version, the extended version is on the next disc
Code:
        Total   Video
Battlestar Galactica Season 2 Disc 2 Episodes 6-10*             AVC     3:40:32 41,444,640,768  43,490,087,306  25.06   18.99   DTS-HD Master 5.1 3903Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S2_D2
Disc Size:      43,490,087,306 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:40:32 (h:m:s)
Description:
VIDEO:
MPEG-4 AVC Video        18993 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        538 kbps            480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3903 kbps       5.1 / 48 kHz / 3903 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         44.889 kbps
Presentation Graphics           French          39.694 kbps
Presentation Graphics           Spanish         39.223 kbps
FILES:
00070.M2TS      0:00:00.000     0:43:44.872     8,234,477,568   25,097
00071.M2TS      0:43:44.872     0:43:44.872     8,268,472,320   25,200
00072.M2TS      1:27:29.744     0:43:48.709     8,335,521,792   25,368
00073.M2TS      2:11:18.453     0:43:45.873     8,175,409,152   24,907
00074.M2TS      2:55:04.327     0:45:28.183     8,430,759,936   24,722
CHAPTERS:
1               0:00:00.000     0:43:44.872     18,990 kbps     37,205 kbps     00:22:11.371    29,482 kbps     00:42:16.742    28,609 kbps     00:30:44.759    99,004 bytes    560,835 bytes   00:43:34.862
2               0:43:44.872     0:43:44.872     18,992 kbps     40,840 kbps     01:07:20.536    34,399 kbps     01:03:35.353    33,938 kbps     01:14:35.971    99,018 bytes    443,598 bytes   01:27:19.651
3               1:27:29.744     0:43:48.709     18,999 kbps     39,192 kbps     01:44:02.694    34,423 kbps     02:09:22.963    34,308 kbps     01:29:05.173    99,054 bytes    424,168 bytes   01:28:53.119
4               2:11:18.453     0:43:45.873     18,991 kbps     33,508 kbps     02:50:13.620    31,694 kbps     02:50:10.992    30,440 kbps     02:50:09.240    99,010 bytes    514,226 bytes   02:54:54.275
5               2:55:04.327     0:45:28.183     18,992 kbps     34,778 kbps     03:03:59.862    34,303 kbps     03:03:58.735    34,156 kbps     03:03:54.356    99,018 bytes    539,531 bytes   02:55:11.334
STREAM DIAGNOSTICS:
00070.M2TS      4113 (0x1011)   0x1B            AVC                                     2624.789                18,991                  6,230,774,884   33,899,538
00070.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2624.789                3,864                   1,267,877,360   7,300,195
00070.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2624.789                47                      15,571,248      89,170
00070.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2624.789                39                      12,941,261      74,163
00070.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2624.789                39                      12,682,776      72,770
00070.M2TS      6912 (0x1B00)   0x1B            AVC                                     2624.789                525                     172,282,011     953,944
00071.M2TS      4113 (0x1011)   0x1B            AVC                                     2624.789                18,993                  6,231,580,953   33,903,664
00071.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2624.789                3,963                   1,300,216,112   7,476,090
00071.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2624.789                39                      12,895,810      74,137
00071.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2624.789                35                      11,518,459      66,272
00071.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2624.789                35                      11,448,212      65,903
00071.M2TS      6912 (0x1B00)   0x1B            AVC                                     2624.789                540                     177,197,934     980,792
00072.M2TS      4113 (0x1011)   0x1B            AVC                                     2628.626                19,000                  6,242,955,765   33,965,537
00072.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2628.626                4,056                   1,332,859,692   7,653,347
00072.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2628.626                54                      17,782,665      101,596
00072.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2628.626                47                      15,468,884      88,477
00072.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2628.626                52                      16,967,972      96,618
00072.M2TS      6912 (0x1B00)   0x1B            AVC                                     2628.626                555                     182,439,433     1,009,770
00073.M2TS      4113 (0x1011)   0x1B            AVC                                     2625.706                18,992                  6,233,442,111   33,914,023
00073.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.706                3,859                   1,266,674,888   7,292,879
00073.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.706                41                      13,529,866      78,046
00073.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.706                35                      11,435,059      65,640
00073.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.706                35                      11,401,322      65,469
00073.M2TS      6912 (0x1B00)   0x1B            AVC                                     2625.706                591                     194,039,286     1,076,181
00074.M2TS      4113 (0x1011)   0x1B            AVC                                     2728.100                18,993                  6,476,799,508   35,238,049
00074.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2728.100                3,779                   1,288,577,492   7,428,151
00074.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2728.100                42                      14,469,624      83,204
00074.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2728.100                40                      13,514,313      77,228
00074.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2728.100                39                      13,156,131      75,277
00074.M2TS      6912 (0x1B00)   0x1B            AVC                                     2728.100                481                     164,017,151     916,882
eric.exe is offline
post #352 of 5106 Old 08-28-2009, 08:21 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
*Extended Version of Episode 10 (00070.m2ts)
Code:
        Total   Video
Battlestar Galactica Season 2 Disc 3 Episodes *10-13            AVC     3:10:13 42,303,424,512  43,158,052,794  29.65   23.49   DTS-HD Master 5.1 3728Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S2_D3
Disc Size:      43,158,052,794 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:10:13 (h:m:s)
Total Bitrate:          29.65 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        23494 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        532 kbps            480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3728 kbps       5.1 / 48 kHz / 3728 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         40.305 kbps
Presentation Graphics           French          36.152 kbps
Presentation Graphics           Spanish         37.549 kbps
FILES:
00070.M2TS      0:00:00.000     0:58:54.405     13,058,353,152  29,557
00071.M2TS      0:58:54.405     0:43:44.288     9,745,575,936   29,709
00072.M2TS      1:42:38.694     0:43:45.664     9,739,763,712   29,676
00073.M2TS      2:26:24.358     0:43:48.667     9,759,731,712   29,702
CHAPTERS:
1               0:00:00.000     0:58:54.405     23,498 kbps     37,976 kbps     00:43:20.681    34,328 kbps     00:00:31.406    34,159 kbps     00:11:14.340    122,507 bytes   403,648 bytes   00:07:15.476
2               0:58:54.405     0:43:44.288     23,491 kbps     37,300 kbps     01:18:54.312    34,668 kbps     01:18:50.308    34,329 kbps     01:18:45.262    122,472 bytes   364,970 bytes   01:10:13.292
3               1:42:38.694     0:43:45.664     23,495 kbps     37,413 kbps     02:10:23.106    33,673 kbps     01:46:52.864    32,997 kbps     02:10:20.687    122,494 bytes   765,848 bytes   01:46:45.774
4               2:26:24.358     0:43:48.667     23,492 kbps     37,790 kbps     02:29:59.573    34,705 kbps     02:32:02.112    34,364 kbps     02:40:54.561    122,479 bytes   855,898 bytes   02:56:14.939
STREAM DIAGNOSTICS:
00070.M2TS      4113 (0x1011)   0x1B            AVC                                     3534.322                23,499                  10,381,496,316  56,470,559
00070.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           3534.322                3,759                   1,660,806,956   9,576,992
00070.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           3534.322                192                     84,826,368      552,255
00070.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           3534.322                43                      19,153,744      109,846
00070.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           3534.322                42                      18,417,193      105,141
00070.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            3534.322                38                      16,891,956      96,857
00070.M2TS      6912 (0x1B00)   0x1B            AVC                                     3534.322                395                     174,623,193     982,170
00071.M2TS      4113 (0x1011)   0x1B            AVC                                     2624.205                23,492                  7,705,910,806   41,916,181
00071.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2624.205                3,695                   1,211,915,924   6,995,613
00071.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2624.205                192                     62,983,680      410,050
00071.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2624.205                40                      13,174,646      75,483
00071.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2624.205                38                      12,484,898      71,467
00071.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2624.205                37                      12,204,309      69,945
00071.M2TS      6912 (0x1B00)   0x1B            AVC                                     2624.205                622                     203,973,346     1,131,524
00072.M2TS      4113 (0x1011)   0x1B            AVC                                     2625.498                23,497                  7,711,342,181   41,945,651
00072.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.498                3,741                   1,227,883,564   7,086,107
00072.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.498                192                     63,016,704      410,265
00072.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.498                31                      10,101,267      58,010
00072.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.498                28                      9,122,466       52,499
00072.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.498                27                      8,889,531       51,232
00072.M2TS      6912 (0x1B00)   0x1B            AVC                                     2625.498                571                     187,239,800     1,036,179
00073.M2TS      4113 (0x1011)   0x1B            AVC                                     2628.501                23,494                  7,719,114,987   41,988,125
00073.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2628.501                3,708                   1,218,377,144   7,031,042
00073.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2628.501                192                     63,088,128      410,730
00073.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2628.501                46                      15,071,180      86,470
00073.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2628.501                41                      13,543,856      77,647
00073.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2628.501                41                      13,589,184      77,913
00073.M2TS      6912 (0x1B00)   0x1B            AVC                                     2628.501                590                     193,743,940     1,071,903
eric.exe is offline
post #353 of 5106 Old 08-28-2009, 02:42 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 2 Disc 4 Episodes 14-17             AVC     2:56:10 42,121,463,808  43,898,611,770  31.88   25.49   DTS-HD Master 5.1 3791Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S2_D4
Disc Size:      43,898,611,770 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:56:10 (h:m:s)
Total Bitrate:          31.88 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        25489 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        605 kbps            480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3791 kbps       5.1 / 48 kHz / 3791 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         40.184 kbps
Presentation Graphics           French          35.802 kbps
Presentation Graphics           Spanish         36.895 kbps
FILES:
00065.M2TS      0:00:00.000     0:43:46.665     10,414,331,904  31,719
00063.M2TS      0:43:46.665     0:43:58.677     10,527,043,584  31,916
00066.M2TS      1:27:45.343     0:44:36.548     10,670,493,696  31,893
00067.M2TS      2:12:21.892     0:43:48.667     10,509,594,624  31,985
CHAPTERS:
1               0:00:00.000     0:43:46.665     25,487 kbps     39,066 kbps     00:34:39.869    35,012 kbps     00:34:35.865    34,363 kbps     00:16:52.594    132,876 bytes   378,520 bytes   00:43:35.613
2               0:43:46.665     0:43:58.677     25,488 kbps     41,318 kbps     01:19:42.694    34,641 kbps     01:22:38.036    34,338 kbps     01:04:54.348    132,880 bytes   526,552 bytes   00:53:52.062
3               1:27:45.343     0:44:36.548     25,496 kbps     38,741 kbps     01:35:15.084    34,474 kbps     01:29:24.609    34,337 kbps     01:29:19.520    132,927 bytes   818,964 bytes   01:55:29.964
4               2:12:21.892     0:43:48.667     25,486 kbps     38,865 kbps     02:17:45.173    34,616 kbps     02:25:31.681    34,366 kbps     02:33:06.302    132,875 bytes   554,688 bytes   02:56:00.549
STREAM DIAGNOSTICS:
00065.M2TS      4113 (0x1011)   0x1B            AVC                                     2626.499                25,489                  8,368,240,410   45,516,090
00065.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2626.499                3,723                   1,222,288,244   7,049,377
00065.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2626.499                192                     63,040,512      410,420
00065.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2626.499                39                      12,772,087      73,115
00065.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2626.499                35                      11,532,655      66,165
00065.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2626.499                33                      10,878,558      62,623
00065.M2TS      6912 (0x1B00)   0x1B            AVC                                     2626.499                536                     176,026,849     975,494
00063.M2TS      4113 (0x1011)   0x1B            AVC                                     2638.511                25,489                  8,406,672,084   45,724,981
00063.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2638.511                3,812                   1,257,314,208   7,245,719
00063.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2638.511                192                     63,328,512      412,295
00063.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2638.511                41                      13,529,521      77,781
00063.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2638.511                37                      12,296,688      70,794
00063.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2638.511                36                      11,905,634      68,694
00063.M2TS      6912 (0x1B00)   0x1B            AVC                                     2638.511                617                     203,633,939     1,139,642
00066.M2TS      4113 (0x1011)   0x1B            AVC                                     2676.465                25,497                  8,530,311,012   46,397,597
00066.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2676.465                3,795                   1,269,786,996   7,317,597
00066.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2676.465                192                     64,237,824      418,215
00066.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2676.465                34                      11,346,200      65,180
00066.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2676.465                31                      10,483,907      60,442
00066.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2676.465                32                      10,798,523      62,159
00066.M2TS      6912 (0x1B00)   0x1B            AVC                                     2676.465                629                     210,586,356     1,164,597
00067.M2TS      4113 (0x1011)   0x1B            AVC                                     2628.501                25,488                  8,374,346,678   45,549,252
00067.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2628.501                3,832                   1,259,138,244   7,252,221
00067.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2628.501                192                     63,088,128      410,730
00067.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2628.501                47                      15,448,423      88,310
00067.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2628.501                44                      14,436,622      82,464
00067.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2628.501                42                      13,723,788      78,588
00067.M2TS      6912 (0x1B00)   0x1B            AVC                                     2628.501                638                     209,630,000     1,187,814
eric.exe is offline
post #354 of 5106 Old 08-28-2009, 04:40 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 2 Disc 5 Episodes 18-20             AVC     2:35:01 41,793,429,504  44,873,693,462  35.95   29.47   DTS-HD Master 5.1 3705Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S2_D5
Disc Size:      44,873,693,462 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:35:01 (h:m:s)
Total Bitrate:          35.95 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        29470 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        608 kbps            480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3705 kbps       5.1 / 48 kHz / 3705 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         40.614 kbps
Presentation Graphics           French          37.138 kbps
Presentation Graphics           Spanish         37.590 kbps
FILES:
00070.M2TS      0:00:00.000     0:43:21.473     11,660,783,616  35,859
00071.M2TS      0:43:21.473     0:43:45.497     11,782,219,776  35,901
00072.M2TS      1:27:06.971     1:07:54.320     18,350,426,112  36,031
CHAPTERS:
1               0:00:00.000     0:43:21.473     29,468 kbps     43,754 kbps     00:01:16.493    35,646 kbps     00:01:12.489    34,832 kbps     00:42:11.946    153,629 bytes   837,700 bytes   00:05:09.309
2               0:43:21.473     0:43:45.497     29,472 kbps     38,443 kbps     00:46:39.213    34,960 kbps     00:46:35.250    34,556 kbps     00:46:30.245    153,652 bytes   379,159 bytes   01:26:56.628
3               1:27:06.971     1:07:54.320     29,470 kbps     38,916 kbps     01:29:39.582    34,881 kbps     01:30:54.657    34,400 kbps     01:43:10.851    153,646 bytes   392,325 bytes   01:30:18.329
STREAM DIAGNOSTICS:
00070.M2TS      4113 (0x1011)   0x1B            AVC                                     2601.390                29,469                  9,582,436,028   52,114,301
00070.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2601.390                3,663                   1,191,143,124   6,879,620
00070.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2601.390                192                     62,436,096      406,485
00070.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2601.390                40                      12,904,155      74,371
00070.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2601.390                36                      11,670,343      67,156
00070.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2601.390                36                      11,585,674      66,688
00070.M2TS      6912 (0x1B00)   0x1B            AVC                                     2601.390                577                     187,494,655     1,037,438
00071.M2TS      4113 (0x1011)   0x1B            AVC                                     2625.414                29,473                  9,672,244,968   52,603,078
00071.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.414                3,684                   1,208,992,580   6,978,868
00071.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.414                192                     63,012,096      410,235
00071.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.414                46                      15,164,898      86,883
00071.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.414                43                      14,055,519      80,502
00071.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.414                43                      14,173,768      81,142
00071.M2TS      6912 (0x1B00)   0x1B            AVC                                     2625.414                571                     187,410,762     1,037,042
00072.M2TS      4113 (0x1011)   0x1B            AVC                                     4074.237                29,471                  15,008,931,206  81,627,000
00072.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4074.237                3,745                   1,907,367,396   11,001,322
00072.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           4074.237                192                     97,784,064      636,615
00072.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4074.237                38                      19,151,835      110,198
00072.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           4074.237                35                      17,979,136      103,228
00072.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            4074.237                34                      17,419,593      100,195
00072.M2TS      6912 (0x1B00)   0x1B            AVC                                     4074.237                651                     331,461,009     1,860,045
eric.exe is offline
post #355 of 5106 Old 08-29-2009, 09:01 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 3 Disc 1 Episodes 1-5               VC-1    3:41:12 42,103,228,416  44,037,171,974  25.38   19.68   DTS-HD Master 5.1 3779Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S3_D1
Disc Size:      44,037,171,974 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:41:12 (h:m:s)
Total Bitrate:          25.38 Mbps
Description:
VIDEO:
VC-1 Video              19682 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              190 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3779 kbps       5.1 / 48 kHz / 3779 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         40.562 kbps
Presentation Graphics           French          34.911 kbps
Presentation Graphics           Spanish         34.210 kbps
FILES:
00372.M2TS      0:00:00.000     0:45:02.700     8,507,940,864   25,184
00373.M2TS      0:45:02.700     0:44:58.320     8,561,694,720   25,384
00375.M2TS      1:30:01.020     0:43:41.243     8,331,902,976   25,429
00374.M2TS      2:13:42.264     0:43:37.614     8,357,154,816   25,541
00376.M2TS      2:57:19.879     0:43:52.254     8,344,535,040   25,361
CHAPTERS:
1               0:00:00.000     0:45:02.700     19,572 kbps     40,399 kbps     00:16:46.296    36,888 kbps     00:14:43.340    34,428 kbps     00:14:40.421    102,976 bytes   605,897 bytes   00:02:24.227
2               0:45:02.700     0:44:58.320     19,739 kbps     46,720 kbps     01:13:47.089    38,311 kbps     01:12:39.480    35,228 kbps     00:58:27.086    103,049 bytes   628,833 bytes   01:24:06.499
3               1:30:01.020     0:43:41.243     19,746 kbps     51,600 kbps     01:46:48.026    37,885 kbps     01:46:44.689    34,183 kbps     01:44:13.538    103,517 bytes   565,217 bytes   01:31:31.986
4               2:13:42.264     0:43:37.614     19,693 kbps     47,494 kbps     02:33:11.098    39,091 kbps     02:33:07.052    34,525 kbps     02:46:19.719    103,043 bytes   510,922 bytes   02:33:11.807
5               2:57:19.879     0:43:52.254     19,659 kbps     40,802 kbps     03:27:13.921    38,932 kbps     03:18:31.107    32,311 kbps     03:18:31.149    102,788 bytes   492,255 bytes   03:27:13.963
STREAM DIAGNOSTICS:
00372.M2TS      4113 (0x1011)   0xEA            VC-1                                    2702.575                19,573                  6,612,172,404   35,975,014
00372.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2702.575                3,727                   1,259,020,548   7,266,034
00372.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2702.575                192                     64,865,280      422,300
00372.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2702.575                41                      13,683,118      78,120
00372.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2702.575                35                      11,723,235      67,107
00372.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2702.575                36                      12,216,513      69,797
00372.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2702.575                162                     54,799,041      343,229
00373.M2TS      4113 (0x1011)   0xEA            VC-1                                    2698.196                19,740                  6,657,863,015   36,223,106
00373.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2698.196                3,715                   1,252,958,212   7,230,647
00373.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2698.196                192                     64,760,064      421,615
00373.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2698.196                47                      15,714,312      89,639
00373.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2698.196                40                      13,388,780      76,493
00373.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2698.196                38                      12,906,996      73,880
00373.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2698.196                186                     62,846,353      386,339
00375.M2TS      4113 (0x1011)   0xEA            VC-1                                    2621.119                19,747                  6,469,921,878   35,200,694
00375.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2621.119                3,794                   1,242,926,532   7,163,933
00375.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2621.119                192                     62,909,952      409,570
00375.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2621.119                39                      12,798,370      73,657
00375.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2621.119                32                      10,458,346      59,964
00375.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2621.119                33                      10,836,080      62,013
00375.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2621.119                165                     54,047,704      337,637
00374.M2TS      4113 (0x1011)   0xEA            VC-1                                    2617.490                19,694                  6,443,585,151   35,057,484
00374.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2617.490                3,922                   1,283,090,848   7,381,511
00374.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2617.490                192                     62,823,168      409,005
00374.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2617.490                33                      10,742,420      61,830
00374.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2617.490                25                      8,307,655       47,834
00374.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2617.490                27                      8,719,714       50,084
00374.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2617.490                219                     71,504,929      431,371
00376.M2TS      4113 (0x1011)   0xEA            VC-1                                    2632.130                19,660                  6,468,546,664   35,193,342
00376.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2632.130                3,744                   1,231,974,900   7,106,578
00376.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2632.130                192                     63,174,144      411,290
00376.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2632.130                44                      14,355,239      82,184
00376.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2632.130                39                      12,876,955      73,804
00376.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2632.130                40                      13,238,883      75,783
00376.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2632.130                216                     71,207,535      429,931
eric.exe is offline
post #356 of 5106 Old 08-29-2009, 01:08 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
*broadcast version of episode 9 (00081.m2ts)
Code:
        Total   Video
Battlestar Galactica Season 3 Disc 2 Episodes 6-9*              VC-1    2:55:39 41,976,360,960  45,077,863,480  31.86   25.76   DTS-HD Master 5.1 3861Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BATTLESTAR_GALACTICA
Disc Size:      45,077,863,480 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:55:39 (h:m:s)
Total Bitrate:          31.86 Mbps
Description:
VIDEO:
VC-1 Video              25755 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              192 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3861 kbps       5.1 / 48 kHz / 3861 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         38.450 kbps
Presentation Graphics           French          33.568 kbps
Presentation Graphics           Spanish         34.220 kbps
FILES:
00010.M2TS      0:00:00.000     0:43:51.962     10,449,623,040  31,762
00079.M2TS      0:43:51.962     0:42:50.025     10,069,518,336  31,344
00080.M2TS      1:26:41.988     0:45:10.541     10,715,731,968  31,627
00081.M2TS      2:11:52.529     0:43:46.957     10,741,487,616  32,712
CHAPTERS:
1               0:00:00.000     0:43:51.962     25,756 kbps     43,399 kbps     00:22:03.363    37,733 kbps     00:04:10.375    36,697 kbps     00:33:12.865    134,280 bytes   614,035 bytes   00:00:27.861
2               0:43:51.962     0:42:50.025     25,379 kbps     48,616 kbps     00:55:37.834    38,861 kbps     01:21:26.798    37,134 kbps     01:05:05.484    132,378 bytes   455,712 bytes   00:44:47.976
3               1:26:41.988     0:45:10.541     25,489 kbps     56,609 kbps     01:57:18.489    38,848 kbps     01:41:02.556    36,310 kbps     01:50:54.189    132,938 bytes   778,997 bytes   01:57:18.948
4               2:11:52.529     0:43:46.957     26,398 kbps     50,272 kbps     02:52:33.342    39,335 kbps     02:31:22.907    37,351 kbps     02:44:11.800    138,067 bytes   748,052 bytes   02:23:00.697
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    2631.879                25,757                  8,473,617,202   46,090,368
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2631.879                3,789                   1,246,386,108   7,184,006
00010.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2631.879                192                     63,167,232      411,245
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2631.879                47                      15,621,301      89,228
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2631.879                42                      13,817,907      79,118
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2631.879                40                      13,053,493      74,991
00010.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2631.879                204                     67,147,725      407,960
00079.M2TS      4113 (0x1011)   0xEA            VC-1                                    2569.901                25,380                  8,153,147,935   44,347,929
00079.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2569.901                3,804                   1,221,996,928   7,043,137
00079.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2569.901                192                     61,681,152      401,570
00079.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2569.901                42                      13,506,455      77,178
00079.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2569.901                38                      12,329,610      70,261
00079.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2569.901                39                      12,427,504      70,801
00079.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2569.901                175                     56,244,878      348,407
00080.M2TS      4113 (0x1011)   0xEA            VC-1                                    2710.416                25,490                  8,636,162,234   46,974,832
00080.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2710.416                3,755                   1,272,242,816   7,336,767
00080.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2710.416                192                     65,053,440      423,525
00080.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2710.416                192                     65,053,440      423,525
00080.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2710.416                37                      12,481,769      71,985
00080.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2710.416                34                      11,617,946      67,115
00080.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2710.416                33                      11,336,174      65,572
00080.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2710.416                169                     57,361,028      356,942
00081.M2TS      4113 (0x1011)   0xEA            VC-1                                    2626.833                26,399                  8,668,244,616   47,148,202
00081.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2626.833                4,101                   1,346,576,852   7,728,171
00081.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2626.833                192                     63,047,424      410,465
00081.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2626.833                28                      9,045,904       52,300
00081.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2626.833                22                      7,316,796       42,240
00081.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2626.833                23                      7,406,499       42,738
00081.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2626.833                219                     71,809,921      433,095
eric.exe is offline
post #357 of 5106 Old 08-29-2009, 08:43 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
*extended version of episode 9 (00110.m2ts)
Code:
        Total   Video
Battlestar Galactica Season 3 Disc 3 Episodes *9-12              VC-1    3:21:30 43,943,049,216  45,990,552,648  29.08   23.12   DTS-HD Master 5.1 3888Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      45,990,552,648 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:21:30 (h:m:s)
Total Bitrate:          29.08 Mbps
Description:
VIDEO:
VC-1 Video              23117 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              203 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3888 kbps       5.1 / 48 kHz / 3888 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         35.830 kbps
Presentation Graphics           French          30.345 kbps
Presentation Graphics           Spanish         31.071 kbps
FILES:
00110.M2TS      0:00:00.000     1:10:11.207     15,378,272,256  29,214
00111.M2TS      1:10:11.207     0:43:48.250     9,529,141,248   29,005
00112.M2TS      1:53:59.457     0:43:44.246     9,546,264,576   29,102
00113.M2TS      2:37:43.704     0:43:46.623     9,489,371,136   28,902
CHAPTERS:
1               0:00:00.000     1:10:11.207     23,173 kbps     48,235 kbps     00:01:47.774    37,265 kbps     00:42:47.773    35,279 kbps     00:30:28.785    121,243 bytes   607,908 bytes   00:11:38.406
2               1:10:11.207     0:43:48.250     23,072 kbps     47,025 kbps     01:47:24.521    38,116 kbps     01:46:58.453    36,507 kbps     01:47:12.259    120,400 bytes   461,341 bytes   01:15:38.700
3               1:53:59.457     0:43:44.246     23,164 kbps     50,280 kbps     02:28:00.079    37,528 kbps     01:59:06.639    36,302 kbps     02:27:27.338    121,219 bytes   530,287 bytes   02:33:12.683
4               2:37:43.704     0:43:46.623     23,025 kbps     49,766 kbps     02:56:02.385    38,404 kbps     02:59:32.595    36,669 kbps     02:59:27.506    120,434 bytes   688,827 bytes   02:55:24.513
STREAM DIAGNOSTICS:
00110.M2TS      4113 (0x1011)   0xEA            VC-1                                    4211.082                23,174                  12,198,353,854  66,356,386
00110.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4211.082                4,011                   2,111,201,984   12,129,728
00110.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           4211.082                192                     101,069,568     658,005
00110.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4211.082                30                      15,984,712      92,646
00110.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           4211.082                24                      12,661,096      72,924
00110.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            4211.082                24                      12,705,113      73,158
00110.M2TS      6912 (0x1B00)   0xEA            VC-1                                    4211.082                178                     93,437,915      571,225
00111.M2TS      4113 (0x1011)   0xEA            VC-1                                    2628.126                23,074                  7,580,009,539   41,233,856
00111.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2628.126                3,866                   1,270,117,732   7,313,992
00111.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2628.126                192                     63,078,144      410,665
00111.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2628.126                36                      11,963,797      68,666
00111.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2628.126                32                      10,479,314      60,232
00111.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2628.126                30                      10,010,911      57,714
00111.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2628.126                198                     65,208,996      397,737
00112.M2TS      4113 (0x1011)   0xEA            VC-1                                    2624.122                23,165                  7,598,586,587   41,334,729
00112.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2624.122                3,790                   1,243,117,764   7,164,990
00112.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2624.122                192                     62,982,144      410,040
00112.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2624.122                45                      14,724,711      84,070
00112.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2624.122                40                      13,239,782      75,495
00112.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2624.122                39                      12,813,646      73,172
00112.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2624.122                251                     82,323,647      489,678
00113.M2TS      4113 (0x1011)   0xEA            VC-1                                    2626.499                23,027                  7,559,885,787   41,124,389
00113.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2626.499                3,813                   1,251,973,372   7,213,647
00113.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2626.499                192                     63,038,976      410,410
00113.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2626.499                35                      11,476,794      66,161
00113.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2626.499                32                      10,577,387      60,967
00113.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2626.499                31                      10,331,020      59,639
00113.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2626.499                200                     65,781,647      400,576
eric.exe is offline
post #358 of 5106 Old 08-29-2009, 09:53 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 3 Disc 4 Episodes 13-17             VC-1    3:38:37 45,248,004,096  46,744,808,080  27.59   21.79   DTS-HD Master 5.1 3760Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S3_D4
Disc Size:      46,744,808,080 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:38:37 (h:m:s)
Total Bitrate:          27.59 Mbps
Description:
VIDEO:
VC-1 Video              21792 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              213 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3760 kbps       5.1 / 48 kHz / 3760 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         43.579 kbps
Presentation Graphics           French          38.112 kbps
Presentation Graphics           Spanish         37.393 kbps
FILES:
00012.M2TS      0:00:00.000     0:43:44.830     8,917,899,264   27,180
00013.M2TS      0:43:44.830     0:43:48.250     9,096,751,104   27,689
00014.M2TS      1:27:33.081     0:43:37.823     9,134,770,176   27,916
00015.M2TS      2:11:10.904     0:43:45.456     9,124,988,928   27,805
00016.M2TS      2:54:56.360     0:43:41.618     8,973,594,624   27,383
CHAPTERS:
1               0:00:00.000     0:43:44.830     21,504 kbps     49,499 kbps     00:00:36.619    40,053 kbps     00:06:49.158    37,433 kbps     00:06:48.908    112,460 bytes   704,220 bytes   00:10:34.884
2               0:43:44.830     0:43:48.250     21,977 kbps     40,865 kbps     01:12:05.404    37,976 kbps     01:12:02.568    36,129 kbps     01:11:56.562    114,969 bytes   440,202 bytes   01:18:01.176
3               1:27:33.081     0:43:37.823     22,099 kbps     42,077 kbps     01:51:44.948    37,135 kbps     01:34:08.017    36,318 kbps     01:34:03.304    115,609 bytes   435,509 bytes   01:57:08.646
4               2:11:10.904     0:43:45.456     21,836 kbps     47,884 kbps     02:15:54.396    39,493 kbps     02:15:52.477    35,789 kbps     02:53:06.876    114,202 bytes   431,314 bytes   02:15:54.646
5               2:54:56.360     0:43:41.618     21,544 kbps     46,797 kbps     03:12:01.801    36,264 kbps     03:31:42.564    34,403 kbps     03:31:39.561    112,612 bytes   719,525 bytes   03:03:18.862
STREAM DIAGNOSTICS:
00012.M2TS      4113 (0x1011)   0xEA            VC-1                                    2624.705                21,505                  7,055,597,824   38,383,780
00012.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2624.705                3,654                   1,198,859,468   6,924,253
00012.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2624.705                192                     62,995,968      410,130
00012.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2624.705                37                      12,102,004      69,438
00012.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2624.705                32                      10,590,657      60,736
00012.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2624.705                33                      10,838,546      62,077
00012.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2624.705                228                     74,805,518      448,997
00013.M2TS      4113 (0x1011)   0xEA            VC-1                                    2628.126                21,978                  7,220,157,536   39,278,090
00013.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2628.126                3,675                   1,207,225,156   6,969,569
00013.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2628.126                192                     63,078,144      410,665
00013.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2628.126                50                      16,322,390      93,032
00013.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2628.126                42                      13,931,894      79,849
00013.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2628.126                43                      14,049,318      80,481
00013.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2628.126                188                     61,772,710      379,135
00014.M2TS      4113 (0x1011)   0xEA            VC-1                                    2617.698                22,100                  7,231,479,295   39,339,452
00014.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2617.698                3,748                   1,226,478,656   7,075,387
00014.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2617.698                192                     62,827,776      409,035
00014.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2617.698                43                      14,068,279      80,382
00014.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2617.698                36                      11,926,057      68,555
00014.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2617.698                38                      12,399,907      71,139
00014.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2617.698                226                     74,082,275      445,233
00015.M2TS      4113 (0x1011)   0xEA            VC-1                                    2625.331                21,837                  7,166,198,010   38,984,830
00015.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2625.331                3,897                   1,278,887,564   7,359,463
00015.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2625.331                192                     63,011,328      410,230
00015.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2625.331                53                      17,524,496      99,731
00015.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2625.331                45                      14,734,890      84,406
00015.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2625.331                46                      15,115,778      86,481
00015.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2625.331                207                     68,080,063      412,869
00016.M2TS      4113 (0x1011)   0xEA            VC-1                                    2621.494                21,545                  7,059,877,265   38,406,909
00016.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2621.494                3,829                   1,254,617,444   7,227,841
00016.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2621.494                192                     62,919,168      409,630
00016.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2621.494                35                      11,441,762      65,885
00016.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2621.494                31                      10,131,210      58,583
00016.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2621.494                31                      10,091,268      58,373
00016.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2621.494                213                     69,808,249      422,382
eric.exe is offline
post #359 of 5106 Old 08-29-2009, 10:26 PM
Upinit's Avatar
Man, are we done yet with BSG?
Upinit is offline
post #360 of 5106 Old 08-30-2009, 09:24 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Battlestar Galactica Season 3 Disc 5 Episodes 18-20             VC-1    2:17:13 38,683,176,960  42,241,579,336  37.59   31.27   DTS-HD Master 5.1 3596Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BSG_S3_D5
Disc Size:      42,241,579,336 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:17:13 (h:m:s)
Total Bitrate:          37.59 Mbps
Description:
VIDEO:
VC-1 Video              31271 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              247 kbps            480p / 23.976 fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3596 kbps       5.1 / 48 kHz / 3596 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         43.148 kbps
Presentation Graphics           French          39.279 kbps
Presentation Graphics           Spanish         37.087 kbps
FILES:
00070.M2TS      0:00:00.000     0:44:39.676     12,547,510,272  37,460
00071.M2TS      0:44:39.676     0:44:40.678     12,533,471,232  37,404
00072.M2TS      1:29:20.354     0:47:52.870     13,602,195,456  37,878
CHAPTERS:
1               0:00:00.000     0:44:39.676     31,154 kbps     47,809 kbps     00:07:42.837    38,244 kbps     00:21:58.400    36,460 kbps     00:17:16.660    162,514 bytes   500,168 bytes   00:34:11.841
2               0:44:39.676     0:44:40.678     31,182 kbps     46,120 kbps     01:17:50.957    39,946 kbps     00:57:13.596    37,361 kbps     00:57:13.596    163,177 bytes   502,634 bytes   00:57:13.638
3               1:29:20.354     0:47:52.869     31,463 kbps     48,236 kbps     01:40:28.897    39,217 kbps     01:48:52.484    37,418 kbps     01:48:47.395    164,091 bytes   756,518 bytes   01:40:29.857
STREAM DIAGNOSTICS:
00070.M2TS      4113 (0x1011)   0xEA            VC-1                                    2679.552                31,155                  10,435,319,533  56,752,450
00070.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2679.552                3,639                   1,218,975,744   7,041,230
00070.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2679.552                192                     64,312,320      418,700
00070.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2679.552                192                     64,312,320      418,700
00070.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2679.552                42                      14,159,118      81,523
00070.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2679.552                39                      12,907,312      74,425
00070.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2679.552                41                      13,654,936      78,499
00070.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2679.552                196                     65,551,700      396,281
00071.M2TS      4113 (0x1011)   0xEA            VC-1                                    2680.553                31,183                  10,448,565,994  56,824,548
00071.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2680.553                3,487                   1,168,418,180   6,768,993
00071.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2680.553                192                     64,336,896      418,860
00071.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2680.553                192                     64,336,896      418,860
00071.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2680.553                47                      15,671,927      89,699
00071.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2680.553                40                      13,283,515      76,263
00071.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2680.553                42                      14,229,046      81,397
00071.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2680.553                259                     86,671,069      510,022
00072.M2TS      4113 (0x1011)   0xEA            VC-1                                    2872.745                31,464                  11,298,638,035  61,447,210
00072.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2872.745                3,656                   1,312,938,296   7,585,305
00072.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2872.745                192                     68,949,504      448,890
00072.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2872.745                192                     68,949,504      448,890
00072.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2872.745                41                      14,574,466      83,652
00072.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2872.745                33                      11,977,097      68,866
00072.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2872.745                35                      12,539,905      71,938
00072.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2872.745                283                     101,641,520     593,728
eric.exe is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
